RTEMS 6.1-rc2
#include "fsl_common.h"
struct | _clock_arm_pll_config |
PLL configuration for ARM. More... | |
struct | _clock_usb_pll_config |
PLL configuration for USB. More... | |
struct | _clock_sys_pll_config |
PLL configuration for System. More... | |
struct | _clock_audio_pll_config |
PLL configuration for AUDIO and VIDEO. More... | |
struct | _clock_video_pll_config |
struct | _clock_enet_pll_config |
PLL configuration for ENET. More... | |
#define | FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL 0 |
Configure whether driver controls clock. | |
OSC operations | |
void | CLOCK_InitExternalClk (bool bypassXtalOsc) |
Initialize the external 24MHz clock. | |
void | CLOCK_DeinitExternalClk (void) |
Deinitialize the external 24MHz clock. | |
void | CLOCK_SwitchOsc (clock_osc_t osc) |
Switch the OSC. | |
void | CLOCK_InitRcOsc24M (void) |
Initialize the RC oscillator 24MHz clock. | |
void | CLOCK_DeinitRcOsc24M (void) |
Power down the RCOSC 24M clock. | |
bool | CLOCK_EnableUsbhs0Clock (clock_usb_src_t src, uint32_t freq) |
Enable USB HS clock. | |
bool | CLOCK_EnableUsbhs1Clock (clock_usb_src_t src, uint32_t freq) |
PLL/PFD operations | |
void | CLOCK_InitArmPll (const clock_arm_pll_config_t *config) |
Initialize the ARM PLL. | |
void | CLOCK_DeinitArmPll (void) |
De-initialize the ARM PLL. | |
void | CLOCK_InitSysPll (const clock_sys_pll_config_t *config) |
Initialize the System PLL. | |
void | CLOCK_DeinitSysPll (void) |
De-initialize the System PLL. | |
void | CLOCK_InitUsb1Pll (const clock_usb_pll_config_t *config) |
Initialize the USB1 PLL. | |
void | CLOCK_DeinitUsb1Pll (void) |
Deinitialize the USB1 PLL. | |
void | CLOCK_InitUsb2Pll (const clock_usb_pll_config_t *config) |
Initialize the USB2 PLL. | |
void | CLOCK_DeinitUsb2Pll (void) |
Deinitialize the USB2 PLL. | |
void | CLOCK_InitAudioPll (const clock_audio_pll_config_t *config) |
Initializes the Audio PLL. | |
void | CLOCK_DeinitAudioPll (void) |
De-initialize the Audio PLL. | |
void | CLOCK_InitVideoPll (const clock_video_pll_config_t *config) |
Initialize the video PLL. | |
void | CLOCK_DeinitVideoPll (void) |
De-initialize the Video PLL. | |
void | CLOCK_InitEnetPll (const clock_enet_pll_config_t *config) |
Initialize the ENET PLL. | |
void | CLOCK_DeinitEnetPll (void) |
Deinitialize the ENET PLL. | |
uint32_t | CLOCK_GetPllFreq (clock_pll_t pll) |
Get current PLL output frequency. | |
void | CLOCK_InitSysPfd (clock_pfd_t pfd, uint8_t pfdFrac) |
Initialize the System PLL PFD. | |
void | CLOCK_DeinitSysPfd (clock_pfd_t pfd) |
De-initialize the System PLL PFD. | |
bool | CLOCK_IsSysPfdEnabled (clock_pfd_t pfd) |
Check if Sys PFD is enabled. | |
void | CLOCK_InitUsb1Pfd (clock_pfd_t pfd, uint8_t pfdFrac) |
Initialize the USB1 PLL PFD. | |
void | CLOCK_DeinitUsb1Pfd (clock_pfd_t pfd) |
De-initialize the USB1 PLL PFD. | |
bool | CLOCK_IsUsb1PfdEnabled (clock_pfd_t pfd) |
Check if Usb1 PFD is enabled. | |
uint32_t | CLOCK_GetSysPfdFreq (clock_pfd_t pfd) |
Get current System PLL PFD output frequency. | |
uint32_t | CLOCK_GetUsb1PfdFreq (clock_pfd_t pfd) |
Get current USB1 PLL PFD output frequency. | |
bool | CLOCK_EnableUsbhs0PhyPllClock (clock_usb_phy_src_t src, uint32_t freq) |
Enable USB HS PHY PLL clock. | |
void | CLOCK_DisableUsbhs0PhyPllClock (void) |
Disable USB HS PHY PLL clock. | |
bool | CLOCK_EnableUsbhs1PhyPllClock (clock_usb_phy_src_t src, uint32_t freq) |
void | CLOCK_DisableUsbhs1PhyPllClock (void) |
Clock Output Inferfaces | |
void | CLOCK_SetClockOutput1 (clock_output1_selection_t selection, clock_output_divider_t divider) |
Set the clock source and the divider of the clock output1. | |
void | CLOCK_SetClockOutput2 (clock_output2_selection_t selection, clock_output_divider_t divider) |
