RTEMS 6.1-rc2
Data Structures | Macros | Typedefs | Enumerations | Functions
capture-cli.c File Reference
RTEMS Performance Monitoring and Measurement Framework. More...
#include <ctype.h>
#include <inttypes.h>
#include <rtems/capture-cli.h>
#include <rtems/captureimpl.h>
#include <rtems/monitor.h>
#include <rtems/cpuuse.h>
struct  rtems_capture_cli_triggers
#define RC_UNUSED   RTEMS_UNUSED
#define RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS   (20)
#define RTEMS_CAPTURE_CLI_TRIGGERS_NUM    (sizeof (rtems_capture_cli_trigger) / sizeof (rtems_capture_cli_triggers))
typedef struct rtems_capture_cli_triggers rtems_capture_cli_triggers
typedef enum rtems_capture_cli_trig_state rtems_capture_cli_trig_state
enum  rtems_capture_cli_trig_state { trig_type , trig_to , trig_from_from , trig_from }
rtems_status_code rtems_capture_cli_init (rtems_capture_timestamp timestamp)
This is the Target Interface Command Line Interface. You need start the RTEMS monitor.
◆ rtems_capture_cli_init()
rtems_status_code rtems_capture_cli_init ( rtems_capture_timestamp  timestamp)
This function initialises the command line interface to the capture engine.
