RTEMS 6.1-rc2
Macros | Functions
Cortex A53 64bit Processor Cache Functions
#define Xil_DCacheFlushRange   Xil_DCacheInvalidateRange
void Xil_DCacheEnable (void)
 Enable the Data cache.
void Xil_DCacheDisable (void)
 Disable the Data cache.
void Xil_DCacheInvalidate (void)
 Invalidate the Data cache. The contents present in the cache are cleaned and invalidated.
void Xil_DCacheInvalidateRange (INTPTR adr, INTPTR len)
 Invalidate the Data cache for the given address range. The cachelines present in the adderss range are cleaned and invalidated.
void Xil_DCacheInvalidateLine (INTPTR adr)
 Invalidate a Data cache line. The cacheline is cleaned and invalidated.
void Xil_DCacheFlush (void)
 Flush the Data cache.
void Xil_DCacheFlushLine (INTPTR adr)
 Flush a Data cache line. If the byte specified by the address (adr) is cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the entire contents of the cacheline are written to system memory before the line is invalidated.
void Xil_ICacheEnable (void)
 Enable the instruction cache.
void Xil_ICacheDisable (void)
 Disable the instruction cache.
void Xil_ICacheInvalidate (void)
 Invalidate the entire instruction cache.
void Xil_ICacheInvalidateRange (INTPTR adr, INTPTR len)
 Invalidate the instruction cache for the given address range. If the instructions specified by the address range are cached by the instrunction cache, the cachelines containing those instructions are invalidated.
void Xil_ICacheInvalidateLine (INTPTR adr)
 Invalidate an instruction cache line. If the instruction specified by the parameter adr is cached by the instruction cache, the cacheline containing that instruction is invalidated.
void Xil_ConfigureL1Prefetch (u8 num)
 Configure the maximum number of outstanding data prefetches allowed in L1 cache.
Cache functions provide access to cache related operations such as flush and invalidate for instruction and data caches. It gives option to perform the cache operations on a single cacheline, a range of memory and an entire cache.
MODIFICATION HISTORY:
Ver   Who  Date     Changes
5.00    pkp  05/29/14 First release
◆ Xil_ConfigureL1Prefetch()
void Xil_ConfigureL1Prefetch ( u8  num)
Parameters
nummaximum number of outstanding data prefetches allowed, valid values are 0-7.
Returns
None.
Note
This function is implemented only for EL3 privilege level.
◆ Xil_DCacheDisable()
void Xil_DCacheDisable ( void  )
Returns
None.
Returns
None.
◆ Xil_DCacheEnable()
void Xil_DCacheEnable ( void  )
Returns
None.
Returns
None.
◆ Xil_DCacheFlush()
void Xil_DCacheFlush ( void  )
Returns
None.
Returns
None.
◆ Xil_DCacheFlushLine()
void Xil_DCacheFlushLine ( INTPTR  adr)
Parameters
adr64bit address of the data to be flushed.
Returns
None.
Note
The bottom 6 bits are set to 0, forced by architecture.
Parameters
adr32bit address of the data to be flushed.
Returns
None.
Note
The bottom 5 bits are set to 0, forced by architecture.
◆ Xil_DCacheInvalidate()
void Xil_DCacheInvalidate ( void  )
Returns
None.
Note
In Cortex-A53, functionality to simply invalid the cachelines is not present. Such operations are a problem for an environment that supports virtualisation. It would allow one OS to invalidate a line belonging to another OS. This could lead to the other OS crashing because of the loss of essential data. Hence, such operations are promoted to clean and invalidate which avoids such corruption.
Returns
None.
◆ Xil_DCacheInvalidateLine()
void Xil_DCacheInvalidateLine ( INTPTR  adr)
Parameters
Returns
None.
Note
Parameters
Returns
None.
Note
◆ Xil_DCacheInvalidateRange()
void Xil_DCacheInvalidateRange ( INTPTR  adr,
INTPTR  len
Parameters
adr64bit start address of the range to be invalidated.
lenLength of the range to be invalidated in bytes.
Returns
None.
Note
◆ Xil_ICacheDisable()
void Xil_ICacheDisable ( void  )
Returns
None.
Returns
None.
◆ Xil_ICacheEnable()
void Xil_ICacheEnable ( void  )
Returns
None.
Returns
None.
◆ Xil_ICacheInvalidate()
void Xil_ICacheInvalidate ( void  )
Returns
None.
Returns
None.
◆ Xil_ICacheInvalidateLine()
void Xil_ICacheInvalidateLine ( INTPTR  adr)
Parameters
adr64bit address of the instruction to be invalidated.
Returns
None.
Note
Parameters
adr32bit address of the instruction to be invalidated.
Returns
None.
Note
◆ Xil_ICacheInvalidateRange()
void Xil_ICacheInvalidateRange ( INTPTR  adr,
INTPTR  len
Parameters
Returns
None.
