RTEMS 6.1-rc2
acc.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
47#ifndef _ACC_
48#define _ACC_
49
50/*----------------------------------------------------------------------------
51 * Headers
52 *----------------------------------------------------------------------------*/
53#include "chip.h"
54
55#include <stdint.h>
56#include <assert.h>
57
58/*------------------------------------------------------------------------------
59 * Definitions
60 *------------------------------------------------------------------------------*/
61#define ACC_SELPLUS_AD12B0 0
62#define ACC_SELPLUS_AD12B1 1
63#define ACC_SELPLUS_AD12B2 2
64#define ACC_SELPLUS_AD12B3 3
65#define ACC_SELPLUS_AD12B4 4
66#define ACC_SELPLUS_AD12B5 5
67#define ACC_SELPLUS_AD12B6 6
68#define ACC_SELPLUS_AD12B7 7
69#define ACC_SELMINUS_TS 0
70#define ACC_SELMINUS_ADVREF 1
71#define ACC_SELMINUS_DAC0 2
72#define ACC_SELMINUS_DAC1 3
73#define ACC_SELMINUS_AD12B0 4
74#define ACC_SELMINUS_AD12B1 5
75#define ACC_SELMINUS_AD12B2 6
76#define ACC_SELMINUS_AD12B3 7
77
78#ifdef __cplusplus
79extern "C" {
80#endif
81
82/*------------------------------------------------------------------------------
83 * Macros function of register access
84 *------------------------------------------------------------------------------*/
85#define ACC_CfgModeReg(pAcc, mode) { \
86 (pAcc)->ACC_MR = (mode);\
87 }
88
89#define ACC_GetModeReg(pAcc) ((pAcc)->ACC_MR)
90
91#define ACC_StartConversion(pAcc) ((pAcc)->ACC_CR = ACC_CR_START)
92
93#define ACC_SoftReset(pAcc) ((pAcc)->ACC_CR = ACC_CR_SWRST)
94
95#define ACC_EnableChannel(pAcc, dwChannel) {\
96 assert(dwChannel < 16);\
97 (pAcc)->ACC_CHER = (1 << (dwChannel));\
98 }
99
100#define ACC_DisableChannel(pAcc, dwChannel) {\
101 assert(dwChannel < 16);\
102 (pAcc)->ACC_CHDR = (1 << (dwChannel));\
103 }
104
105#define ACC_EnableIt(pAcc, dwMode) {\
106 assert(((dwMode)&0xFFF00000)== 0);\
107 (pAcc)->ACC_IER = (dwMode);\
108 }
109
110#define ACC_DisableIt(pAcc, dwMode) {\
111 assert(((dwMode)&0xFFF00000)== 0);\
112 (pAcc)->ACC_IDR = (dwMode);\
113 }
114
115#define ACC_EnableDataReadyIt(pAcc) ((pAcc)->ACC_IER = AT91C_ACC_DRDY)
116
117#define ACC_GetStatus(pAcc) ((pAcc)->ACC_ISR)
118
119#define ACC_GetChannelStatus(pAcc) ((pAcc)->ACC_CHSR)
120
121#define ACC_GetInterruptMaskStatus(pAcc) ((pAcc)->ACC_IMR)
122
123#define ACC_GetLastConvertedData(pAcc) ((pAcc)->ACC_LCDR)
124
125#define ACC_CfgAnalogCtrlReg(pAcc, dwMode) {\
126 assert(((dwMode) & 0xFFFCFF3C) == 0);\
127 (pAcc)->ACC_ACR = (dwMode);\
128 }
129
130#define ACC_CfgExtModeReg(pAcc, extmode) {\
131 assert(((extmode) & 0xFF00FFFE) == 0);\
132 (pAcc)->ACC_EMR = (extmode);\
133 }
134
135#define ACC_GetAnalogCtrlReg(pAcc) ((pAcc)->ACC_ACR)
136
137/*------------------------------------------------------------------------------
138 * Exported functions
139 *------------------------------------------------------------------------------*/
140extern void ACC_Configure(Acc *pAcc, uint8_t idAcc, uint8_t ucSelplus,
141 uint8_t ucSelminus, uint16_t wAc_en, uint16_t wEdge, uint16_t wInvert);
142
143extern void ACC_SetComparisonPair(Acc *pAcc, uint8_t ucSelplus,
144 uint8_t ucSelminus);
145
146extern uint32_t ACC_GetComparisonResult(Acc *pAcc, uint32_t dwStatus);
147
148#ifdef __cplusplus
149}
150#endif
151
152#endif /* #ifndef _ACC_ */
void ACC_SetComparisonPair(Acc *pAcc, uint8_t ucSelplus, uint8_t ucSelminus)
Definition: acc.c:121
void ACC_Configure(Acc *pAcc, uint8_t idAcc, uint8_t ucSelplus, uint8_t ucSelminus, uint16_t wAc_en, uint16_t wEdge, uint16_t wInvert)
Initialize the ACC controller.
Definition: acc.c:91
Definition: acc.c:141
This header file provides the interfaces of the Assert Handler.
Acc hardware registers.
Definition: component_acc.h:41
