RTEMS provides a collection of services to assist in the management and usage of the objects created and utilized via other managers. These services assist in the manipulation of RTEMS objects independent of the API used to create them.
More...
#define | rtems_object_id_api_minimum(void) OBJECTS_INTERNAL_API |
| Gets the lowest valid value for the API component of an object identifier.
#define | rtems_object_id_api_maximum(void) OBJECTS_APIS_LAST |
| Gets the highest valid value for the API component of an object identifier.
#define | RTEMS_OBJECT_ID_FINAL OBJECTS_ID_FINAL |
| This constant represents the highest object identifier value.
#define | RTEMS_OBJECT_ID_FINAL_INDEX OBJECTS_ID_FINAL_INDEX |
| This constant represents the highest value for the index component of an object identifier.
#define | RTEMS_OBJECT_ID_INITIAL(_api, _class, _node) OBJECTS_ID_INITIAL( _api, _class, _node ) |
| Builds the object identifier with the lowest index from the API, class, and MPCI node components.
#define | RTEMS_OBJECT_ID_INITIAL_INDEX OBJECTS_ID_INITIAL_INDEX |
| This constant represents the lowest value for the index component of an object identifier.
#define | RTEMS_SEARCH_ALL_NODES OBJECTS_SEARCH_ALL_NODES |
| This constant indicates that an object name to identifier search should search through all MPCI nodes of the system.
#define | RTEMS_SEARCH_LOCAL_NODE OBJECTS_SEARCH_LOCAL_NODE |
| This constant indicates that an object name to identifier search should search only the local MPCI node of the system.
#define | RTEMS_SEARCH_OTHER_NODES OBJECTS_SEARCH_OTHER_NODES |
| This constant indicates that an object name to identifier search should search through all MPCI nodes of the system except the local node.
#define | RTEMS_WHO_AM_I OBJECTS_WHO_AM_I |
| This constant indicates that an object name to identifier search is being asked for the identifier of the currently executing task.
rtems_id | rtems_build_id (uint32_t api, uint32_t the_class, uint32_t node, uint32_t index) |
| Builds the object identifier from the API, class, MPCI node, and index components.
rtems_name | rtems_build_name (char c1, char c2, char c3, char c4) |
| Builds the object name composed of the four characters.
rtems_status_code | rtems_object_get_classic_name (rtems_id id, rtems_name *name) |
| Gets the object name associated with the object identifier.
char * | rtems_object_get_name (rtems_id id, size_t length, char *name) |
| Gets the object name associated with the object identifier as a string.
rtems_status_code | rtems_object_set_name (rtems_id id, const char *name) |
| Sets the object name of the object associated with the object identifier.
int | rtems_object_id_get_api (rtems_id id) |
| Gets the API component of the object identifier.
int | rtems_object_id_get_class (rtems_id id) |
| Gets the class component of the object identifier.
int | rtems_object_id_get_node (rtems_id id) |
| Gets the MPCI node component of the object identifier.
int | rtems_object_id_get_index (rtems_id id) |
| Gets the index component of the object identifier.
int | rtems_object_api_minimum_class (int api) |
| Gets the lowest valid class value of the object API.
int | rtems_object_api_maximum_class (int api) |
| Gets the highest valid class value of the object API.
const char * | rtems_object_get_api_name (int api) |
| Gets a descriptive name of the object API.
const char * | rtems_object_get_api_class_name (int the_api, int the_class) |
| Gets a descriptive name of the object class of the object API.
rtems_status_code | rtems_object_get_class_information (int the_api, int the_class, rtems_object_api_class_information *info) |
| Gets the object class information of the object class of the object API.
◆ rtems_object_id_api_maximum
- Returns
- Returns the highest valid value for the API component of an object identifier.
- Constraints
The following constraints apply to this directive:
- The directive is implemented by a macro and may be called from within C/C++ constant expressions. In addition, a function implementation of the directive exists for bindings to other programming languages.
- The directive will not cause the calling task to be preempted.
◆ rtems_object_id_api_minimum
int rtems_object_id_api_minimum |
void | ) |
- Returns
- Returns the lowest valid value for the API component of an object identifier.
- Constraints
◆ RTEMS_OBJECT_ID_INITIAL
#define RTEMS_OBJECT_ID_INITIAL |
_api, |
_class, |
_node |
- Parameters
_api | is the API of the object identifier to build. |
_class | is the class of the object identifier to build. |
_node | is the MPCI node of the object identifier to build. |
- Returns
- Returns the object identifier with the lowest index built from the API, class, and MPCI node components.
- Constraints
- The directive may be called from within any runtime context.
◆ rtems_build_id()
rtems_id rtems_build_id |
uint32_t |
api, |
uint32_t |
the_class, |
uint32_t |
node, |
uint32_t |
index |
- Parameters
the_class | is the class of the object identifier to build. |
index | is the index of the object identifier to build. |
- Returns
- Returns the object identifier built from the API, class, MPCI node, and index components.
