RTEMS 6.1-rc2
#define | Xil_L1DCacheInvalidate() microblaze_invalidate_dcache() |
Invalidate the entire L1 data cache. If the cacheline is modified (dirty), the modified contents are lost. | |
#define | Xil_L2CacheInvalidate() microblaze_invalidate_cache_ext() |
Invalidate the entire L2 data cache. If the cacheline is modified (dirty),the modified contents are lost. | |
#define | Xil_L1DCacheInvalidateRange(Addr, Len) microblaze_invalidate_dcache_range((Addr), (Len)) |
Invalidate the L1 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the L1 data cache, the cacheline containing that byte is invalidated.If the cacheline is modified (dirty), the modified contents are lost. | |
#define | Xil_L2CacheInvalidateRange(Addr, Len) microblaze_invalidate_cache_ext_range((Addr), (Len)) |
Invalidate the L1 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the L1 data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the modified contents are lost. | |
#define | Xil_L1DCacheFlushRange(Addr, Len) microblaze_invalidate_dcache_range((Addr), (Len)) |
Flush the L1 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the data cache, and is modified (dirty), the cacheline will be written to system memory.The cacheline will also be invalidated. | |
#define | Xil_L2CacheFlushRange(Addr, Len) microblaze_flush_cache_ext_range((Addr), (Len)) |
Flush the L2 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the data cache, and is modified (dirty), the cacheline will be written to system memory. The cacheline will also be invalidated. | |
#define | Xil_L1DCacheFlush() microblaze_invalidate_dcache() |
Flush the entire L1 data cache. If any cacheline is dirty, the cacheline will be written to system memory. The entire data cache will be invalidated. | |
#define | Xil_L2CacheFlush() microblaze_flush_cache_ext() |
Flush the entire L2 data cache. If any cacheline is dirty, the cacheline will be written to system memory. The entire data cache will be invalidated. | |
#define | Xil_L1ICacheInvalidateRange(Addr, Len) microblaze_invalidate_icache_range((Addr), (Len)) |
Invalidate the instruction cache for the given address range. | |
#define | Xil_L1ICacheInvalidate() microblaze_invalidate_icache() |
Invalidate the entire instruction cache. | |
#define | Xil_L1DCacheEnable() microblaze_enable_dcache() |
Enable the L1 data cache. | |
#define | Xil_L1DCacheDisable() microblaze_disable_dcache() |
Disable the L1 data cache. | |
#define | Xil_L1ICacheEnable() microblaze_enable_icache() |
Enable the instruction cache. | |
#define | Xil_L1ICacheDisable() microblaze_disable_icache() |
Disable the L1 Instruction cache. | |
#define | Xil_DCacheEnable() Xil_L1DCacheEnable() |
Enable the data cache. | |
#define | Xil_ICacheEnable() Xil_L1ICacheEnable() |
#define | Xil_DCacheInvalidate() |
Invalidate the entire Data cache. | |
#define | Xil_DCacheInvalidateRange(Addr, Len) |
Invalidate the Data cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the modified contents are lost and are NOT written to system memory before the line is invalidated. | |
#define | Xil_DCacheFlush() |
Flush the entire Data cache. | |
#define | Xil_DCacheFlushRange(Addr, Len) |
Flush the Data cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the written to system memory first before the before the line is invalidated. | |
#define | Xil_ICacheInvalidate() |
#define | Xil_ICacheInvalidateRange(Addr, Len) |
Invalidate the instruction cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the modified contents are lost and are NOT written to system memory before the line is invalidated. | |
void | Xil_DCacheDisable (void) |
Disable the Data cache. | |
void | Xil_ICacheDisable (void) |
Disable the instruction cache. | |
The xil_cache.h file contains cache related driver functions (or macros) that can be used to access the device. The user should refer to the hardware device specification for more details of the device operation. The functions in this header file can be used across all Xilinx supported processors.
MODIFICATION HISTORY: Ver Who Date Changes ----- ---- -------- ------------------------------------------------------- 1.00 hbm 07/28/09 Initial release 3.02a sdm 10/24/11 Updated the file to include xparameters.h so that the correct cache flush routines are used based on whether the write-back or write-through caches are used (cr #630532). 3.10a asa 05/04/13 This version of MicroBlaze BSP adds support for system cache/L2 cache. The existing/old APIs/macros in this file are renamed to imply that they deal with L1 cache. New macros/APIs are added to address similar features for L2 cache. Users can include this file in their application to use the various cache related APIs. These changes are done for implementing PR #697214.
void Xil_DCacheEnable | ( | ) | Xil_L1DCacheEnable() |
void Xil_DCacheFlush | ( | ) |
#define Xil_DCacheFlushRange | ( | Addr, | |
Len | |||
Addr | Start address of range to be flushed. |
Len | Length of range to be flushed in bytes. |
void Xil_DCacheInvalidate | ( | ) |
#define Xil_DCacheInvalidateRange | ( | Addr, | |
Len | |||
Addr | Start address of range to be invalidated. |
Len | Length of range to be invalidated in bytes. |
void Xil_ICacheEnable | ( | ) | Xil_L1ICacheEnable() |
void Xil_ICacheInvalidate | ( | ) |
#define Xil_ICacheInvalidateRange | ( | Addr, | |
Len | |||
Addr | Start address of ragne to be invalidated. |
#define Xil_L1DCacheDisable | ( | ) | microblaze_disable_dcache() |
#define Xil_L1DCacheEnable | ( | ) | microblaze_enable_dcache() |
#define Xil_L1DCacheFlush | ( | ) | microblaze_invalidate_dcache() |
#define Xil_L1DCacheFlushRange | ( | Addr, | |
Len | |||
) | microblaze_invalidate_dcache_range((Addr), (Len)) |
Addr | the starting address of the range to be flushed. |
Len | length in byte to be flushed. |
#define Xil_L1DCacheInvalidate | ( | ) | microblaze_invalidate_dcache() |
#define Xil_L1DCacheInvalidateRange | ( | Addr, | |
Len | |||
Addr | is address of range to be invalidated. |
Len | is the length in bytes to be invalidated. |
#define Xil_L1ICacheDisable | ( | ) | microblaze_disable_icache() |
#define Xil_L1ICacheEnable | ( | ) | microblaze_enable_icache() |
#define Xil_L1ICacheInvalidate | ( | ) | microblaze_invalidate_icache() |
#define Xil_L1ICacheInvalidateRange | ( | Addr, | |
Len | |||
) | microblaze_invalidate_icache_range((Addr), (Len)) |
Addr | is address of ragne to be invalidated. |
#define Xil_L2CacheFlush | ( | ) | microblaze_flush_cache_ext() |
#define Xil_L2CacheFlushRange | ( | Addr, | |
Len | |||
) | microblaze_flush_cache_ext_range((Addr), (Len)) |
#define Xil_L2CacheInvalidate | ( | ) | microblaze_invalidate_cache_ext() |
#define Xil_L2CacheInvalidateRange | ( | Addr, | |
Len | |||
) | microblaze_invalidate_cache_ext_range((Addr), (Len)) |
Addr | address of range to be invalidated. |
Len | length in bytes to be invalidated. |
void Xil_DCacheDisable | ( | void | ) |
void Xil_ICacheDisable | ( | void | ) |
