RTEMS 6.1-rc2
Data Structures | Typedefs | Enumerations | Functions
struct  ALT_16550_HANDLE_s
typedef enum ALT_16550_DEVICE_e ALT_16550_DEVICE_t
typedef struct ALT_16550_HANDLE_s ALT_16550_HANDLE_t
enum  ALT_16550_DEVICE_e { ALT_16550_DEVICE_SOCFPGA_UART0 = 0 , ALT_16550_DEVICE_SOCFPGA_UART1 = 1 , ALT_16550_DEVICE_ALTERA_16550_UART = 0x100 }
ALT_STATUS_CODE alt_16550_init (ALT_16550_DEVICE_t device, void *location, alt_freq_t clock_freq, ALT_16550_HANDLE_t *handle)
ALT_STATUS_CODE alt_16550_uninit (ALT_16550_HANDLE_t *handle)
ALT_STATUS_CODE alt_16550_reset (ALT_16550_HANDLE_t *handle)
ALT_STATUS_CODE alt_16550_enable (ALT_16550_HANDLE_t *handle)
ALT_STATUS_CODE alt_16550_disable (ALT_16550_HANDLE_t *handle)
ALT_STATUS_CODE alt_16550_read (ALT_16550_HANDLE_t *handle, char *item)
ALT_STATUS_CODE alt_16550_write (ALT_16550_HANDLE_t *handle, char item)
This group of APIs provides basic access to the UART to initialize, uninitialize, read, write, and reset the UART.
Typedef Documentation
◆ ALT_16550_DEVICE_t
This type definition enumerates the list of UARTs available on the system.
◆ ALT_16550_HANDLE_t
This structure is used to represent a handle to a specific UART on the system. The internal members are undocumented and should be not altered outside of this API.
◆ ALT_16550_DEVICE_e
This option selects UART0 in the SoC FPGA.
This option selects UART1 in the SoC FPGA.
This option selects an Altera 16550 Compatible soft IP UART. The memory location of the device must be provided as part of the initialization.
◆ alt_16550_disable()
ALT_STATUS_CODE alt_16550_disable ( ALT_16550_HANDLE_t handle)
Stops the UART. While UART configuration can be done while enabled, it is not recommended.
Parameters
handleThe UART device handle.
Return values
ALT_E_SUCCESSThe operation was successful.
ALT_E_ERRORThe operation failed.
ALT_E_BAD_ARGThe given UART device handle is invalid.
◆ alt_16550_enable()
ALT_STATUS_CODE alt_16550_enable ( ALT_16550_HANDLE_t handle)
Starts the UART after all configuration has been completed.
Parameters
Return values
◆ alt_16550_init()
ALT_STATUS_CODE alt_16550_init ( ALT_16550_DEVICE_t  device,
void *  location,
Performs the initialization steps needed by the UART. This should be the first API call made when accessing a particular UART
The default UART setting is 8 databits, no parity, 1 stopbit, and 57600 baud.
For the SoCFPGA UARTs, The ALT_CLK_L4_SP clock needs to be setup before initialization.
Parameters
deviceThe UART device identifier.
locationThe memory of the location for the given UART. For SoCFPGA UARTs, this parameter is ignored.
clock_freqThe clock frequency of the serial clock for the given UART. For SoCFPGA UARTs, this paramter is ignored.
handle[out] A pointer to a handle that will represent the UART. This handle should subsequently be used when calling other UART APIs.
Return values
ALT_E_BAD_ARGThe given UART device identifier is invalid.
ALT_E_BAD_CLKThe required clock is not yet setup.
◆ alt_16550_read()
ALT_STATUS_CODE alt_16550_read ( ALT_16550_HANDLE_t handle,
char *  item
Reads a single character from the UART receiver buffer. This API should only be used when FIFOs are disabled.
Parameters
item[out] Pointer to an output parameter that contains the in receiver buffer of the UART.
Return values
◆ alt_16550_reset()
ALT_STATUS_CODE alt_16550_reset ( ALT_16550_HANDLE_t handle)
Resets the UART to the default configuration. The UART will be reset and reinitialized.
Parameters
Return values
◆ alt_16550_uninit()
ALT_STATUS_CODE alt_16550_uninit ( ALT_16550_HANDLE_t handle)
Performs the uninitialization steps for the UART. This should be the last API call made to cleanup the UART.
After calling this function, the handle will need to be initialized again before being used by calling alt_16550_init().
Parameters
Return values
◆ alt_16550_write()
ALT_STATUS_CODE alt_16550_write ( ALT_16550_HANDLE_t handle,
char  item
Writes a single character to the UART transmitter buffer. This API should only be used when FIFOs are disabled.
Parameters
itemThe character to write to the transmitter buffer of the UART.
Return values
