RTEMS 6.1-rc2
Macros | Functions
aarch64-exception-default.c File Reference
Implementation of _AArch64_Exception_default. More...
#include <rtems/fatal.h>
#include <rtems/score/aarch64-system-registers.h>
#include <rtems/score/cpu.h>
#define AARCH64_INSTRUCTION_SIZE   4
void _AArch64_Exception_default (CPU_Exception_frame *frame)
void _CPU_Exception_disable_thread_dispatch (void)
void _AArch64_Exception_frame_copy (CPU_Exception_frame *new_ef, CPU_Exception_frame *old_ef)
int _CPU_Exception_frame_get_signal (CPU_Exception_frame *ef)
void _CPU_Exception_frame_set_resume (CPU_Exception_frame *ef, void *address)
void _CPU_Exception_frame_make_resume_next_instruction (CPU_Exception_frame *ef)
This file implements _AArch64_Exception_default for use as part of the default exception handling code which dumps all system registers.
