RTEMS 6.1-rc2
Macros | Functions
acc.h File Reference
#include "chip.h"
#include <stdint.h>
#include <assert.h>
#define ACC_SELPLUS_AD12B0   0
#define ACC_SELPLUS_AD12B1   1
#define ACC_SELPLUS_AD12B2   2
#define ACC_SELPLUS_AD12B3   3
#define ACC_SELPLUS_AD12B4   4
#define ACC_SELPLUS_AD12B5   5
#define ACC_SELPLUS_AD12B6   6
#define ACC_SELPLUS_AD12B7   7
#define ACC_SELMINUS_TS   0
#define ACC_SELMINUS_ADVREF   1
#define ACC_SELMINUS_DAC0   2
#define ACC_SELMINUS_DAC1   3
#define ACC_SELMINUS_AD12B0   4
#define ACC_SELMINUS_AD12B1   5
#define ACC_SELMINUS_AD12B2   6
#define ACC_SELMINUS_AD12B3   7
#define ACC_CfgModeReg(pAcc, mode)
#define ACC_GetModeReg(pAcc)   ((pAcc)->ACC_MR)
#define ACC_StartConversion(pAcc)   ((pAcc)->ACC_CR = ACC_CR_START)
#define ACC_SoftReset(pAcc)   ((pAcc)->ACC_CR = ACC_CR_SWRST)
#define ACC_EnableChannel(pAcc, dwChannel)
#define ACC_DisableChannel(pAcc, dwChannel)
#define ACC_EnableIt(pAcc, dwMode)
#define ACC_DisableIt(pAcc, dwMode)
#define ACC_EnableDataReadyIt(pAcc)   ((pAcc)->ACC_IER = AT91C_ACC_DRDY)
#define ACC_GetStatus(pAcc)   ((pAcc)->ACC_ISR)
#define ACC_GetChannelStatus(pAcc)   ((pAcc)->ACC_CHSR)
#define ACC_GetInterruptMaskStatus(pAcc)   ((pAcc)->ACC_IMR)
#define ACC_GetLastConvertedData(pAcc)   ((pAcc)->ACC_LCDR)
#define ACC_CfgAnalogCtrlReg(pAcc, dwMode)
#define ACC_CfgExtModeReg(pAcc, extmode)
#define ACC_GetAnalogCtrlReg(pAcc)   ((pAcc)->ACC_ACR)
void ACC_Configure (Acc *pAcc, uint8_t idAcc, uint8_t ucSelplus, uint8_t ucSelminus, uint16_t wAc_en, uint16_t wEdge, uint16_t wInvert)
 Initialize the ACC controller.
void ACC_SetComparisonPair (Acc *pAcc, uint8_t ucSelplus, uint8_t ucSelminus)
uint32_t ACC_GetComparisonResult (Acc *pAcc, uint32_t dwStatus)
Purpose
Interface for configuration the Analog-to-Digital Converter (ACC) peripheral.
Usage
  1. Configurate the pins for ACC
  2. Initialize the ACC with ACC_Initialize().
  3. Select the active channel using ACC_EnableChannel()
  4. Start the conversion with ACC_StartConversion()
  5. Wait the end of the conversion by polling status with ACC_GetStatus()
  6. Finally, get the converted data using ACC_GetConvertedData()
◆ ACC_CfgAnalogCtrlReg
#define ACC_CfgAnalogCtrlReg (   pAcc,
  dwMode
Value:
assert(((dwMode) & 0xFFFCFF3C) == 0);\
(pAcc)->ACC_ACR = (dwMode);\
◆ ACC_CfgExtModeReg
#define ACC_CfgExtModeReg (   pAcc,
  extmode
Value:
assert(((extmode) & 0xFF00FFFE) == 0);\
(pAcc)->ACC_EMR = (extmode);\
◆ ACC_CfgModeReg
#define ACC_CfgModeReg (   pAcc,
  mode
Value:
(pAcc)->ACC_MR = (mode);\
◆ ACC_DisableChannel
#define ACC_DisableChannel (   pAcc,
  dwChannel
Value:
assert(dwChannel < 16);\
(pAcc)->ACC_CHDR = (1 << (dwChannel));\
◆ ACC_DisableIt
#define ACC_DisableIt (   pAcc,
  dwMode
Value:
assert(((dwMode)&0xFFF00000)== 0);\
(pAcc)->ACC_IDR = (dwMode);\
◆ ACC_EnableChannel
#define ACC_EnableChannel (   pAcc,
  dwChannel
Value:
(pAcc)->ACC_CHER = (1 << (dwChannel));\
◆ ACC_EnableIt
#define ACC_EnableIt (   pAcc,
  dwMode
Value:
(pAcc)->ACC_IER = (dwMode);\
◆ ACC_Configure()
void ACC_Configure ( Acc pAcc,
uint8_t  idAcc,
uint8_t  ucSelplus,
uint8_t  ucSelminus,
uint16_t  wAc_en,
uint16_t  wEdge,
uint16_t  wInvert
Parameters
pAccPointer to an Acc instance.
idAccACC identifier
ucSelplusinput connected to inp, 0~7
ucSelminusinput connected to inm,0~7
wAc_enAnalog comparator enabled/disabled
wEdgeCF flag triggering mode
wInvertINVert comparator output,use pattern defined in the device header file
◆ ACC_GetComparisonResult()
uint32_t ACC_GetComparisonResult ( Acc pAcc,
uint32_t  dwStatus
Return Comparison Result
Parameters
dwStatusvalue of ACC_ISR
◆ ACC_SetComparisonPair()
void ACC_SetComparisonPair ( Acc pAcc,
uint8_t  ucSelplus,
uint8_t  ucSelminus
Return the Channel Converted Data
Parameters
ucSelplusinput applied on ACC SELPLUS
ucSelminusinput applied on ACC SELMINUS