Set the clock source and the divider of the clock output2. | |
uint32_t | CLOCK_GetClockOutCLKO1Freq (void) |
Get the frequency of clock output1 clock signal. | |
uint32_t | CLOCK_GetClockOutClkO2Freq (void) |
Get the frequency of clock output2 clock signal. | |
Driver version | |
#define | FSL_CLOCK_DRIVER_VERSION (MAKE_VERSION(2, 5, 1)) |
CLOCK driver version 2.5.1. | |
#define | SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY (600000000UL) |
#define | CCM_ANALOG_PLL_BYPASS_SHIFT (16U) |
#define | CCM_ANALOG_PLL_BYPASS_CLK_SRC_MASK (0xC000U) |
#define | CCM_ANALOG_PLL_BYPASS_CLK_SRC_SHIFT (14U) |
#define | CCSR_OFFSET 0x0C |
CCM registers offset. | |
#define | CBCDR_OFFSET 0x14 |
#define | CBCMR_OFFSET 0x18 |
#define | CSCMR1_OFFSET 0x1C |
#define | CSCMR2_OFFSET 0x20 |
#define | CSCDR1_OFFSET 0x24 |
#define | CDCDR_OFFSET 0x30 |
#define | CSCDR2_OFFSET 0x38 |
#define | CSCDR3_OFFSET 0x3C |
#define | CACRR_OFFSET 0x10 |
#define | CS1CDR_OFFSET 0x28 |
#define | CS2CDR_OFFSET 0x2C |
#define | PLL_ARM_OFFSET 0x00 |
CCM Analog registers offset. | |
#define | PLL_SYS_OFFSET 0x30 |
#define | PLL_USB1_OFFSET 0x10 |
#define | PLL_AUDIO_OFFSET 0x70 |
#define | PLL_VIDEO_OFFSET 0xA0 |
#define | PLL_ENET_OFFSET 0xE0 |
#define | PLL_USB2_OFFSET 0x20 |
#define | CCM_TUPLE(reg, shift, mask, busyShift) (int)(((reg)&0xFFU) | ((shift) << 8U) | ((((mask) >> (shift)) & 0x1FFFU) << 13U) | ((busyShift) << 26U)) |
#define | CCM_TUPLE_REG(base, tuple) (*((volatile uint32_t *)(((uint32_t)(base)) + ((uint32_t)(tuple)&0xFFU)))) |
#define | CCM_TUPLE_SHIFT(tuple) ((((uint32_t)tuple) >> 8U) & 0x1FU) |
#define | CCM_TUPLE_MASK(tuple) ((uint32_t)((((uint32_t)(tuple) >> 13U) & 0x1FFFU) << (((((uint32_t)tuple) >> 8U) & 0x1FU)))) |
#define | CCM_TUPLE_BUSY_SHIFT(tuple) ((((uint32_t)tuple) >> 26U) & 0x3FU) |
#define | CCM_NO_BUSY_WAIT (0x20U) |
#define | CCM_ANALOG_TUPLE(reg, shift) ((((reg)&0xFFFU) << 16U) | (shift)) |
CCM ANALOG tuple macros to map corresponding registers and bit fields. | |
#define | CCM_ANALOG_TUPLE_SHIFT(tuple) (((uint32_t)tuple) & 0x1FU) |
#define | CCM_ANALOG_TUPLE_REG_OFF(base, tuple, off) (*((volatile uint32_t *)((uint32_t)(base) + (((uint32_t)(tuple) >> 16U) & 0xFFFU) + (off)))) |
#define | CCM_ANALOG_TUPLE_REG(base, tuple) CCM_ANALOG_TUPLE_REG_OFF(base, tuple, 0U) |
#define | CLKPN_FREQ 0U |
clock1PN frequency. | |
#define | CLOCK_SetXtal0Freq CLOCK_SetXtalFreq |
#define | CLOCK_SetXtal32Freq CLOCK_SetRtcXtalFreq |
#define | ADC_CLOCKS |
Clock ip name array for ADC. | |
#define | AOI_CLOCKS |
Clock ip name array for AOI. | |
#define | BEE_CLOCKS |
Clock ip name array for BEE. | |
#define | CMP_CLOCKS |
Clock ip name array for CMP. | |
#define | CSI_CLOCKS |
Clock ip name array for CSI. | |
#define | DCDC_CLOCKS |
Clock ip name array for DCDC. | |
#define | DCP_CLOCKS |
Clock ip name array for DCP. | |
#define | DMAMUX_CLOCKS |
Clock ip name array for DMAMUX_CLOCKS. | |
#define | EDMA_CLOCKS |
Clock ip name array for DMA. | |
#define | ENC_CLOCKS |
Clock ip name array for ENC. | |
#define | ENET_CLOCKS |
Clock ip name array for ENET. | |
#define | EWM_CLOCKS |
Clock ip name array for EWM. | |
#define | FLEXCAN_CLOCKS |
Clock ip name array for FLEXCAN. | |
#define | FLEXCAN_PERIPH_CLOCKS |
Clock ip name array for FLEXCAN Peripheral clock. | |
#define | FLEXIO_CLOCKS |
Clock ip name array for FLEXIO. | |
#define | FLEXRAM_CLOCKS |
Clock ip name array for FLEXRAM. | |
#define | FLEXSPI_CLOCKS |
Clock ip name array for FLEXSPI. | |
#define | FLEXSPI_EXSC_CLOCKS |
Clock ip name array for FLEXSPI EXSC. | |
#define | GPIO_CLOCKS |
Clock ip name array for GPIO. | |
#define | GPT_CLOCKS |
Clock ip name array for GPT. | |
