RTEMS 6.1-rc2
start Directory Reference
file  bspgetworkarea.c
 This source file contains the powerpc/mpc55xxevb implementation of _Memory_Get().
file  bspreset.c
 BSP reset.
file  bspstart.c
 BSP startup code.
file  edma.c
 Enhanced Direct Memory Access (eDMA).
file  emios.c
 Enhanced Modular Input Output Subsystem (eMIOS).
file  flash_support.c
 MPC55XX flash memory support.
file  get-system-clock.c
 System clock calculation.
file  idle-thread.c
 bsp_idle_thread() implementation.
file  irq.c
 Source file for MPC55XX interrupt support.
file  sd-card-init.c
 SD Card initialization code.
file  siu.c
 System Integration Unit Access (SIU).
file  start-clock.c
 Clock and FMPLL initialization code.
file  start-config-clock.c
 Clock and FMPLL configuration.
file  start-config-ebi-cs-cal.c
 EBI calibration chip-select configuration.
file  start-config-ebi-cs.c
 EBI chip-select configuration.
file  start-config-ebi.c
 EBI configuration.
file  start-config-mmu-early.c
 MMU early configuration.
file  start-config-mmu.c
 MMU configuration.
file  start-config-siu-pcr.c
 SIU PCR configuration.
file  start-early.c
 Early initialization code.
file  start-prologue.c
 Start prologue.
file  start-watchdog.c
 Watchdog initialization code.
