RTEMS 6.1-rc2
#define | ALT_E_SUCCESS 0 |
#define | ALT_E_ERROR (-1) |
#define | ALT_E_FPGA_CFG (-2) |
#define | ALT_E_FPGA_CRC (-3) |
#define | ALT_E_FPGA_CFG_STM (-4) |
#define | ALT_E_FPGA_PWR_OFF (-5) |
#define | ALT_E_FPGA_NO_SOC_CTRL (-6) |
#define | ALT_E_FPGA_NOT_USER_MODE (-7) |
#define | ALT_E_ARG_RANGE (-8) |
#define | ALT_E_BAD_ARG (-9) |
#define | ALT_E_BAD_OPERATION (-10) |
#define | ALT_E_INV_OPTION (-11) |
#define | ALT_E_TMO (-12) |
#define | ALT_E_RESERVED (-13) |
#define | ALT_E_BAD_CLK (-14) |
#define | ALT_E_BAD_VERSION (-15) |
#define | ALT_E_BUF_OVF (-20) |
#define | ALT_E_FALSE (0) |
#define | ALT_E_TRUE (1) |
#define | ALT_HWLIBS_VERSION(a, b, c) (((a)*10000)+((b)*100)+(c)) |
#define | ALTERA_HWLIBS_VERSION_CODE |
#define | ALTERA_INTERNAL_ONLY_DOCS 1 |
#define | ALT_HPS_ADDR 0 |
#define | ALT_MILLISECS_IN_A_SEC 1000 |
#define | ALT_MICROSECS_IN_A_SEC 1000000 |
#define | ALT_NANOSECS_IN_A_SEC 1000000000 |
#define | ALT_TWO_TO_POW0 (1) |
#define | ALT_TWO_TO_POW1 (1<<1) |
#define | ALT_TWO_TO_POW2 (1<<2) |
#define | ALT_TWO_TO_POW3 (1<<3) |
#define | ALT_TWO_TO_POW4 (1<<4) |
#define | ALT_TWO_TO_POW5 (1<<5) |
#define | ALT_TWO_TO_POW6 (1<<6) |
#define | ALT_TWO_TO_POW7 (1<<7) |
#define | ALT_TWO_TO_POW8 (1<<8) |
#define | ALT_TWO_TO_POW9 (1<<9) |
#define | ALT_TWO_TO_POW10 (1<<10) |
#define | ALT_TWO_TO_POW11 (1<<11) |
#define | ALT_TWO_TO_POW12 (1<<12) |
#define | ALT_TWO_TO_POW13 (1<<13) |
#define | ALT_TWO_TO_POW14 (1<<14) |
#define | ALT_TWO_TO_POW15 (1<<15) |
#define | ALT_TWO_TO_POW16 (1<<16) |
#define | ALT_TWO_TO_POW17 (1<<17) |
#define | ALT_TWO_TO_POW18 (1<<18) |
#define | ALT_TWO_TO_POW19 (1<<19) |
#define | ALT_TWO_TO_POW20 (1<<20) |
#define | ALT_TWO_TO_POW21 (1<<21) |
#define | ALT_TWO_TO_POW22 (1<<22) |
#define | ALT_TWO_TO_POW23 (1<<23) |
#define | ALT_TWO_TO_POW24 (1<<24) |
#define | ALT_TWO_TO_POW25 (1<<25) |
#define | ALT_TWO_TO_POW26 (1<<26) |
#define | ALT_TWO_TO_POW27 (1<<27) |
#define | ALT_TWO_TO_POW28 (1<<28) |
#define | ALT_TWO_TO_POW29 (1<<29) |
#define | ALT_TWO_TO_POW30 (1<<30) |
#define | ALT_TWO_TO_POW31 (1<<31) |
Typedefs | |
typedef int32_t | ALT_STATUS_CODE |
#define ALT_E_ARG_RANGE (-8) |
An argument violates a range constraint.
#define ALT_E_BAD_ARG (-9) |
A bad argument value was passed.
#define ALT_E_BAD_CLK (-14) |
A clock is not enabled or violates an operational constraint.
#define ALT_E_BAD_OPERATION (-10) |
The operation is invalid or illegal.
#define ALT_E_BAD_VERSION (-15) |
The version ID is invalid.
#define ALT_E_BUF_OVF (-20) |
The buffer does not contain enough free space for the operation.
#define ALT_E_ERROR (-1) |
The operation failed.
#define ALT_E_FALSE (0) |
Indicates a FALSE condition.
#define ALT_E_FPGA_CFG (-2) |
FPGA configuration error detected.
#define ALT_E_FPGA_CFG_STM (-4) |
An error occurred on the FPGA configuration bitstream input source.
#define ALT_E_FPGA_CRC (-3) |
FPGA CRC error detected.
#define ALT_E_FPGA_NO_SOC_CTRL (-6) |
The SoC does not currently control the FPGA.
#define ALT_E_FPGA_NOT_USER_MODE (-7) |
The FPGA is not in USER mode.
#define ALT_E_FPGA_PWR_OFF (-5) |
The FPGA is powered off.
#define ALT_E_INV_OPTION (-11) |
An invalid option was selected.
#define ALT_E_RESERVED (-13) |
The argument value is reserved or unavailable.
#define ALT_E_SUCCESS 0 |
Definitions of status codes returned by the HWLIB.
The operation was successful.
#define ALT_E_TMO (-12) |
An operation or response timeout period expired.
#define ALT_E_TRUE (1) |
Indicates a TRUE condition.
#define ALT_HPS_ADDR 0 |
Provide base address of MPU address space
#define ALT_HWLIBS_VERSION | ( | a, | |
b, | |||
c | |||
) | (((a)*10000)+((b)*100)+(c)) |
Specifies the current major and minor revision of the HWLibs. The MS four decimal digits specify the Altera ACDS release number, the LS two decimal digits specify minor revisions of the HWLibs, if any.
A typical use is:
for a dependency on the major or minor ACDS revision or
for a dependency on the hwlibs revision
#define ALT_MILLISECS_IN_A_SEC 1000 |
These constants are sometimes useful:
#define ALTERA_HWLIBS_VERSION_CODE |
#define ALTERA_INTERNAL_ONLY_DOCS 1 |
Allow some parts of the documentation to be hidden by setting to zero
typedef int32_t ALT_STATUS_CODE |
The type definition for status codes returned by the HWLIB.