#define | KPP_CLOCKS |
Clock ip name array for KPP. | |
#define | LCDIF_CLOCKS |
Clock ip name array for LCDIF. | |
#define | LCDIF_PERIPH_CLOCKS |
Clock ip name array for LCDIF PIXEL. | |
#define | LPI2C_CLOCKS |
Clock ip name array for LPI2C. | |
#define | LPSPI_CLOCKS |
Clock ip name array for LPSPI. | |
#define | LPUART_CLOCKS |
Clock ip name array for LPUART. | |
#define | MQS_CLOCKS |
Clock ip name array for MQS. | |
#define | OCRAM_EXSC_CLOCKS |
Clock ip name array for OCRAM EXSC. | |
#define | PIT_CLOCKS |
Clock ip name array for PIT. | |
#define | PWM_CLOCKS |
Clock ip name array for PWM. | |
#define | PXP_CLOCKS |
Clock ip name array for PXP. | |
#define | RTWDOG_CLOCKS |
Clock ip name array for RTWDOG. | |
#define | SAI_CLOCKS |
Clock ip name array for SAI. | |
#define | SEMC_CLOCKS |
Clock ip name array for SEMC. | |
#define | SEMC_EXSC_CLOCKS |
Clock ip name array for SEMC EXSC. | |
#define | TMR_CLOCKS |
Clock ip name array for QTIMER. | |
#define | TRNG_CLOCKS |
Clock ip name array for TRNG. | |
#define | TSC_CLOCKS |
Clock ip name array for TSC. | |
#define | WDOG_CLOCKS |
Clock ip name array for WDOG. | |
#define | USDHC_CLOCKS |
Clock ip name array for USDHC. | |
#define | SPDIF_CLOCKS |
Clock ip name array for SPDIF. | |
#define | XBARA_CLOCKS |
Clock ip name array for XBARA. | |
#define | XBARB_CLOCKS |
Clock ip name array for XBARB. | |
#define | CLOCK_SOURCE_NONE (0xFFU) |
#define | CLOCK_ROOT_SOUCE |
#define | CLOCK_ROOT_MUX_TUPLE |
#define | CLOCK_ROOT_NONE_PRE_DIV 0UL |
#define | CLOCK_ROOT_DIV_TUPLE |
#define | kCLOCK_CoreSysClk kCLOCK_CpuClk |
#define | CLOCK_GetCoreSysClkFreq CLOCK_GetCpuClkFreq |
enum | _clock_name { kCLOCK_CpuClk = 0x0U , kCLOCK_AhbClk = 0x1U , kCLOCK_SemcClk = 0x2U , kCLOCK_IpgClk = 0x3U , kCLOCK_PerClk = 0x4U , kCLOCK_OscClk = 0x5U , kCLOCK_RtcClk = 0x6U , kCLOCK_ArmPllClk = 0x7U , kCLOCK_Usb1PllClk = 0x8U , kCLOCK_Usb1PllPfd0Clk = 0x9U , kCLOCK_Usb1PllPfd1Clk = 0xAU , kCLOCK_Usb1PllPfd2Clk = 0xBU , kCLOCK_Usb1PllPfd3Clk = 0xCU , kCLOCK_Usb1SwClk = 0x17U , kCLOCK_Usb1Sw120MClk = 0x18U , kCLOCK_Usb1Sw60MClk = 0x19U , kCLOCK_Usb1Sw80MClk = 0x1AU , kCLOCK_Usb2PllClk = 0xDU , kCLOCK_SysPllClk = 0xEU , kCLOCK_SysPllPfd0Clk = 0xFU , kCLOCK_SysPllPfd1Clk = 0x10U , kCLOCK_SysPllPfd2Clk = 0x11U , kCLOCK_SysPllPfd3Clk = 0x12U , kCLOCK_EnetPll0Clk = 0x13U , kCLOCK_EnetPll1Clk = 0x14U , kCLOCK_AudioPllClk = 0x15U , kCLOCK_VideoPllClk = 0x16U , kCLOCK_NoneName = CLOCK_SOURCE_NONE , kCLOCK_OscRc16M = 0 , kCLOCK_OscRc48M = 1 , kCLOCK_OscRc48MDiv2 = 2 , kCLOCK_OscRc400M = 3 , kCLOCK_Osc24M = 4 , kCLOCK_Osc24MOut = 5 , kCLOCK_ArmPll = 6 , kCLOCK_ArmPllOut = 7 , kCLOCK_SysPll2 = 8 , kCLOCK_SysPll2Out = 9 , kCLOCK_SysPll2Pfd0 = 10 , kCLOCK_SysPll2Pfd1 = 11 , kCLOCK_SysPll2Pfd2 = 12 , kCLOCK_SysPll2Pfd3 = 13 , kCLOCK_SysPll3 = 14 , kCLOCK_SysPll3Out = 15 , kCLOCK_SysPll3Div2 = 16 , kCLOCK_SysPll3Pfd0 = 17 , kCLOCK_SysPll3Pfd1 = 18 , kCLOCK_SysPll3Pfd2 = 19 , kCLOCK_SysPll3Pfd3 = 20 , kCLOCK_SysPll1 = 21 , kCLOCK_SysPll1Out = 22 , kCLOCK_SysPll1Div2 = 23 , kCLOCK_SysPll1Div5 = 24 , kCLOCK_AudioPll = 25 , kCLOCK_AudioPllOut = 26 , kCLOCK_VideoPll = 27 , kCLOCK_VideoPllOut = 28 , kCLOCK_CpuClk , kCLOCK_CoreSysClk , kCLOCK_Reserved = 0xFFU } |
Clock name used to get clock frequency. More... | |
