| __FBSDID ("$FreeBSD$") |
| SYSCTL_PROC (_kern, KERN_BOOTTIME, boottime, CTLTYPE_STRUCT|CTLFLAG_RD|CTLFLAG_MPSAFE, NULL, 0, sysctl_kern_boottime, "S,timeval", "Estimated system boottime") |
| SYSCTL_NODE (_kern, OID_AUTO, timecounter, CTLFLAG_RW|CTLFLAG_MPSAFE, 0, "") |
| SYSCTL_INT (_kern_timecounter, OID_AUTO, stepwarnings, CTLFLAG_RWTUN, ×tepwarnings, 0, "Log time steps") |
| SYSCTL_INT (_kern_timecounter, OID_AUTO, timehands_count, CTLFLAG_RDTUN|CTLFLAG_NOFETCH, &timehands_count, 0, "Count of timehands in rotation") |
| SYSCTL_PROC (_kern_timecounter, OID_AUTO, alloweddeviation, CTLTYPE_INT|CTLFLAG_RWTUN|CTLFLAG_MPSAFE, 0, 0, sysctl_kern_timecounter_adjprecision, "I", "Allowed time interval deviation in percents") |
void | dtrace_getnanotime (struct timespec *tsp) |
void | dtrace_getnanouptime (struct timespec *tsp) |
void | binuptime (struct bintime *bt) |
void | nanouptime (struct timespec *tsp) |
void | microuptime (struct timeval *tvp) |
void | bintime (struct bintime *bt) |
void | nanotime (struct timespec *tsp) |
void | microtime (struct timeval *tvp) |
void | getbinuptime (struct bintime *bt) |
void | getnanouptime (struct timespec *tsp) |
void | getmicrouptime (struct timeval *tvp) |
void | getbintime (struct bintime *bt) |
void | getnanotime (struct timespec *tsp) |
void | getmicrotime (struct timeval *tvp) |
void | getboottime (struct timeval *boottime) |
void | getboottimebin (struct bintime *boottimebin) |
void | sysclock_getsnapshot (struct sysclock_snap *clock_snap, int fast) |
int | sysclock_snap2bintime (struct sysclock_snap *cs, struct bintime *bt, int whichclock, uint32_t flags) |
void | tc_init (struct timecounter *tc) |
uint64_t | tc_getfrequency (void) |
| MTX_SYSINIT (tc_setclock_init, &tc_setclock_mtx, "tcsetc", MTX_SPIN) |
void | tc_setclock (struct timespec *ts) |
| SYSCTL_PROC (_kern_timecounter, OID_AUTO, hardware, CTLTYPE_STRING|CTLFLAG_RWTUN|CTLFLAG_NOFETCH|CTLFLAG_MPSAFE, 0, 0, sysctl_kern_timecounter_hardware, "A", "Timecounter hardware selected") |
| SYSCTL_PROC (_kern_timecounter, OID_AUTO, choice, CTLTYPE_STRING|CTLFLAG_RD|CTLFLAG_MPSAFE, 0, 0, sysctl_kern_timecounter_choice, "A", "Timecounter hardware detected") |
int | pps_ioctl (u_long cmd, caddr_t data, struct pps_state *pps) |
void | pps_init (struct pps_state *pps) |
void | pps_init_abi (struct pps_state *pps) |
void | pps_capture (struct pps_state *pps) |
void | pps_event (struct pps_state *pps, int event) |
| SYSCTL_INT (_kern_timecounter, OID_AUTO, tick, CTLFLAG_RD, &tc_tick, 0, "Approximate number of hardclock ticks in a millisecond") |
void | tc_ticktock (int cnt) |
| SYSINIT (timehands, SI_SUB_TUNABLES, SI_ORDER_ANY, inittimehands, NULL) |
| SYSINIT (timecounter, SI_SUB_CLOCKS, SI_ORDER_SECOND, inittimecounter, NULL) |
| DPCPU_DEFINE_STATIC (uint64_t, tc_cpu_ticks_base) |
| DPCPU_DEFINE_STATIC (unsigned, tc_cpu_ticks_last) |
void | cpu_tick_calibration (void) |
void | set_cputicker (cpu_tick_f *func, uint64_t freq, bool isvariable) |
uint64_t | cpu_tickrate (void) |
uint64_t | cputick2usec (uint64_t tick) |
| SYSCTL_PROC (_kern_timecounter, OID_AUTO, fast_gettime, CTLTYPE_INT|CTLFLAG_RW|CTLFLAG_MPSAFE, NULL, 0, sysctl_fast_gettime, "I", "Enable fast time of day") |
uint32_t | tc_fill_vdso_timehands (struct vdso_timehands *vdso_th) |
This source file contains the definition of _Timecounter, _Timecounter_Time_second, and _Timecounter_Time_uptime and the implementation of _Timecounter_Set_NTP_update_second(), _Timecounter_Binuptime(), _Timecounter_Nanouptime(), _Timecounter_Microuptime(), _Timecounter_Bintime(), _Timecounter_Nanotime(), _Timecounter_Microtime(), _Timecounter_Getbinuptime(), _Timecounter_Getnanouptime(), _Timecounter_Getmicrouptime(), _Timecounter_Getbintime(), _Timecounter_Getnanotime(), _Timecounter_Getmicrotime(), _Timecounter_Getboottime(), _Timecounter_Getboottimebin(), and _Timecounter_Install().
