RTEMS 6.1-rc2
Files | Macros | Typedefs
Atomic Operations
This group contains the atomic operations implementation. More...
file  atomic.h
 This header file provides the interfaces of the Atomic Operations.
file  libatomic.c
 This source file contains the implementation of _Libatomic_Protect_start() and _Libatomic_Protect_end().
#define ATOMIC_ORDER_RELAXED   0
#define ATOMIC_ORDER_ACQUIRE   2
#define ATOMIC_ORDER_RELEASE   3
#define ATOMIC_ORDER_ACQ_REL   4
#define ATOMIC_ORDER_SEQ_CST   5
#define ATOMIC_INITIALIZER_UINT(value)   ( value )
#define ATOMIC_INITIALIZER_ULONG(value)   ( value )
#define ATOMIC_INITIALIZER_UINTPTR(value)   ( value )
#define ATOMIC_INITIALIZER_FLAG   false
typedef unsigned int Atomic_Uint
typedef unsigned long Atomic_Ulong
typedef uintptr_t Atomic_Uintptr
typedef bool Atomic_Flag
typedef int Atomic_Order
Atomic operations can be used to implement low-level synchronization primitives on SMP systems, like spin locks. All atomic operations are defined in terms of C11 (ISO/IEC 9899:2011) or C++11 (ISO/IEC 14882:2011). For documentation use the standard documents.
