RTEMS 6.1-rc2
Files | Functions
This group contains the gocv support. More...
file  test-gcov.h
 This header file provides the interfaces of the Gcov Support.
file  gcovdumpinfo.c
 This source file contains the implementation of _Gcov_Ddump_info().
file  gcovdumpinfobase64.c
 This source file contains the implementation of _Gcov_Dump_info_base64().
file  gcovinfoset.c
 This source file contains the definition of the gcov information linker set.
 RTEMS_LINKER_ROSET_DECLARE (gcov_info, const struct gcov_info *)
void _Gcov_Dump_info (IO_Put_char put_char, void *arg)
 Dumps the gcov information as a binary gcfn and gcda data stream using the put character handler.
void _Gcov_Dump_info_base64 (IO_Put_char put_char, void *arg)
 Dumps the gcov information as a base64 encoded gcfn and gcda data stream using the put character handler.
◆ _Gcov_Dump_info()
void _Gcov_Dump_info ( IO_Put_char  put_char,
void *  arg
Parameters
put_charis the put character handler used to output the data stream.
argis the argument passed to the put character handler.
◆ _Gcov_Dump_info_base64()
void _Gcov_Dump_info_base64 ( IO_Put_char  put_char,
void *  arg
Parameters
