RTEMS 6.1-rc2
afe_dma.h File Reference
#include "chip.h"
struct  AfeCmd
 Spi Transfer Request prepared by the application upper layer. More...
struct  AfeDma
#define AFE_OK   0
#define AFE_ERROR   1
#define AFE_ERROR_LOCK   2
typedef void(* AfeCallback) (uint8_t, void *)
uint32_t Afe_ConfigureDma (AfeDma *pAfed, Afec *pAfeHw, uint8_t AfeId, sXdmad *pXdmad)
 Initializes the AfeDma structure and the corresponding AFE & DMA . hardware select value. The driver will uses DMA channel 0 for RX . The DMA channels are freed automatically when no DMA command processing.
uint32_t Afe_SendData (AfeDma *pAfed, AfeCmd *pCommand)
 Starts a AFE transfer. This is a non blocking function. It will return as soon as the transfer is started.
Purpose
Interface for configuration the Analog-to-Digital Converter (AFEC) peripheral.
Usage
  1. Configurate the pins for AFEC.
  2. Initialize the AFEC with AFEC_Initialize().
  3. Set AFEC clock and timing with AFEC_SetClock() and AFEC_SetTiming().
  4. Select the active channel using AFEC_EnableChannel().
  5. Start the conversion with AFEC_StartConversion().
  6. Wait the end of the conversion by polling status with AFEC_GetStatus().
  7. Finally, get the converted data using AFEC_GetConvertedData() or AFEC_GetLastConvertedData().
Typedef Documentation
◆ AfeCallback
AFE transfer complete callback.
◆ Afe_ConfigureDma()
uint32_t Afe_ConfigureDma ( AfeDma pAfed,
Afec pAfeHw,
uint8_t  AfeId,
sXdmad pXdmad
Parameters
pAfedPointer to a AfeDma instance.
pAfeHwAssociated Afe peripheral.
AfeIdAfe peripheral identifier.
pDmadPointer to a Dmad instance.
◆ Afe_SendData()
uint32_t Afe_SendData ( AfeDma pAfed,
AfeCmd pCommand
Parameters
pCommandPointer to the Afe command to execute.
Returns
0 if the transfer has been started successfully; otherwise returns AFE_ERROR_LOCK is the driver is in use, or AFE_ERROR if the command is not valid.
