RTEMS 6.1-rc2
RTEMS monitor main body. More...
#include <rtems/monitor.h>
#define | RTEMS_MONITOR_POSIX_NEXT 19 |
#define | RTEMS_MONITOR_DEBUGGER_NEXT (RTEMS_MONITOR_POSIX_NEXT + 1) |
rtems_status_code | rtems_monitor_suspend (rtems_interval timeout) |
void | __attribute__ ((weak)) |
Zynq UltraScale+ MPSoC specific set up of a management console. | |
void | rtems_monitor_wakeup (void) |
void | rtems_monitor_debugger_cmd (int argc RTEMS_UNUSED, char **argv RTEMS_UNUSED, const rtems_monitor_command_arg_t *command_arg RTEMS_UNUSED, bool verbose RTEMS_UNUSED) |
void | rtems_monitor_pause_cmd (int argc, char **argv, const rtems_monitor_command_arg_t *command_arg RTEMS_UNUSED, bool verbose RTEMS_UNUSED) |
void | rtems_monitor_fatal_cmd (int argc, char **argv, const rtems_monitor_command_arg_t *command_arg, bool verbose RTEMS_UNUSED) |
void | rtems_monitor_continue_cmd (int argc RTEMS_UNUSED, char **argv RTEMS_UNUSED, const rtems_monitor_command_arg_t *command_arg RTEMS_UNUSED, bool verbose RTEMS_UNUSED) |
void | rtems_monitor_symbols_loadup (void) |
int | rtems_monitor_insert_cmd (rtems_monitor_command_entry_t *command) |
void | rtems_monitor_command_iterate (rtems_monitor_per_command_routine routine, void *arg) |
Iterates through all registerd commands. | |
rtems_id | rtems_monitor_task_id |
uint32_t | rtems_monitor_node |
uint32_t | rtems_monitor_default_node |
rtems_symbol_table_t * | rtems_monitor_symbols |
TODO: add stuff to RTEMS api rtems_get_name(id) rtems_get_type(id) rtems_build_id(node, type, num) Add a command to dump out info about an arbitrary id when types are added to id's rtems> id idnum idnum: node n, object: whatever, id: whatever allow id's to be specified as n:t:id, where 'n:t' is optional should have a separate monitor FILE stream (ala the debugger) remote request/response stuff should be cleaned up maybe we can use real rpc?? 'info' command to print out: interrupt stack location, direction and size floating point config stuff interrupt config stuff
void rtems_monitor_command_iterate | ( | rtems_monitor_per_command_routine | routine, |
void * | arg | ||
For each command the interation routine routine is called with the command entry and the user provided argument arg. It is guaranteed that the command name and function are not NULL.
