RTEMS 6.1-rc2
Files | Macros | Functions
ARM system low level start. More...
file  arm-cp15-start.h
 Arm CP15 start.
file  start.h
file  bspstart.c
 Raspberry pi startup code.
file  bspstarthooks.c
 Rasberry Pi startup code.
#define BSP_START_TEXT_SECTION   __attribute__((section(".bsp_start_text")))
#define BSP_START_DATA_SECTION   __attribute__((section(".bsp_start_data")))
void _start (void)
 System start entry.
void bsp_start_hook_0 (void)
 Start entry hook 0.
void bsp_start_hook_0_done (void)
 Can be used by bsp_start_hook_0() to jump back to the start code instead of using the link register.
void bsp_start_hook_1 (void)
 Start entry hook 1.
void bsp_start_memcpy (int *dest, const int *src, size_t n)
 Similar to standard memcpy().
void bsp_start_memcpy_arm (int *dest, const int *src, size_t n)
 ARM entry point to bsp_start_memcpy().
◆ bsp_start_hook_0()
void bsp_start_hook_0 ( void  )
Start entry hook 0.
This hook will be called from the start entry code after all modes and stack pointers are initialized but before the copying of the exception vectors.
◆ bsp_start_hook_1()
void bsp_start_hook_1 ( void  )
Start entry hook 1.
This hook will be called from the start entry code after copying of the exception vectors but before the call to boot_card().
◆ bsp_start_memcpy()
void bsp_start_memcpy ( int *  dest,
const int *  src,
size_t  n
The memory areas must be word aligned. Copy code will be executed from the stack. If dest equals src nothing will be copied.
