RTEMS 6.1-rc2
This group contains the SMP lock implementation. More...
Files | |
file | smplock.h |
This header file provides the main interfaces of the SMP Locks. | |
file | smplockmcs.h |
This header file provides the interfaces of the SMP Locks related to MCS locks. | |
file | smplockseq.h |
This header file provides the interfaces of the SMP Locks related to sequence locks. | |
file | smplockstats.h |
This header file provides the interfaces of the SMP Locks related to lock statistics. | |
file | smplockticket.h |
This header file provides the interfaces of the SMP Locks related to ticket locks. | |
file | profilingsmplock.c |
This source file contains the implementation of _SMP_lock_Stats_destroy(), _SMP_lock_Stats_register_or_max_section_time(), _SMP_lock_Stats_iteration_start(), _SMP_lock_Stats_iteration_next(), and _SMP_lock_Stats_iteration_stop(). | |
file | smplock.c |
This source file contains the implementation of _SMP_lock_Initialize(), _SMP_lock_Destroy(), _SMP_lock_Acquire(), _SMP_lock_Release(), _SMP_lock_ISR_disable_and_acquire(), _SMP_lock_Release_and_ISR_enable(), and _SMP_lock_Is_owner(). | |
The SMP lock provides mutual exclusion in SMP systems at the lowest level.
The SMP lock is implemented as a ticket lock. This provides fairness in case of concurrent lock attempts.
This SMP lock API uses a local context for acquire and release pairs. Such a context may be used to implement for example the Mellor-Crummey and Scott (MCS) locks in the future.