enum | _clock_ip_name { kCLOCK_IpInvalid = -1 , kCLOCK_Aips_tz1 = (0U << 8U) | CCM_CCGR0_CG0_SHIFT , kCLOCK_Aips_tz2 = (0U << 8U) | CCM_CCGR0_CG1_SHIFT , kCLOCK_Mqs = (0U << 8U) | CCM_CCGR0_CG2_SHIFT , kCLOCK_FlexSpiExsc = (0U << 8U) | CCM_CCGR0_CG3_SHIFT , kCLOCK_Sim_M_Main = (0U << 8U) | CCM_CCGR0_CG4_SHIFT , kCLOCK_Dcp = (0U << 8U) | CCM_CCGR0_CG5_SHIFT , kCLOCK_Lpuart3 = (0U << 8U) | CCM_CCGR0_CG6_SHIFT , kCLOCK_Can1 = (0U << 8U) | CCM_CCGR0_CG7_SHIFT , kCLOCK_Can1S = (0U << 8U) | CCM_CCGR0_CG8_SHIFT , kCLOCK_Can2 = (0U << 8U) | CCM_CCGR0_CG9_SHIFT , kCLOCK_Can2S = (0U << 8U) | CCM_CCGR0_CG10_SHIFT , kCLOCK_Trace = (0U << 8U) | CCM_CCGR0_CG11_SHIFT , kCLOCK_Gpt2 = (0U << 8U) | CCM_CCGR0_CG12_SHIFT , kCLOCK_Gpt2S = (0U << 8U) | CCM_CCGR0_CG13_SHIFT , kCLOCK_Lpuart2 = (0U << 8U) | CCM_CCGR0_CG14_SHIFT , kCLOCK_Gpio2 = (0U << 8U) | CCM_CCGR0_CG15_SHIFT , kCLOCK_Lpspi1 = (1U << 8U) | CCM_CCGR1_CG0_SHIFT , kCLOCK_Lpspi2 = (1U << 8U) | CCM_CCGR1_CG1_SHIFT , kCLOCK_Lpspi3 = (1U << 8U) | CCM_CCGR1_CG2_SHIFT , kCLOCK_Lpspi4 = (1U << 8U) | CCM_CCGR1_CG3_SHIFT , kCLOCK_Adc2 = (1U << 8U) | CCM_CCGR1_CG4_SHIFT , kCLOCK_Enet = (1U << 8U) | CCM_CCGR1_CG5_SHIFT , kCLOCK_Pit = (1U << 8U) | CCM_CCGR1_CG6_SHIFT , kCLOCK_Aoi2 = (1U << 8U) | CCM_CCGR1_CG7_SHIFT , kCLOCK_Adc1 = (1U << 8U) | CCM_CCGR1_CG8_SHIFT , kCLOCK_SemcExsc = (1U << 8U) | CCM_CCGR1_CG9_SHIFT , kCLOCK_Gpt1 = (1U << 8U) | CCM_CCGR1_CG10_SHIFT , kCLOCK_Gpt1S = (1U << 8U) | CCM_CCGR1_CG11_SHIFT , kCLOCK_Lpuart4 = (1U << 8U) | CCM_CCGR1_CG12_SHIFT , kCLOCK_Gpio1 = (1U << 8U) | CCM_CCGR1_CG13_SHIFT , kCLOCK_Csu = (1U << 8U) | CCM_CCGR1_CG14_SHIFT , kCLOCK_Gpio5 = (1U << 8U) | CCM_CCGR1_CG15_SHIFT , kCLOCK_OcramExsc = (2U << 8U) | CCM_CCGR2_CG0_SHIFT , kCLOCK_Csi = (2U << 8U) | CCM_CCGR2_CG1_SHIFT , kCLOCK_IomuxcSnvs = (2U << 8U) | CCM_CCGR2_CG2_SHIFT , kCLOCK_Lpi2c1 = (2U << 8U) | CCM_CCGR2_CG3_SHIFT , kCLOCK_Lpi2c2 = (2U << 8U) | CCM_CCGR2_CG4_SHIFT , kCLOCK_Lpi2c3 = (2U << 8U) | CCM_CCGR2_CG5_SHIFT , kCLOCK_Ocotp = (2U << 8U) | CCM_CCGR2_CG6_SHIFT , kCLOCK_Xbar3 = (2U << 8U) | CCM_CCGR2_CG7_SHIFT , kCLOCK_Ipmux1 = (2U << 8U) | CCM_CCGR2_CG8_SHIFT , kCLOCK_Ipmux2 = (2U << 8U) | CCM_CCGR2_CG9_SHIFT , kCLOCK_Ipmux3 = (2U << 8U) | CCM_CCGR2_CG10_SHIFT , kCLOCK_Xbar1 = (2U << 8U) | CCM_CCGR2_CG11_SHIFT , kCLOCK_Xbar2 = (2U << 8U) | CCM_CCGR2_CG12_SHIFT , kCLOCK_Gpio3 = (2U << 8U) | CCM_CCGR2_CG13_SHIFT , kCLOCK_Lcd = (2U << 8U) | CCM_CCGR2_CG14_SHIFT , kCLOCK_Pxp = (2U << 8U) | CCM_CCGR2_CG15_SHIFT , kCLOCK_Flexio2 = (3U << 8U) | CCM_CCGR3_CG0_SHIFT , kCLOCK_Lpuart5 = (3U << 8U) | CCM_CCGR3_CG1_SHIFT , kCLOCK_Semc = (3U << 8U) | CCM_CCGR3_CG2_SHIFT , kCLOCK_Lpuart6 = (3U << 8U) | CCM_CCGR3_CG3_SHIFT , kCLOCK_Aoi1 = (3U << 8U) | CCM_CCGR3_CG4_SHIFT , kCLOCK_LcdPixel = (3U << 8U) | CCM_CCGR3_CG5_SHIFT , kCLOCK_Gpio4 = (3U << 8U) | CCM_CCGR3_CG6_SHIFT , kCLOCK_Ewm0 = (3U << 8U) | CCM_CCGR3_CG7_SHIFT , kCLOCK_Wdog1 = (3U << 8U) | CCM_CCGR3_CG8_SHIFT , kCLOCK_FlexRam = (3U << 8U) | CCM_CCGR3_CG9_SHIFT , kCLOCK_Acmp1 = (3U << 8U) | CCM_CCGR3_CG10_SHIFT , kCLOCK_Acmp2 = (3U << 8U) | CCM_CCGR3_CG11_SHIFT , kCLOCK_Acmp3 = (3U << 8U) | CCM_CCGR3_CG12_SHIFT , kCLOCK_Acmp4 = (3U << 8U) | CCM_CCGR3_CG13_SHIFT , kCLOCK_Ocram = (3U << 8U) | CCM_CCGR3_CG14_SHIFT , kCLOCK_IomuxcSnvsGpr = (3U << 8U) | CCM_CCGR3_CG15_SHIFT , kCLOCK_Sim_m7_clk_r = (4U << 8U) | CCM_CCGR4_CG0_SHIFT , kCLOCK_Iomuxc = (4U << 8U) | CCM_CCGR4_CG1_SHIFT , kCLOCK_IomuxcGpr = (4U << 8U) | CCM_CCGR4_CG2_SHIFT , kCLOCK_Bee = (4U << 8U) | CCM_CCGR4_CG3_SHIFT , kCLOCK_SimM7 = (4U << 8U) | CCM_CCGR4_CG4_SHIFT , kCLOCK_Tsc = (4U << 8U) | CCM_CCGR4_CG5_SHIFT , kCLOCK_SimM = (4U << 8U) | CCM_CCGR4_CG6_SHIFT , kCLOCK_SimEms = (4U << 8U) | CCM_CCGR4_CG7_SHIFT , kCLOCK_Pwm1 = (4U << 8U) | CCM_CCGR4_CG8_SHIFT , kCLOCK_Pwm2 = (4U << 8U) | CCM_CCGR4_CG9_SHIFT , kCLOCK_Pwm3 = (4U << 8U) | CCM_CCGR4_CG10_SHIFT , kCLOCK_Pwm4 = (4U << 8U) | CCM_CCGR4_CG11_SHIFT , kCLOCK_Enc1 = (4U << 8U) | CCM_CCGR4_CG12_SHIFT , kCLOCK_Enc2 = (4U << 8U) | CCM_CCGR4_CG13_SHIFT , kCLOCK_Enc3 = (4U << 8U) | CCM_CCGR4_CG14_SHIFT , kCLOCK_Enc4 = (4U << 8U) | CCM_CCGR4_CG15_SHIFT , kCLOCK_Rom = (5U << 8U) | CCM_CCGR5_CG0_SHIFT , kCLOCK_Flexio1 = (5U << 8U) | CCM_CCGR5_CG1_SHIFT , kCLOCK_Wdog3 = (5U << 8U) | CCM_CCGR5_CG2_SHIFT , kCLOCK_Dma = (5U << 8U) | CCM_CCGR5_CG3_SHIFT , kCLOCK_Kpp = (5U << 8U) | CCM_CCGR5_CG4_SHIFT , kCLOCK_Wdog2 = (5U << 8U) | CCM_CCGR5_CG5_SHIFT , kCLOCK_Aips_tz4 = (5U << 8U) | CCM_CCGR5_CG6_SHIFT , kCLOCK_Spdif = (5U << 8U) | CCM_CCGR5_CG7_SHIFT , kCLOCK_SimMain = (5U << 8U) | CCM_CCGR5_CG8_SHIFT , kCLOCK_Sai1 = (5U << 8U) | CCM_CCGR5_CG9_SHIFT , kCLOCK_Sai2 = (5U << 8U) | CCM_CCGR5_CG10_SHIFT , kCLOCK_Sai3 = (5U << 8U) | CCM_CCGR5_CG11_SHIFT , kCLOCK_Lpuart1 = (5U << 8U) | CCM_CCGR5_CG12_SHIFT , kCLOCK_Lpuart7 = (5U << 8U) | CCM_CCGR5_CG13_SHIFT , kCLOCK_SnvsHp = (5U << 8U) | CCM_CCGR5_CG14_SHIFT , kCLOCK_SnvsLp = (5U << 8U) | CCM_CCGR5_CG15_SHIFT , kCLOCK_UsbOh3 = (6U << 8U) | CCM_CCGR6_CG0_SHIFT , kCLOCK_Usdhc1 = (6U << 8U) | CCM_CCGR6_CG1_SHIFT , kCLOCK_Usdhc2 = (6U << 8U) | CCM_CCGR6_CG2_SHIFT , kCLOCK_Dcdc = (6U << 8U) | CCM_CCGR6_CG3_SHIFT , kCLOCK_Ipmux4 = (6U << 8U) | CCM_CCGR6_CG4_SHIFT , kCLOCK_FlexSpi = (6U << 8U) | CCM_CCGR6_CG5_SHIFT , kCLOCK_Trng = (6U << 8U) | CCM_CCGR6_CG6_SHIFT , kCLOCK_Lpuart8 = (6U << 8U) | CCM_CCGR6_CG7_SHIFT , kCLOCK_Timer4 = (6U << 8U) | CCM_CCGR6_CG8_SHIFT , kCLOCK_Aips_tz3 = (6U << 8U) | CCM_CCGR6_CG9_SHIFT , kCLOCK_SimPer = (6U << 8U) | CCM_CCGR6_CG10_SHIFT , kCLOCK_Anadig = (6U << 8U) | CCM_CCGR6_CG11_SHIFT , kCLOCK_Lpi2c4 = (6U << 8U) | CCM_CCGR6_CG12_SHIFT , kCLOCK_Timer1 = (6U << 8U) | CCM_CCGR6_CG13_SHIFT , kCLOCK_Timer2 = (6U << 8U) | CCM_CCGR6_CG14_SHIFT , kCLOCK_Timer3 = (6U << 8U) | CCM_CCGR6_CG15_SHIFT } |
CCM CCGR gate control for each module independently. More... | |
enum | _clock_osc { kCLOCK_RcOsc = 0U , kCLOCK_XtalOsc = 1U , kCLOCK_RcOsc = 0U , kCLOCK_XtalOsc = 1U } |
OSC 24M sorce select. More... | |
enum | _clock_gate_value { kCLOCK_ClockNotNeeded = 0U , kCLOCK_ClockNeededRun = 1U , kCLOCK_ClockNeededRunWait = 3U , kCLOCK_Off = (int)~CCM_LPCG_DIRECT_ON_MASK , kCLOCK_On = CCM_LPCG_DIRECT_ON_MASK } |
Clock gate value. More... | |
enum | _clock_mode_t { kCLOCK_ModeRun = 0U , kCLOCK_ModeWait = 1U , kCLOCK_ModeStop = 2U , kCLOCK_ModeRun = 0U , kCLOCK_ModeWait = 1U , kCLOCK_ModeStop = 2U } |
System clock mode. More... | |
enum | _clock_mux { kCLOCK_Pll3SwMux , kCLOCK_PeriphMux , kCLOCK_SemcAltMux , kCLOCK_SemcMux , kCLOCK_PrePeriphMux , kCLOCK_TraceMux , kCLOCK_PeriphClk2Mux , kCLOCK_LpspiMux , kCLOCK_FlexspiMux , kCLOCK_Usdhc2Mux , kCLOCK_Usdhc1Mux , kCLOCK_Sai3Mux , kCLOCK_Sai2Mux , kCLOCK_Sai1Mux , kCLOCK_PerclkMux , kCLOCK_Flexio2Mux , kCLOCK_CanMux , kCLOCK_UartMux , kCLOCK_SpdifMux , kCLOCK_Flexio1Mux , kCLOCK_Lpi2cMux , kCLOCK_LcdifPreMux , kCLOCK_CsiMux } |
MUX control names for clock mux setting. More... | |
enum | _clock_div { kCLOCK_ArmDiv , kCLOCK_PeriphClk2Div , kCLOCK_SemcDiv , kCLOCK_AhbDiv , kCLOCK_IpgDiv , kCLOCK_LpspiDiv , kCLOCK_LcdifDiv , kCLOCK_FlexspiDiv , kCLOCK_PerclkDiv , kCLOCK_CanDiv , kCLOCK_TraceDiv , kCLOCK_Usdhc2Div , kCLOCK_Usdhc1Div , kCLOCK_UartDiv , kCLOCK_Flexio2Div , kCLOCK_Sai3PreDiv , kCLOCK_Sai3Div , kCLOCK_Flexio2PreDiv , kCLOCK_Sai1PreDiv , kCLOCK_Sai1Div , kCLOCK_Sai2PreDiv , kCLOCK_Sai2Div , kCLOCK_Spdif0PreDiv , kCLOCK_Spdif0Div , kCLOCK_Flexio1PreDiv , kCLOCK_Flexio1Div , kCLOCK_Lpi2cDiv , kCLOCK_LcdifPreDiv , kCLOCK_CsiDiv , kCLOCK_NonePreDiv = CLOCK_ROOT_NONE_PRE_DIV } |
DIV control names for clock div setting. More... | |
