RTEMS 6.1-rc2
aarch32-pmsa.h File Reference
This header file provides the API to manage an Arm PMSAv8-32 based Memory Protection Unit (MPU). More...
struct  AArch32_PMSA_Section
 The section definition is used to initialize the Memory Protection Unit (MPU). More...
struct  AArch32_PMSA_Region
 The region definition is used to configure the Memory Protection Unit (MPU). More...
#define AARCH32_PMSA_MIN_REGION_ALIGN   64
#define AARCH32_PMSA_ATTR_EN   0x1U
#define AARCH32_PMSA_ATTR_IDX_SHIFT   1
#define AARCH32_PMSA_ATTR_IDX_MASK   0xeU
#define AARCH32_PMSA_ATTR_IDX(_idx)    ( ( _idx ) << AARCH32_PMSA_ATTR_IDX_SHIFT )
#define AARCH32_PMSA_ATTR_XN   0x40U
#define AARCH32_PMSA_ATTR_AP_SHIFT   7
#define AARCH32_PMSA_ATTR_AP_MASK   0x18U
#define AARCH32_PMSA_ATTR_AP(_ap)    ( ( _ap ) << AARCH32_PMSA_ATTR_AP_SHIFT )
#define AARCH32_PMSA_ATTR_AP_EL1_RW_EL0_NO   0x0U
#define AARCH32_PMSA_ATTR_AP_EL1_RW_EL0_RW   0x1U
#define AARCH32_PMSA_ATTR_AP_EL1_RO_EL0_NO   0x2U
#define AARCH32_PMSA_ATTR_AP_EL1_RO_EL0_RO   0x3U
#define AARCH32_PMSA_ATTR_SH_SHIFT   9
#define AARCH32_PMSA_ATTR_SH_MASK   0x600U
#define AARCH32_PMSA_ATTR_SH(_sh)    ( ( _sh ) << AARCH32_PMSA_ATTR_SH_SHIFT )
#define AARCH32_PMSA_ATTR_SH_NO   0x0U
#define AARCH32_PMSA_ATTR_SH_RES   0x1U
#define AARCH32_PMSA_ATTR_SH_OUTER   0x2U
#define AARCH32_PMSA_ATTR_SH_INNER   0x3U
#define AARCH32_PMSA_MEM_DEVICE_NG_NR_NE   0x00U
#define AARCH32_PMSA_MEM_DEVICE_NG_NR_E   0x04U
#define AARCH32_PMSA_MEM_DEVICE_NG_R_E   0x08U
#define AARCH32_PMSA_MEM_DEVICE_G_R_E   0x0cU
#define AARCH32_PMSA_MEM_OUTER_WTT   0x00U
#define AARCH32_PMSA_MEM_OUTER_NC   0x40U
#define AARCH32_PMSA_MEM_OUTER_WBT   0x40U
#define AARCH32_PMSA_MEM_OUTER_WTNT   0x80U
#define AARCH32_PMSA_MEM_OUTER_WBNT   0xc0U
#define AARCH32_PMSA_MEM_OUTER_RA   0x20U
#define AARCH32_PMSA_MEM_OUTER_WA   0x10U
#define AARCH32_PMSA_MEM_INNER_WTT   0x00U
#define AARCH32_PMSA_MEM_INNER_NC   0x04U
#define AARCH32_PMSA_MEM_INNER_WBT   0x04U
#define AARCH32_PMSA_MEM_INNER_WTNT   0x08U
#define AARCH32_PMSA_MEM_INNER_WBNT   0x0cU
#define AARCH32_PMSA_MEM_INNER_RA   0x02U
#define AARCH32_PMSA_MEM_INNER_WA   0x01U
#define AARCH32_PMSA_MEM_ATTR(_ma0, _ma1, _ma2, _ma3)    ( ( _ma0 ) | ( ( _ma1 ) << 8 ) | ( ( _ma2 ) << 16 ) | ( ( _ma3 ) << 24 ) )
#define AARCH32_PMSA_MEM_ATTR_DEFAULT_CACHED
#define AARCH32_PMSA_MEM_ATTR_DEFAULT_UNCACHED
#define AARCH32_PMSA_MEM_ATTR_DEFAULT_DEVICE    AARCH32_PMSA_MEM_DEVICE_NG_NR_NE
#define AARCH32_PMSA_CODE_CACHED
#define AARCH32_PMSA_CODE_UNCACHED
#define AARCH32_PMSA_DATA_READ_ONLY_CACHED
#define AARCH32_PMSA_DATA_READ_ONLY_UNCACHED
#define AARCH32_PMSA_DATA_READ_WRITE_CACHED
#define AARCH32_PMSA_DATA_READ_WRITE_UNCACHED
#define AARCH32_PMSA_DATA_READ_WRITE_SHARED
#define AARCH32_PMSA_DEVICE
#define AARCH32_PMSA_DATA_READ_WRITE_DEFAULT    AARCH32_PMSA_DATA_READ_WRITE_CACHED
#define AARCH32_PMSA_DEFAULT_SECTIONS
 The default section definitions shall be used by the BSP to define _AArch32_PMSA_Sections.
void _AArch32_PMSA_Initialize (uint32_t memory_attributes_0, uint32_t memory_attributes_1, const AArch32_PMSA_Section *sections, size_t section_count)
 Initializes the Memory Protection Unit (MPU).
size_t _AArch32_PMSA_Map_sections_to_regions (const AArch32_PMSA_Section *sections, size_t section_count, AArch32_PMSA_Region *regions, size_t region_max)
 Maps the section definitions to region definitions.
void _AArch32_PMSA_Initialize_default (void)
 Initializes the Memory Protection Unit (MPU) using the section definitions with default memory attributes.
const AArch32_PMSA_Section _AArch32_PMSA_Sections []
 This array provides section definitions to initialize the memory protection unit (MPU).
const size_t _AArch32_PMSA_Section_count
 This constant provides the count of elements in _AArch32_PMSA_Sections.
