RTEMS 6.1-rc2
Create a Special or Ordinary File. More...
#include <sys/stat.h>
#include <rtems/libio_.h>
int rtems_filesystem_mknod (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
int mknod (const char *path, mode_t mode, dev_t dev)
◆ mknod()
int mknod ( const char *  path,
mode_t  mode,
dev_t  dev
This routine is not defined in the POSIX 1003.1b standard but is commonly supported on most UNIX and POSIX systems. It is the foundation for creating file system objects.