- Constraints
◆ rtems_build_name()
rtems_name rtems_build_name |
char |
c1, |
char |
c2, |
char |
c3, |
char |
c4 |
- Parameters
c1 | is the first character of the name. |
c2 | is the second character of the name. |
c3 | is the third character of the name. |
c4 | is the fourth character of the name. |
This directive takes the four characters provided as arguments and composes a 32-bit object name with c1
in the most significant 8-bits and c4
in the least significant 8-bits.
- Returns
- Returns the object name composed of the four characters.
- Constraints
◆ rtems_object_api_maximum_class()
int rtems_object_api_maximum_class |
int |
api | ) |
- Parameters
api | is the object API to get the highest valid class value. |
- Return values
0 | The object API was invalid. |
- Returns
- Returns the highest valid class value of the object API.
- Constraints
◆ rtems_object_api_minimum_class()
int rtems_object_api_minimum_class |
int |
api | ) |
- Parameters
api | is the object API to get the lowest valid class value. |
- Return values
-1 | The object API was invalid. |
- Returns
- Returns the lowest valid class value of the object API.
- Constraints
◆ rtems_object_get_api_class_name()
const char * rtems_object_get_api_class_name |
int |
the_api, |
int |
the_class |
- Parameters
the_api | is the object API of the object class. |
the_class | is the object class of the object API to get the name. |
- Return values
BAD API | The API was invalid. |
BAD CLASS | The class of the API was invalid. |
- Returns
- Returns a descriptive name of the class of the API, if the class of the API and the API were valid.
- Notes
- The string returned is from constant space. Do not modify or free it.
- Constraints
◆ rtems_object_get_api_name()
const char * rtems_object_get_api_name |
int |
api | ) |
- Parameters
api | is the object API to get the name. |
- Return values
- Returns
- Returns a descriptive name of the API, if the API was valid.
- Notes
- Constraints
◆ rtems_object_get_class_information()
- Parameters
| the_class | is the object class of the object API to get the class information. |
[out] | info | is the pointer to an rtems_object_api_class_information object. When the directive call is successful, the object class information of the class of the API will be stored in this object. |
- Return values
- Constraints
◆ rtems_object_get_classic_name()
- Parameters
| id | is the object identifier to get the name. |
[out] | name | is the pointer to an rtems_name object. When the directive call is successful, the object name associated with the object identifier will be stored in this object. |
- Return values
- Constraints
◆ rtems_object_get_name()
char * rtems_object_get_name |
rtems_id |
id, |
size_t |
length, |
char * |
name |
- Parameters
| length | is the buffer length in bytes. |
[out] | name | is the pointer to a buffer of the specified length. |
The object name is stored in the name buffer. If the name buffer length is greater than zero, then the stored object name will be NUL
terminated. The stored object name may be truncated to fit the length. There is no indication if a truncation occurred. Every attempt is made to return name as a printable string even if the object has the Classic API 32-bit integer style name.
- Return values
NULL | The length parameter was 0. |
NULL | The name parameter was NULL. |
NULL | There was no object information available for the object identifier. |
NULL | There was no object associated with the object identifier. |
- Returns
- Returns the
name
parameter value, if there is an object name associated with the object identifier.
- Constraints
◆ rtems_object_id_get_api()
int rtems_object_id_get_api |
rtems_id |
id | ) |
- Parameters
id | is the object identifier with the API component to get. |
- Returns
- Returns the API component of the object identifier.
- Notes
- This directive does not validate the object identifier provided in
id
- Constraints
◆ rtems_object_id_get_class()
int rtems_object_id_get_class |
rtems_id |
id | ) |
- Parameters
id | is the object identifier with the class component to get. |
- Returns
- Returns the class component of the object identifier.
- Notes
id
- Constraints
◆ rtems_object_id_get_index()
int rtems_object_id_get_index |
rtems_id |
id | ) |
- Parameters
id | is the object identifier with the index component to get. |
- Returns
- Returns the index component of the object identifier.
- Notes
id
- Constraints
◆ rtems_object_id_get_node()
int rtems_object_id_get_node |
rtems_id |
id | ) |
- Parameters
id | is the object identifier with the MPCI node component to get. |
- Returns
- Returns the MPCI node component of the object identifier.
- Notes
id
- Constraints
◆ rtems_object_set_name()
- Parameters
id | is the object identifier of the object to set the name. |
name | is the object name to set. |
This directive will set the object name based upon the user string.
- Return values
- Notes
This directive can be used to set the name of objects which do not have a naming scheme per their API.
If the object specified by id
is of a class that has a string name, this directive will free the existing name to the RTEMS Workspace and allocate enough memory from the RTEMS Workspace to make a copy of the string located at name
is of a class that has a 32-bit integer style name, then the first four characters in name
will be used to construct the name.
- Constraints
- The directive may be called from within device driver initialization context.
- The directive may be called from within task context.
- The directive may obtain and release the object allocator mutex. This may cause the calling task to be preempted.