enum | _clock_div_value { kCLOCK_ArmDivBy1 = 0 , kCLOCK_ArmDivBy2 = 1 , kCLOCK_ArmDivBy3 = 2 , kCLOCK_ArmDivBy4 = 3 , kCLOCK_ArmDivBy5 = 4 , kCLOCK_ArmDivBy6 = 5 , kCLOCK_ArmDivBy7 = 6 , kCLOCK_ArmDivBy8 = 7 , kCLOCK_PeriphClk2DivBy1 = 0 , kCLOCK_PeriphClk2DivBy2 = 1 , kCLOCK_PeriphClk2DivBy3 = 2 , kCLOCK_PeriphClk2DivBy4 = 3 , kCLOCK_PeriphClk2DivBy5 = 4 , kCLOCK_PeriphClk2DivBy6 = 5 , kCLOCK_PeriphClk2DivBy7 = 6 , kCLOCK_PeriphClk2DivBy8 = 7 , kCLOCK_SemcDivBy1 = 0 , kCLOCK_SemcDivBy2 = 1 , kCLOCK_SemcDivBy3 = 2 , kCLOCK_SemcDivBy4 = 3 , kCLOCK_SemcDivBy5 = 4 , kCLOCK_SemcDivBy6 = 5 , kCLOCK_SemcDivBy7 = 6 , kCLOCK_SemcDivBy8 = 7 , kCLOCK_AhbDivBy1 = 0 , kCLOCK_AhbDivBy2 = 1 , kCLOCK_AhbDivBy3 = 2 , kCLOCK_AhbDivBy4 = 3 , kCLOCK_AhbDivBy5 = 4 , kCLOCK_AhbDivBy6 = 5 , kCLOCK_AhbDivBy7 = 6 , kCLOCK_AhbDivBy8 = 7 , kCLOCK_IpgDivBy1 = 0 , kCLOCK_IpgDivBy2 = 1 , kCLOCK_IpgDivBy3 = 2 , kCLOCK_IpgDivBy4 = 3 , kCLOCK_LpspiDivBy1 = 0 , kCLOCK_LpspiDivBy2 = 1 , kCLOCK_LpspiDivBy3 = 2 , kCLOCK_LpspiDivBy4 = 3 , kCLOCK_LpspiDivBy5 = 4 , kCLOCK_LpspiDivBy6 = 5 , kCLOCK_LpspiDivBy7 = 6 , kCLOCK_LpspiDivBy8 = 7 , kCLOCK_LcdifDivBy1 = 0 , kCLOCK_LcdifDivBy2 = 1 , kCLOCK_LcdifDivBy3 = 2 , kCLOCK_LcdifDivBy4 = 3 , kCLOCK_LcdifDivBy5 = 4 , kCLOCK_LcdifDivBy6 = 5 , kCLOCK_LcdifDivBy7 = 6 , kCLOCK_LcdifDivBy8 = 7 , kCLOCK_FlexspiDivBy1 = 0 , kCLOCK_FlexspiDivBy2 = 1 , kCLOCK_FlexspiDivBy3 = 2 , kCLOCK_FlexspiDivBy4 = 3 , kCLOCK_FlexspiDivBy5 = 4 , kCLOCK_FlexspiDivBy6 = 5 , kCLOCK_FlexspiDivBy7 = 6 , kCLOCK_FlexspiDivBy8 = 7 , kCLOCK_TraceDivBy1 = 0 , kCLOCK_TraceDivBy2 = 1 , kCLOCK_TraceDivBy3 = 2 , kCLOCK_TraceDivBy4 = 3 , kCLOCK_Usdhc2DivBy1 = 0 , kCLOCK_Usdhc2DivBy2 = 1 , kCLOCK_Usdhc2DivBy3 = 2 , kCLOCK_Usdhc2DivBy4 = 3 , kCLOCK_Usdhc2DivBy5 = 4 , kCLOCK_Usdhc2DivBy6 = 5 , kCLOCK_Usdhc2DivBy7 = 6 , kCLOCK_Usdhc2DivBy8 = 7 , kCLOCK_Usdhc1DivBy1 = 0 , kCLOCK_Usdhc1DivBy2 = 1 , kCLOCK_Usdhc1DivBy3 = 2 , kCLOCK_Usdhc1DivBy4 = 3 , kCLOCK_Usdhc1DivBy5 = 4 , kCLOCK_Usdhc1DivBy6 = 5 , kCLOCK_Usdhc1DivBy7 = 6 , kCLOCK_Usdhc1DivBy8 = 7 , kCLOCK_Flexio2DivBy1 = 0 , kCLOCK_Flexio2DivBy2 = 1 , kCLOCK_Flexio2DivBy3 = 2 , kCLOCK_Flexio2DivBy4 = 3 , kCLOCK_Flexio2DivBy5 = 4 , kCLOCK_Flexio2DivBy6 = 5 , kCLOCK_Flexio2DivBy7 = 6 , kCLOCK_Flexio2DivBy8 = 7 , kCLOCK_Sai3PreDivBy1 = 0 , kCLOCK_Sai3PreDivBy2 = 1 , kCLOCK_Sai3PreDivBy3 = 2 , kCLOCK_Sai3PreDivBy4 = 3 , kCLOCK_Sai3PreDivBy5 = 4 , kCLOCK_Sai3PreDivBy6 = 5 , kCLOCK_Sai3PreDivBy7 = 6 , kCLOCK_Sai3PreDivBy8 = 7 , kCLOCK_Flexio2PreDivBy1 = 0 , kCLOCK_Flexio2PreDivBy2 = 1 , kCLOCK_Flexio2PreDivBy3 = 2 , kCLOCK_Flexio2PreDivBy4 = 3 , kCLOCK_Flexio2PreDivBy5 = 4 , kCLOCK_Flexio2PreDivBy6 = 5 , kCLOCK_Flexio2PreDivBy7 = 6 , kCLOCK_Flexio2PreDivBy8 = 7 , kCLOCK_Sai1PreDivBy1 = 0 , kCLOCK_Sai1PreDivBy2 = 1 , kCLOCK_Sai1PreDivBy3 = 2 , kCLOCK_Sai1PreDivBy4 = 3 , kCLOCK_Sai1PreDivBy5 = 4 , kCLOCK_Sai1PreDivBy6 = 5 , kCLOCK_Sai1PreDivBy7 = 6 , kCLOCK_Sai1PreDivBy8 = 7 , kCLOCK_Sai2PreDivBy1 = 0 , kCLOCK_Sai2PreDivBy2 = 1 , kCLOCK_Sai2PreDivBy3 = 2 , kCLOCK_Sai2PreDivBy4 = 3 , kCLOCK_Sai2PreDivBy5 = 4 , kCLOCK_Sai2PreDivBy6 = 5 , kCLOCK_Sai2PreDivBy7 = 6 , kCLOCK_Sai2PreDivBy8 = 7 , kCLOCK_Spdif0PreDivBy1 = 0 , kCLOCK_Spdif0PreDivBy2 = 1 , kCLOCK_Spdif0PreDivBy3 = 2 , kCLOCK_Spdif0PreDivBy4 = 3 , kCLOCK_Spdif0PreDivBy5 = 4 , kCLOCK_Spdif0PreDivBy6 = 5 , kCLOCK_Spdif0PreDivBy7 = 6 , kCLOCK_Spdif0PreDivBy8 = 7 , kCLOCK_Spdif0DivBy1 = 0 , kCLOCK_Spdif0DivBy2 = 1 , kCLOCK_Spdif0DivBy3 = 2 , kCLOCK_Spdif0DivBy4 = 3 , kCLOCK_Spdif0DivBy5 = 4 , kCLOCK_Spdif0DivBy6 = 5 , kCLOCK_Spdif0DivBy7 = 6 , kCLOCK_Spdif0DivBy8 = 7 , kCLOCK_Flexio1PreDivBy1 = 0 , kCLOCK_Flexio1PreDivBy2 = 1 , kCLOCK_Flexio1PreDivBy3 = 2 , kCLOCK_Flexio1PreDivBy4 = 3 , kCLOCK_Flexio1PreDivBy5 = 4 , kCLOCK_Flexio1PreDivBy6 = 5 , kCLOCK_Flexio1PreDivBy7 = 6 , kCLOCK_Flexio1PreDivBy8 = 7 , kCLOCK_Flexio1DivBy1 = 0 , kCLOCK_Flexio1DivBy2 = 1 , kCLOCK_Flexio1DivBy3 = 2 , kCLOCK_Flexio1DivBy4 = 3 , kCLOCK_Flexio1DivBy5 = 4 , kCLOCK_Flexio1DivBy6 = 5 , kCLOCK_Flexio1DivBy7 = 6 , kCLOCK_Flexio1DivBy8 = 7 , kCLOCK_LcdifPreDivBy1 = 0 , kCLOCK_LcdifPreDivBy2 = 1 , kCLOCK_LcdifPreDivBy3 = 2 , kCLOCK_LcdifPreDivBy4 = 3 , kCLOCK_LcdifPreDivBy5 = 4 , kCLOCK_LcdifPreDivBy6 = 5 , kCLOCK_LcdifPreDivBy7 = 6 , kCLOCK_LcdifPreDivBy8 = 7 , kCLOCK_CsiDivBy1 = 0 , kCLOCK_CsiDivBy2 = 1 , kCLOCK_CsiDivBy3 = 2 , kCLOCK_CsiDivBy4 = 3 , kCLOCK_CsiDivBy5 = 4 , kCLOCK_CsiDivBy6 = 5 , kCLOCK_CsiDivBy7 = 6 , kCLOCK_CsiDivBy8 = 7 , kCLOCK_MiscDivBy1 = 0 , kCLOCK_MiscDivBy2 = 1 , kCLOCK_MiscDivBy3 = 2 , kCLOCK_MiscDivBy4 = 3 , kCLOCK_MiscDivBy5 = 4 , kCLOCK_MiscDivBy6 = 5 , kCLOCK_MiscDivBy7 = 6 , kCLOCK_MiscDivBy8 = 7 , kCLOCK_MiscDivBy9 = 8 , kCLOCK_MiscDivBy10 = 9 , kCLOCK_MiscDivBy11 = 10 , kCLOCK_MiscDivBy12 = 11 , kCLOCK_MiscDivBy13 = 12 , kCLOCK_MiscDivBy14 = 13 , kCLOCK_MiscDivBy15 = 14 , kCLOCK_MiscDivBy16 = 15 , kCLOCK_MiscDivBy17 = 16 , kCLOCK_MiscDivBy18 = 17 , kCLOCK_MiscDivBy19 = 18 , kCLOCK_MiscDivBy20 = 19 , kCLOCK_MiscDivBy21 = 20 , kCLOCK_MiscDivBy22 = 21 , kCLOCK_MiscDivBy23 = 22 , kCLOCK_MiscDivBy24 = 23 , kCLOCK_MiscDivBy25 = 24 , kCLOCK_MiscDivBy26 = 25 , kCLOCK_MiscDivBy27 = 26 , kCLOCK_MiscDivBy28 = 27 , kCLOCK_MiscDivBy29 = 28 , kCLOCK_MiscDivBy30 = 29 , kCLOCK_MiscDivBy31 = 30 , kCLOCK_MiscDivBy32 = 31 , kCLOCK_MiscDivBy33 = 32 , kCLOCK_MiscDivBy34 = 33 , kCLOCK_MiscDivBy35 = 34 , kCLOCK_MiscDivBy36 = 35 , kCLOCK_MiscDivBy37 = 36 , kCLOCK_MiscDivBy38 = 37 , kCLOCK_MiscDivBy39 = 38 , kCLOCK_MiscDivBy40 = 39 , kCLOCK_MiscDivBy41 = 40 , kCLOCK_MiscDivBy42 = 41 , kCLOCK_MiscDivBy43 = 42 , kCLOCK_MiscDivBy44 = 43 , kCLOCK_MiscDivBy45 = 44 , kCLOCK_MiscDivBy46 = 45 , kCLOCK_MiscDivBy47 = 46 , kCLOCK_MiscDivBy48 = 47 , kCLOCK_MiscDivBy49 = 48 , kCLOCK_MiscDivBy50 = 49 , kCLOCK_MiscDivBy51 = 50 , kCLOCK_MiscDivBy52 = 51 , kCLOCK_MiscDivBy53 = 52 , kCLOCK_MiscDivBy54 = 53 , kCLOCK_MiscDivBy55 = 54 , kCLOCK_MiscDivBy56 = 55 , kCLOCK_MiscDivBy57 = 56 , kCLOCK_MiscDivBy58 = 57 , kCLOCK_MiscDivBy59 = 58 , kCLOCK_MiscDivBy60 = 59 , kCLOCK_MiscDivBy61 = 60 , kCLOCK_MiscDivBy62 = 61 , kCLOCK_MiscDivBy63 = 62 , kCLOCK_MiscDivBy64 = 63 } |
Clock divider value. More... | |
enum | _clock_usb_src { kCLOCK_Usb480M = 0 , kCLOCK_UsbSrcUnused = (int)0xFFFFFFFFU , kCLOCK_Usb480M = 0 , kCLOCK_UsbSrcUnused = (int)0xFFFFFFFFU } |
USB clock source definition. More... | |
enum | _clock_usb_phy_src { kCLOCK_Usbphy480M = 0 , kCLOCK_Usbphy480M = 0 } |
Source of the USB HS PHY. More... | |
enum | _clock_pll_clk_src { kCLOCK_PllClkSrc24M = 0U , kCLOCK_PllSrcClkPN = 1U , kCLOCK_PllClkSrc24M = 0U , kCLOCK_PllSrcClkPN = 1U } |
PLL clock source, bypass cloco source also. More... | |
enum | _clock_pll { kCLOCK_PllArm = CCM_ANALOG_TUPLE(PLL_ARM_OFFSET, CCM_ANALOG_PLL_ARM_ENABLE_SHIFT) , kCLOCK_PllSys = CCM_ANALOG_TUPLE(PLL_SYS_OFFSET, CCM_ANALOG_PLL_SYS_ENABLE_SHIFT) , kCLOCK_PllUsb1 = CCM_ANALOG_TUPLE(PLL_USB1_OFFSET, CCM_ANALOG_PLL_USB1_ENABLE_SHIFT) , kCLOCK_PllAudio = CCM_ANALOG_TUPLE(PLL_AUDIO_OFFSET, CCM_ANALOG_PLL_AUDIO_ENABLE_SHIFT) , kCLOCK_PllVideo = CCM_ANALOG_TUPLE(PLL_VIDEO_OFFSET, CCM_ANALOG_PLL_VIDEO_ENABLE_SHIFT) , kCLOCK_PllEnet = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENABLE_SHIFT) , kCLOCK_PllEnet25M = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN_SHIFT) , kCLOCK_PllUsb2 = CCM_ANALOG_TUPLE(PLL_USB2_OFFSET, CCM_ANALOG_PLL_USB2_ENABLE_SHIFT) , kCLOCK_PllArm , kCLOCK_PllSys1 , kCLOCK_PllSys2 , kCLOCK_PllSys3 , kCLOCK_PllAudio , kCLOCK_PllVideo , kCLOCK_PllInvalid = -1 } |
PLL name. More... | |
enum | _clock_pfd { kCLOCK_Pfd0 = 0U , kCLOCK_Pfd1 = 1U , kCLOCK_Pfd2 = 2U , kCLOCK_Pfd3 = 3U , kCLOCK_Pfd0 = 0U , kCLOCK_Pfd1 = 1U , kCLOCK_Pfd2 = 2U , kCLOCK_Pfd3 = 3U } |
