RTEMS 6.1-rc2
Macros | Variables
conscfg.c File Reference
#include <unistd.h>
#include <bsp.h>
#include <libchip/serial.h>
#include <libchip/ns16550.h>
#include <rtems/pci.h>
#include <bsp/irq.h>
#define COM_CONSOLE_FUNCTIONS   &ns16550_fns_polled
#define COM1_BASE_IO   0x3F8
#define COM2_BASE_IO   0x3E8
#define CLOCK_RATE   (115200 * 16)
#define COM_IO_BASE_ADDRESS   (0xa0000000UL | 0x18000000UL)
console_tbl Console_Configuration_Ports []
unsigned long Console_Configuration_Count
This file contains the libchip configuration information to instantiate the libchip driver for the serial ports.
Variable Documentation
◆ Console_Configuration_Count
Initial value:
console_tbl Console_Configuration_Ports[]
Definition: conscfg.c:84
Definition: serial.h:136
The number of serial ports defined in Console_Configuration_Ports
◆ Console_Configuration_Ports
The statically configured serial port information tables which are used to initially populate the dynamic tables.
