RTEMS 6.1-rc2
Files | Enumerations | Functions
Clock Manager
This group contains the Clock Manager implementation. More...
file  clock.h
 This header file defines the Clock Manager API.
file  clockimpl.h
 This header file provides the implementation interfaces of the Clock Manager.
file  clockgetsecondssinceepoch.c
 This source file contains the implementation of rtems_clock_get_seconds_since_epoch().
file  clockgettickspersecond.c
 This source file contains the implementation of rtems_clock_get_ticks_per_second().
file  clockgettickssinceboot.c
 This source file contains the implementation of rtems_clock_get_ticks_since_boot().
file  clockgettod.c
 This source file contains the implementation of rtems_clock_get_tod().
file  clockgettodtimeval.c
 This source file contains the implementation of rtems_clock_get_tod_timeval().
file  clockgetuptime.c
 This source file contains the implementation of rtems_clock_get_uptime().
file  clockgetuptimenanoseconds.c
 This source file contains the implementation of rtems_clock_get_uptime_nanoseconds().
file  clockgetuptimeseconds.c
 This source file contains the implementation of rtems_clock_get_uptime_seconds().
file  clockgetuptimetimeval.c
 This source file contains the implementation of rtems_clock_get_uptime_timeval().
file  clockset.c
 This source file contains the implementation of rtems_clock_set().
file  clocktick.c
 This source file contains the implementation of rtems_clock_tick().
file  clocktodtoseconds.c
 This source file contains the implementation of _TOD_To_seconds().
file  clocktodvalidate.c
 This source file contains the implementation of _TOD_Validate().
enum  TOD_Ticks_validation { TOD_DISABLE_TICKS_VALIDATION = 0 , TOD_ENABLE_TICKS_VALIDATION = -1 }
 The enumerators of this type determine if the ticks member is validated in _TOD_Validate(). More...
rtems_status_code _TOD_Validate (const rtems_time_of_day *the_tod, TOD_Ticks_validation ticks_validation)
 Validates the time of day.
Watchdog_Interval _TOD_To_seconds (const rtems_time_of_day *the_tod)
 TOD to Seconds.
◆ TOD_Ticks_validation
Use this option to disable the validation of the ticks member in _TOD_Validate().
Use this option to enable the validation of the ticks member in _TOD_Validate().
◆ _TOD_To_seconds()
Watchdog_Interval _TOD_To_seconds ( const rtems_time_of_day the_tod)
TOD to Seconds.
This function returns the number seconds between the epoch and the_tod.
Parameters
[in]the_todis the TOD structure to convert to seconds
Return values
Thismethod returns the number of seconds since epoch represented by the_tod
◆ _TOD_Validate()
rtems_status_code _TOD_Validate ( const rtems_time_of_day the_tod,
Parameters
the_todis the reference to the time of day structure to validate or NULL.
ticks_validationindicates if the ticks member of the time of day should be validated. Use TOD_ENABLE_TICKS_VALIDATION to validate the ticks member. Use TOD_DISABLE_TICKS_VALIDATION to skip the validation of the ticks member.
Return values
RTEMS_SUCCESSFULthe_tod references a valid time of day.
RTEMS_INVALID_CLOCKthe_tod references an invalid time of day.
RTEMS_INVALID_ADDRESSthe_tod reference is NULL.
