RTEMS
6.1-rc2
bsps
include
dev
serial
zynq-uart.h
1
7
8
* SPDX-License-Identifier: BSD-2-Clause
9
10
* Copyright (C) 2013, XXX embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef LIBBSP_ARM_XILINX_ZYNQ_UART_H
35
#define LIBBSP_ARM_XILINX_ZYNQ_UART_H
36
37
rtems/termiosdevice.h
38
39
#ifdef __cplusplus
40
extern
"C"
41
#endif
/* __cplusplus */
42
52
typedef
struct
53
rtems_termios_device_context
base;
54
volatile
struct
zynq_uart
*regs;
55
int
tx_queued;
56
bool
transmitting;
57
rtems_vector_number
irq;
58
zynq_uart_context
59
60
extern
const
rtems_termios_device_handler
zynq_uart_handler;
61
62
#define ZYNQ_UART_DEFAULT_BAUD 115200
63
64
void
zynq_uart_initialize(
*base);
65
66
int
zynq_uart_read_polled(
*base);
67
68
void
zynq_uart_write_polled(
69
*base,
70
char
72
76
void
zynq_uart_reset_tx_flush
zynq_uart_context
*ctx);
77
78
int
zynq_cal_baud_rate(
79
uint32_t baudrate,
80
uint32_t* brgr,
81
uint32_t* bauddiv,
82
uint32_t modereg
83
84
85
#ifdef __cplusplus
86
87
#endif
/* __cplusplus */
88
89
#endif
/* LIBBSP_ARM_XILINX_ZYNQ_UART_H */
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition:
intr.h:102
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
zynq_uart_context
Definition:
zynq-uart.h:52
zynq_uart
Definition:
zynq-uart-regs.h:48
termiosdevice.h
This header file provides the interfaces of the RTEMS Termios Device Support.
void zynq_uart_reset_tx_flush(zynq_uart_context *ctx)
Definition:
zynq-uart-polled.c:191
