RTEMS 6.1-rc2
Files | Functions
Profiling Support
This group contains the implementation to support profiling. More...
file  profiling.h
 This header file provides the interfaces of the Profiling Support.
file  profilingisrentryexit.c
 This source file contains the implementation of _Profiling_Outer_most_interrupt_entry_and_exit().
void _Profiling_Outer_most_interrupt_entry_and_exit (Per_CPU_Control *cpu, CPU_Counter_ticks interrupt_entry_instant, CPU_Counter_ticks interrupt_exit_instant)
 Updates the interrupt profiling statistics.
◆ _Profiling_Outer_most_interrupt_entry_and_exit()
void _Profiling_Outer_most_interrupt_entry_and_exit ( Per_CPU_Control cpu,
Must be called with the interrupt stack and before the thread dispatch disable level is decremented.
Parameters
cpuThe cpu control.
interrupt_entry_instantThe instant that the interrupt occurred.
interrupt_exit_instantThe instant in which the interrupt was exited.
