RTEMS 6.1-rc2
Files | Data Structures | Macros | Typedefs | Functions | Variables
uC5282 Board Support Package. More...
file  bsp.h
 Global BSP definitions.
struct  bsp_mnode_t
struct  mcf5282BufferDescriptor_
#define RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "fs1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_fec_driver_attach
#define CONSOLE_PORT   0
#define RTEMS_BSP_PGM_ERASE_FIRST   0x1
#define RTEMS_BSP_PGM_RESET_AFTER   0x2
#define RTEMS_BSP_PGM_EXEC_AFTER   0x4
#define RTEMS_BSP_PGM_HALT_AFTER   0x8
#define FEC_IRQ_LEVEL   4
#define FEC_IRQ_RX_PRIORITY   7
#define FEC_IRQ_TX_PRIORITY   6
#define PIT3_IRQ_LEVEL   4
#define PIT3_IRQ_PRIORITY   0
#define UART0_IRQ_LEVEL   3
#define UART0_IRQ_PRIORITY   7
#define UART1_IRQ_LEVEL   3
#define UART1_IRQ_PRIORITY   6
#define UART2_IRQ_LEVEL   3
#define UART2_IRQ_PRIORITY   5
#define VME_AM_STD_SUP_ASCENDING   0x3f
#define VME_AM_STD_SUP_PGM   0x3e
#define VME_AM_STD_USR_ASCENDING   0x3b
#define VME_AM_STD_USR_PGM   0x3a
#define VME_AM_STD_SUP_DATA   0x3d
#define VME_AM_STD_USR_DATA   0x39
#define VME_AM_EXT_SUP_ASCENDING   0x0f
#define VME_AM_EXT_SUP_PGM   0x0e
#define VME_AM_EXT_USR_ASCENDING   0x0b
#define VME_AM_EXT_USR_PGM   0x0a
#define VME_AM_EXT_SUP_DATA   0x0d
#define VME_AM_EXT_USR_DATA   0x09
#define VME_AM_SUP_SHORT_IO   0x2d
#define VME_AM_USR_SHORT_IO   0x29
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
typedef void(* BSP_VME_ISR_t) (void *usrArg, unsigned long vector)
typedef struct mcf5282BufferDescriptor_ mcf5282BufferDescriptor_t
int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
uint32_t bsp_get_CPU_clock_speed (void)
rtems_status_code bsp_allocate_interrupt (int level, int priority)
int bsp_sysReset (int flags)
int bsp_program (bsp_mnode_t *chain, int flags)
unsigned const char * bsp_gethwaddr (int a)
const char * bsp_getbenv (const char *a)
int bsp_flash_erase_range (volatile unsigned short *flashptr, int start, int end)
int bsp_flash_write_range (volatile unsigned short *flashptr, bsp_mnode_t *chain, int offset)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
rtems_status_code bspExtInit (void)
BSP_VME_ISR_t BSP_getVME_isr (unsigned long vector, void **parg)
int BSP_installVME_isr (unsigned long vector, BSP_VME_ISR_t handler, void *usrArg)
int BSP_removeVME_isr (unsigned long vector, BSP_VME_ISR_t handler, void *usrArg)
int BSP_enableVME_int_lvl (unsigned int level)
int BSP_disableVME_int_lvl (unsigned int level)
int BSP_vme2local_adrs (unsigned am, unsigned long vmeaddr, unsigned long *plocaladdr)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
int bsp_cpu_load_percentage (void)
void bsp_reset_cause (char *buf, size_t capacity)
struct {
   uint32_t   idle_counter
   uint32_t   filtered_idle
   uint32_t   max_idle_count
   uint32_t   pitc_per_tick
   uint32_t   nsec_per_pitc
   uint32_t   pad [3]
   mcf5282BufferDescriptor_t   fec_descriptors []
__SRAMBASE
◆ CONSOLE_PORT
User Definable configuration
◆ RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
BSP Configuration
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
