RTEMS 6.1-rc2
arm Directory Reference
file  __aeabi_read_tp.c
 This source file contains the implementation of __aeabi_read_tp().
file  __tls_get_addr.c
 This source file contains the implementation of __tls_get_addr().
file  aarch32-psma-init-default.c
 This source file contains the implementation of _AArch32_PMSA_Initialize_default().
file  aarch32-psma-init.c
 This source file contains the implementation of _AArch32_PMSA_Initialize().
file  arm-exception-default.c
 This source file contains the implementation of _ARM_Exception_default().
file  arm-exception-frame-print.c
 This source file contains the implementation of _CPU_Exception_frame_print().
file  armv4-sync-synchronize.c
 This source file contains the implementation of __sync_synchronize().
file  armv7-thread-idle.c
 This source file contains the implementation of _CPU_Thread_Idle_body().
file  armv7m-context-initialize.c
 This source file contains the implementation of _CPU_Context_Initialize().
file  armv7m-context-restore.c
 This source file contains the implementation of _CPU_Context_restore().
file  armv7m-context-switch.c
 This source file contains the implementation of _CPU_Context_switch().
file  armv7m-exception-default.c
 This source file contains the implementation of _ARMV7M_Exception_default().
file  armv7m-exception-handler-get.c
 This source file contains the implementation of _ARMV7M_Get_exception_handler().
file  armv7m-exception-handler-set.c
 This source file contains the implementation of _ARMV7M_Set_exception_handler().
file  armv7m-exception-priority-get.c
 This source file contains the implementation of _ARMV7M_Get_exception_priority().
file  armv7m-exception-priority-handler.c
 This source file contains the implementation of _ARMV7M_Set_exception_priority_and_handler().
file  armv7m-exception-priority-set.c
 This source file contains the implementation of _ARMV7M_Set_exception_priority().
file  armv7m-initialize.c
 This source file contains the implementation of _CPU_Initialize().
file  armv7m-isr-dispatch.c
 This source file contains the implementation of _ARMV7M_Thread_dispatch().
file  armv7m-isr-enter-leave.c
 This source file contains the implementation of _ARMV7M_Interrupt_service_enter() and _ARMV7M_Interrupt_service_leave().
file  armv7m-isr-level-get.c
 This source file contains the implementation of _CPU_ISR_Get_level().
file  armv7m-isr-level-set.c
 This source file contains the implementation of _CPU_ISR_Set_level().
file  armv7m-isr-vector-install.c
 This source file contains the implementation of _CPU_ISR_install_vector().
file  armv7m-multitasking-start-stop.c
 This source file contains the implementation of _ARMV7M_Start_multitasking().
file  cpu.c
 This source file contains static assertions to ensure the consistency of interfaces used in C and assembler and it contains the ARM-specific implementation of _CPU_Initialize(), _CPU_ISR_Get_level(), _CPU_ISR_Set_level(), _CPU_ISR_install_vector(), _CPU_Context_Initialize(), and _CPU_Fatal_halt().
