RTEMS 6.1-rc2
Data Structures | Macros | Typedefs | Enumerations
gpio-defs.h File Reference
API definitions of the GPIO driver for the lpc176x bsp in RTEMS. More...
#include <bsp/common-types.h>
struct  lpc176x_interrupt_control
 GPIO Interrupt register map. More...
struct  lpc176x_registered_interrupt_function
 A registered interrupt function for the pin 'pin'. More...
#define LPC176X_GPIO_BASE_ADDR   0x40028000U
#define LPC176X_GPIO_INTERRUPT_STATUS   0x40028080U
#define LPC176X_IOPIN0
#define LPC176X_IOSET0
#define LPC176X_IODIR0
#define LPC176X_IOCLR0
#define LPC176X_IOPIN1
#define LPC176X_IOSET1
#define LPC176X_IODIR1
#define LPC176X_IOCLR1
#define LPC176X_IO0_INT_EN_R
#define LPC176X_IO0_INT_EN_F
#define LPC176X_IO0_INT_STAT_R
#define LPC176X_IO0_INT_STAT_F
#define LPC176X_IO0_INT_CLR
#define LPC176X_IO2_INT_EN_R
#define LPC176X_IO2_INT_EN_F
#define LPC176X_IO2_INT_STAT_R
#define LPC176X_IO2_INT_STAT_F
#define LPC176X_IO2_INT_CLR
#define LPC176X_IO_INT_STAT
#define LPC176X_RESERVED_ISR_FUNCT_SIZE   2U
#define LPC176X_RESERVED_ISR_FUNCT_MAX_SIZE   5U
#define LPC176X_MAX_PORT_NUMBER   160U
#define LPC176X_SET_BIT(reg, pin, value)    reg = ( reg & ~( 1U << pin ) ) | ( ( value & 1U ) << pin )
#define LPC176X_INT_STATUS
#define LPC176X_INT_STATUS_P0   1U
#define LPC176X_INT_STATUS_P2   ( 1U << 2U )
#define LPC176X_INT_ENABLE   1U
#define LPC176X_INT_DISABLE   0U
#define LPC176X_IRQ_EINT_3   21U
#define LPC176X_PIN_BIT(pin)   ( 1U << pin )
typedef void(* lpc176x_gpio_interrupt_function) (const lpc176x_pin_number pin, const lpc176x_gpio_interrupt edge)
 A function that attends an interrupt for GPIO.
enum  lpc176x_gpio_direction { LPC176X_GPIO_FUNCTION_INPUT , LPC176X_GPIO_FUNCTION_OUTPUT , LPC176X_GPIO_FUNCTION_COUNT }
 The direction of the GPIO port (input or output). More...
enum  lpc176x_gpio_interrupt {
  LPC176X_GPIO_INTERRUPT_DISABLE , LPC176X_GPIO_INTERRUPT_RISING , LPC176X_GPIO_INTERRUPT_FALLING , LPC176X_GPIO_INTERRUPT_BOTH ,
  LPC176X_GPIO_INTERRUPT_COUNT
 The interrupt sources edge for a GPIO. More...
enum  lpc176x_gpio_ports {
  LPC176X_GPIO_PORT_0 , LPC176X_GPIO_PORT_1 , LPC176X_GPIO_PORT_2 , LPC176X_GPIO_PORT_3 ,
  LPC176X_GPIO_PORT_4 , LPC176X_GPIO_PORTS_COUNT
 The ports for a GPIO. More...
enum  lpc176x_gpio_address {
  LPC176X_FIO0_BASE_ADDRESS = 0x2009C000U , LPC176X_FIO1_BASE_ADDRESS = 0x2009C020U , LPC176X_FIO2_BASE_ADDRESS = 0x2009C040U , LPC176X_FIO3_BASE_ADDRESS = 0x2009C060U ,
  LPC176X_FIO4_BASE_ADDRESS = 0x2009C080U
 Addresses for a GPIO. More...
enum  lpc176x_interrupt_address { LPC176X_IO0_INT_BASE_ADDRESS = 0x40028084U , LPC176X_IO2_INT_BASE_ADDRESS = 0x400280A4U }
 Addresses for the two interrupts. More...
◆ LPC176X_INT_STATUS
Value:
( *(volatile uint32_t *) \
( LPC176X_GPIO_INTERRUPT_STATUS ) )
◆ LPC176X_IO0_INT_CLR
Value:
( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR \
+ 0x8CU ) )
◆ LPC176X_IO0_INT_EN_F
Value:
+ 0x94U ) )
◆ LPC176X_IO0_INT_EN_R
Value:
+ 0x90U ) )
◆ LPC176X_IO0_INT_STAT_F
Value:
( *(volatile uint32_t *) ( \
+ 0x88U ) )
◆ LPC176X_IO0_INT_STAT_R
Value:
+ 0x84U ) )
◆ LPC176X_IO2_INT_CLR
Value:
+ 0xACU ) )
◆ LPC176X_IO2_INT_EN_F
Value:
+ 0xB4U ) )
◆ LPC176X_IO2_INT_EN_R
Value:
+ 0xB0U ) )
◆ LPC176X_IO2_INT_STAT_F
Value:
+ 0xA8U ) )
◆ LPC176X_IO2_INT_STAT_R
Value:
+ 0xA4U ) )
◆ LPC176X_IO_INT_STAT
Value:
+ 0x80U ) )
◆ LPC176X_IOCLR0
Value:
( *(volatile uint32_t *) ( LPC176X_GPIO_BASE_ADDR + \
0x0CU ) )
◆ LPC176X_IOCLR1
Value:
0x1CU ) )
◆ LPC176X_IODIR0
Value:
0x08U ) )
◆ LPC176X_IODIR1
Value:
0x18U ) )
◆ LPC176X_IOPIN0
Value:
0x00U ) )
◆ LPC176X_IOPIN1
Value:
0x10U ) )
◆ LPC176X_IOSET0
Value:
0x04U ) )
◆ LPC176X_IOSET1
Value:
0x14U ) )
Typedef Documentation
◆ lpc176x_gpio_interrupt_function
Parameters
pinPin number.
edgeInterrupt.
Returns
Pointer to the interrupt function.
◆ lpc176x_gpio_address
Enumerated type to define the set of fio bases addresses for a gpio device.
◆ lpc176x_gpio_direction
Enumerated type to define the set of function types for a gpio device.
Enumerated type to define the set of interrupt types for a gpio device.
◆ lpc176x_gpio_ports
Enumerated type to define the set of ports for a gpio device.
◆ lpc176x_interrupt_address
Enumerated type to define the set of interrupt addresses for a gpio device.
