RTEMS 6.1-rc2
Functions | Variables
This header file provides the interfaces of the Object Handler Multiprocessing (MP) Support. More...
void _Objects_MP_Handler_initialization (void)
 Intializes the inactive global object chain based on the maximum number of global objects configured.
void _Objects_MP_Handler_early_initialization (void)
 Intializes the global object node number used in the ID field of all objects.
void _Objects_MP_Open (Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id)
 Place the specified global object in the specified information table.
bool _Objects_MP_Allocate_and_open (Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error)
 Allocates a global object control block and places it in the specified information table.
void _Objects_MP_Close (Objects_Information *information, Objects_Id the_id)
 Removes a global object from the specified information table.
Status_Control _Objects_MP_Global_name_search (const Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id)
 Looks for the object with the_name in the global object tables indicated by information.
bool _Objects_MP_Is_remote (Objects_Id id, const Objects_Information *information)
 Checks if the object identifier is in the global object identifier cache of the specified object information.
Objects_MP_Control * _Objects_MP_Allocate_global_object (void)
 This function allocates a Global Object control block.
void _Objects_MP_Free_global_object (Objects_MP_Control *the_object)
 This routine deallocates a Global Object control block.
uint32_t _Objects_MP_Maximum_global_objects
