RTEMS 6.1-rc2
Functions | Variables
eirq.c File Reference
This source file contains the implementation of the interrupt controller support. More...
#include <bsp/irq.h>
#include <bsp/irq-generic.h>
#include <bsp/irqimpl.h>
void leon3_ext_irq_init (irqamp *regs)
 Initializes the interrupt controller for the boot processor.
bool bsp_interrupt_is_valid_vector (rtems_vector_number vector)
void bsp_interrupt_facility_initialize (void)
 BSP specific initialization.
rtems_status_code bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes)
 Gets the attributes of the interrupt vector.
rtems_status_code bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending)
 Checks if the interrupt is pending.
rtems_status_code bsp_interrupt_raise (rtems_vector_number vector)
 Causes the interrupt vector.
rtems_status_code bsp_interrupt_clear (rtems_vector_number vector)
 Clears the interrupt vector.
rtems_status_code bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled)
 Checks if the interrupt is enabled.
rtems_status_code bsp_interrupt_vector_enable (rtems_vector_number vector)
 Enables the interrupt vector.
rtems_status_code bsp_interrupt_vector_disable (rtems_vector_number vector)
 Disables the interrupt vector.
uint32_t LEON3_IrqCtrl_EIrq
 This object provides the interrupt number used to multiplex extended interrupts or is zero if no extended interrupts are available.
rtems_interrupt_lock LEON3_IrqCtrl_Lock
 This lock serializes the interrupt controller access.
