RTEMS 6.1-rc2
- r -
- RATE_MONOTONIC_ACTIVE : ratemon.h
- RATE_MONOTONIC_EXPIRED : ratemon.h
- RATE_MONOTONIC_INACTIVE : ratemon.h
- RCC_IRQn : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- RDC_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- READ : xnandpsu_onfi.h
- READ_CACHE_END : xnandpsu_onfi.h
- READ_CACHE_RANDOM : xnandpsu_onfi.h
- READ_CACHE_SEQUENTIAL : xnandpsu_onfi.h
- READ_ID : xnandpsu_onfi.h
- READ_PARAM_PAGE : xnandpsu_onfi.h
- READ_STATUS : xnandpsu_onfi.h
- READ_STATUS_ENHANCED : xnandpsu_onfi.h
- READ_UNIQUE_ID : xnandpsu_onfi.h
- Reserved110_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved115_IRQn : MIMXRT1052.h
- Reserved123_IRQn : MIMXRT1052.h
- Reserved143_IRQn : MIMXRT1052.h
- Reserved144_IRQn : MIMXRT1052.h
- Reserved166_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved167_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved168_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved169_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved170_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved177_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved178_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved179_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved180_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved185_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved186_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved208_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved209_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved210_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved211_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved212_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved213_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved214_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved215_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved232_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved233_IRQn : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved33_IRQn : MIMXRT1166_cm4.h
- Reserved34_IRQn : MIMXRT1166_cm4.h
- Reserved66_IRQn : MIMXRT1166_cm4.h
- Reserved68_IRQn : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- Reserved78_IRQn : MIMXRT1052.h
- Reserved86_IRQn : MIMXRT1052.h
- Reserved87_IRQn : MIMXRT1052.h
- RESET : xnandpsu_onfi.h
- RESET_LUN : xnandpsu_onfi.h
- RNG_IRQn : stm32h723xx.h, stm32h725xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h7a3xx.h, stm32h7a3xxq.h
- RTC_Alarm_IRQn : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- RTC_TAMP_STAMP_CSS_LSE_IRQn : stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- RTC_WKUP_IRQn : stm32h723xx.h, stm32h725xx.h, stm32h730xx.h, stm32h733xx.h, stm32h735xx.h, stm32h742xx.h, stm32h743xx.h, stm32h745xg.h, stm32h745xx.h, stm32h747xg.h, stm32h747xx.h, stm32h750xx.h, stm32h753xx.h, stm32h755xx.h, stm32h757xx.h, stm32h7a3xx.h, stm32h7a3xxq.h, stm32h7b0xx.h, stm32h7b3xx.h, stm32h7b3xxq.h
- RTEMS_ALREADY_SUSPENDED : status.h
- RTEMS_BDBUF_STATE_ACCESS_CACHED : bdbuf.h
- RTEMS_BDBUF_STATE_ACCESS_EMPTY : bdbuf.h
- RTEMS_BDBUF_STATE_ACCESS_MODIFIED : bdbuf.h
- RTEMS_BDBUF_STATE_ACCESS_PURGED : bdbuf.h
- RTEMS_BDBUF_STATE_CACHED : bdbuf.h
- RTEMS_BDBUF_STATE_EMPTY : bdbuf.h
- RTEMS_BDBUF_STATE_FREE : bdbuf.h
- RTEMS_BDBUF_STATE_MODIFIED : bdbuf.h
- RTEMS_BDBUF_STATE_SYNC : bdbuf.h
- RTEMS_BDBUF_STATE_TRANSFER : bdbuf.h
- RTEMS_BDBUF_STATE_TRANSFER_PURGED : bdbuf.h
- RTEMS_BDPART_FORMAT_GPT : bdpart.h
- RTEMS_BDPART_FORMAT_MBR : bdpart.h
- RTEMS_BLKDEV_REQ_READ : blkdev.h
- RTEMS_BLKDEV_REQ_SYNC : blkdev.h
- RTEMS_BLKDEV_REQ_WRITE : blkdev.h
- RTEMS_CALLED_FROM_ISR : status.h
