RTEMS 6.1-rc2
This source file contains this BSP's console configuration. More...
#include <rtems/console.h>
#include <rtems/bspIo.h>
#include <rtems/endian.h>
#include <rtems/sysinit.h>
#include <rtems/termiostypes.h>
#include <bsp/aarch64-mmu.h>
#include <bsp/fdt.h>
#include <bsp/irq.h>
#include <dev/serial/zynq-uart.h>
#include <bspopts.h>
#include <libfdt.h>
#include <libchip/ns16550.h>
__attribute__ ((weak)) | |
Zynq UltraScale+ MPSoC specific set up of a management console. | |
RTEMS_SYSINIT_ITEM (zynqmp_management_console_init, RTEMS_SYSINIT_BSP_START, RTEMS_SYSINIT_ORDER_FIRST) | |
rtems_status_code | console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console initialization entry point. | |
void | zynqmp_debug_console_flush (void) |
RTEMS_SYSINIT_ITEM (zynqmp_debug_console_init, RTEMS_SYSINIT_BSP_START, RTEMS_SYSINIT_ORDER_LAST_BUT_5) | |
uint32_t | mgmt_uart_reg_shift = 0 |
BSP_output_char_function_type | BSP_output_char = zynqmp_debug_console_early_init |
This function pointer references the kernel character output implementation. | |
BSP_polling_getchar_function_type | BSP_poll_char = zynqmp_debug_console_in |
This function pointer may reference the kernel character input implementation. | |
rtems_status_code console_initialize | ( | rtems_device_major_number | major, |
rtems_device_minor_number | minor, | ||
void * | arg | ||
This method initializes the console device driver.
[in] | major | is the device driver major number. |
[in] | minor | is the device driver minor number. |
[in] | arg | is the parameters to this call. |
RTEMS_SUCCESSFUL | The device driver is successfully initialized. |