- RTEMS_FATAL_SOURCE_APPLICATION : interr.h
- RTEMS_FATAL_SOURCE_ASSERT : interr.h
- RTEMS_FATAL_SOURCE_BDBUF : interr.h
- RTEMS_FATAL_SOURCE_BSP : interr.h
- RTEMS_FATAL_SOURCE_EXCEPTION : interr.h
- RTEMS_FATAL_SOURCE_EXIT : interr.h
- RTEMS_FATAL_SOURCE_HEAP : interr.h
- RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE : interr.h
- RTEMS_FATAL_SOURCE_LAST : interr.h
- RTEMS_FATAL_SOURCE_PANIC : interr.h
- RTEMS_FATAL_SOURCE_SMP : interr.h
- RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT : interr.h
- RTEMS_FATAL_SOURCE_STACK_CHECKER : interr.h
- RTEMS_FLASHDEV_NAND : flashdev.h
- RTEMS_FLASHDEV_NOR : flashdev.h
- RTEMS_FSTAB_ANY : fsmount.h
- RTEMS_FSTAB_ERROR : fsmount.h
- RTEMS_FSTAB_ERROR_MOUNT : fsmount.h
- RTEMS_FSTAB_ERROR_MOUNT_POINT : fsmount.h
- RTEMS_FSTAB_NONE : fsmount.h
- RTEMS_FSTAB_OK : fsmount.h
- RTEMS_ILLEGAL_ON_REMOTE_OBJECT : status.h
- RTEMS_ILLEGAL_ON_SELF : status.h
- RTEMS_INCORRECT_STATE : status.h
- RTEMS_INTERNAL_ERROR : status.h
- RTEMS_INTERRUPT_NO_SIGNAL : intr.h
- RTEMS_INTERRUPT_SIGNAL_EDGE_FALLING : intr.h
- RTEMS_INTERRUPT_SIGNAL_EDGE_RAISING : intr.h
- RTEMS_INTERRUPT_SIGNAL_LEVEL_HIGH : intr.h
- RTEMS_INTERRUPT_SIGNAL_LEVEL_LOW : intr.h
- RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL : intr.h
- RTEMS_INTERRUPTED : status.h
- RTEMS_INVALID_ADDRESS : status.h
- RTEMS_INVALID_CLOCK : status.h
- RTEMS_INVALID_ID : status.h
- RTEMS_INVALID_NAME : status.h
- RTEMS_INVALID_NODE : status.h
- RTEMS_INVALID_NUMBER : status.h
- RTEMS_INVALID_PRIORITY : status.h
- RTEMS_INVALID_SIZE : status.h
- RTEMS_IO_ERROR : status.h
- RTEMS_MP_NOT_CONFIGURED : status.h
- RTEMS_NO_MEMORY : status.h
- RTEMS_NOT_CONFIGURED : status.h
- RTEMS_NOT_DEFINED : status.h
- RTEMS_NOT_IMPLEMENTED : status.h
- RTEMS_NOT_OWNER_OF_RESOURCE : status.h
- RTEMS_OBJECT_WAS_DELETED : status.h
- RTEMS_PROFILING_PER_CPU : profiling.h
- RTEMS_PROFILING_SMP_LOCK : profiling.h
- RTEMS_PROXY_BLOCKING : status.h
- RTEMS_RESOURCE_IN_USE : status.h
- rtems_rfs_unlink_dir_allowed : rtems-rfs-link.h
- rtems_rfs_unlink_dir_denied : rtems-rfs-link.h
- rtems_rfs_unlink_dir_if_empty : rtems-rfs-link.h
- RTEMS_RTL_ALLOC_DEL : rtl-allocator.h
- RTEMS_RTL_ALLOC_EXTERNAL : rtl-allocator.h
- RTEMS_RTL_ALLOC_LOCK : rtl-allocator.h
- RTEMS_RTL_ALLOC_NEW : rtl-allocator.h
- RTEMS_RTL_ALLOC_OBJECT : rtl-allocator.h
- RTEMS_RTL_ALLOC_READ : rtl-allocator.h
- RTEMS_RTL_ALLOC_READ_EXEC : rtl-allocator.h
- RTEMS_RTL_ALLOC_READ_WRITE : rtl-allocator.h
- RTEMS_RTL_ALLOC_RESIZE : rtl-allocator.h
- RTEMS_RTL_ALLOC_SYMBOL : rtl-allocator.h
- RTEMS_RTL_ALLOC_UNLOCK : rtl-allocator.h
- RTEMS_RTL_ALLOC_WR_DISABLE : rtl-allocator.h
- RTEMS_RTL_ALLOC_WR_ENABLE : rtl-allocator.h
- rtems_rtl_archive_search_error : rtl-archive.h
- rtems_rtl_archive_search_found : rtl-archive.h
- rtems_rtl_archive_search_loaded : rtl-archive.h
- rtems_rtl_archive_search_no_config : rtl-archive.h
- rtems_rtl_archive_search_not_found : rtl-archive.h
- rtems_rtl_elf_rel_failure : rtl-elf.h
- rtems_rtl_elf_rel_no_error : rtl-elf.h
- rtems_rtl_elf_rel_tramp_add : rtl-elf.h
- rtems_rtl_elf_rel_tramp_cache : rtl-elf.h
- rtems_rtl_trampoline_reloc : rtl-unresolved.h
- rtems_rtl_unresolved_empty : rtl-unresolved.h
- rtems_rtl_unresolved_reloc : rtl-unresolved.h
- rtems_rtl_unresolved_symbol : rtl-unresolved.h
- RTEMS_SUCCESSFUL : status.h
- RTEMS_TASK_EXITTED : status.h
- RTEMS_TERMIOS_IPROC_CONTINUE : libio.h
- RTEMS_TERMIOS_IPROC_DONE : libio.h
- RTEMS_TERMIOS_IPROC_INTERRUPT : libio.h
- RTEMS_TIMEOUT : status.h
- RTEMS_TOO_MANY : status.h
- RTEMS_UNSATISFIED : status.h
- RTWDOG3_IRQn : MIMXRT1166_cm7.h
- RTWDOG4_IRQn : MIMXRT1166_cm4.h
- RTWDOG_IRQn : MIMXRT1052.h