PLL PFD name. More... | |
enum | _clock_output1_selection { kCLOCK_OutputPllUsb1 = 0U , kCLOCK_OutputPllSys = 1U , kCLOCK_OutputPllVideo = 3U , kCLOCK_OutputSemcClk = 5U , kCLOCK_OutputLcdifPixClk = 0xAU , kCLOCK_OutputAhbClk = 0xBU , kCLOCK_OutputIpgClk = 0xCU , kCLOCK_OutputPerClk = 0xDU , kCLOCK_OutputCkilSyncClk = 0xEU , kCLOCK_OutputPll4MainClk = 0xFU , kCLOCK_DisableClockOutput1 = 0x10U } |
The enumerater of clock output1's clock source, such as USB1 PLL, SYS PLL and so on. More... | |
enum | _clock_output2_selection { kCLOCK_OutputUsdhc1Clk = 3U , kCLOCK_OutputLpi2cClk = 6U , kCLOCK_OutputCsiClk = 0xBU , kCLOCK_OutputOscClk = 0xEU , kCLOCK_OutputUsdhc2Clk = 0x11U , kCLOCK_OutputSai1Clk = 0x12U , kCLOCK_OutputSai2Clk = 0x13U , kCLOCK_OutputSai3Clk = 0x14U , kCLOCK_OutputCanClk = 0x17U , kCLOCK_OutputFlexspiClk = 0x1BU , kCLOCK_OutputUartClk = 0x1CU , kCLOCK_OutputSpdif0Clk = 0x1DU , kCLOCK_DisableClockOutput2 = 0x1FU } |
The enumerater of clock output2's clock source, such as USDHC1 clock root, LPI2C clock root and so on. More... | |
enum | _clock_output_divider { kCLOCK_DivideBy1 = 0U , kCLOCK_DivideBy2 , kCLOCK_DivideBy3 , kCLOCK_DivideBy4 , kCLOCK_DivideBy5 , kCLOCK_DivideBy6 , kCLOCK_DivideBy7 , kCLOCK_DivideBy8 } |
The enumerator of clock output's divider. More... | |
enum | _clock_root { kCLOCK_Usdhc1ClkRoot = 0U , kCLOCK_Usdhc2ClkRoot , kCLOCK_FlexspiClkRoot , kCLOCK_CsiClkRoot , kCLOCK_LpspiClkRoot , kCLOCK_TraceClkRoot , kCLOCK_Sai1ClkRoot , kCLOCK_Sai2ClkRoot , kCLOCK_Sai3ClkRoot , kCLOCK_Lpi2cClkRoot , kCLOCK_CanClkRoot , kCLOCK_UartClkRoot , kCLOCK_LcdifClkRoot , kCLOCK_SpdifClkRoot , kCLOCK_Flexio1ClkRoot , kCLOCK_Flexio2ClkRoot , kCLOCK_Root_M7 = 0 , kCLOCK_Root_M4 = 1 , kCLOCK_Root_Bus = 2 , kCLOCK_Root_Bus_Lpsr = 3 , kCLOCK_Root_Semc = 4 , kCLOCK_Root_Cssys = 5 , kCLOCK_Root_Cstrace = 6 , kCLOCK_Root_M4_Systick = 7 , kCLOCK_Root_M7_Systick = 8 , kCLOCK_Root_Adc1 = 9 , kCLOCK_Root_Adc2 = 10 , kCLOCK_Root_Acmp = 11 , kCLOCK_Root_Flexio1 = 12 , kCLOCK_Root_Flexio2 = 13 , kCLOCK_Root_Gpt1 = 14 , kCLOCK_Root_Gpt2 = 15 , kCLOCK_Root_Gpt3 = 16 , kCLOCK_Root_Gpt4 = 17 , kCLOCK_Root_Gpt5 = 18 , kCLOCK_Root_Gpt6 = 19 , kCLOCK_Root_Flexspi1 = 20 , kCLOCK_Root_Flexspi2 = 21 , kCLOCK_Root_Can1 = 22 , kCLOCK_Root_Can2 = 23 , kCLOCK_Root_Can3 = 24 , kCLOCK_Root_Lpuart1 = 25 , kCLOCK_Root_Lpuart2 = 26 , kCLOCK_Root_Lpuart3 = 27 , kCLOCK_Root_Lpuart4 = 28 , kCLOCK_Root_Lpuart5 = 29 , kCLOCK_Root_Lpuart6 = 30 , kCLOCK_Root_Lpuart7 = 31 , kCLOCK_Root_Lpuart8 = 32 , kCLOCK_Root_Lpuart9 = 33 , kCLOCK_Root_Lpuart10 = 34 , kCLOCK_Root_Lpuart11 = 35 , kCLOCK_Root_Lpuart12 = 36 , kCLOCK_Root_Lpi2c1 = 37 , kCLOCK_Root_Lpi2c2 = 38 , kCLOCK_Root_Lpi2c3 = 39 , kCLOCK_Root_Lpi2c4 = 40 , kCLOCK_Root_Lpi2c5 = 41 , kCLOCK_Root_Lpi2c6 = 42 , kCLOCK_Root_Lpspi1 = 43 , kCLOCK_Root_Lpspi2 = 44 , kCLOCK_Root_Lpspi3 = 45 , kCLOCK_Root_Lpspi4 = 46 , kCLOCK_Root_Lpspi5 = 47 , kCLOCK_Root_Lpspi6 = 48 , kCLOCK_Root_Emv1 = 49 , kCLOCK_Root_Emv2 = 50 , kCLOCK_Root_Enet1 = 51 , kCLOCK_Root_Enet2 = 52 , kCLOCK_Root_Enet_25m = 54 , kCLOCK_Root_Enet_Timer1 = 55 , kCLOCK_Root_Enet_Timer2 = 56 , kCLOCK_Root_Usdhc1 = 58 , kCLOCK_Root_Usdhc2 = 59 , kCLOCK_Root_Asrc = 60 , kCLOCK_Root_Mqs = 61 , kCLOCK_Root_Mic = 62 , kCLOCK_Root_Spdif = 63 , kCLOCK_Root_Sai1 = 64 , kCLOCK_Root_Sai2 = 65 , kCLOCK_Root_Sai3 = 66 , kCLOCK_Root_Sai4 = 67 , kCLOCK_Root_Gc355 = 68 , kCLOCK_Root_Lcdif = 69 , kCLOCK_Root_Lcdifv2 = 70 , kCLOCK_Root_Mipi_Ref = 71 , kCLOCK_Root_Mipi_Esc = 72 , kCLOCK_Root_Csi2 = 73 , kCLOCK_Root_Csi2_Esc = 74 , kCLOCK_Root_Csi2_Ui = 75 , kCLOCK_Root_Csi = 76 , kCLOCK_Root_Cko1 = 77 , kCLOCK_Root_Cko2 = 78 } |
The enumerator of clock root. More... | |
typedef enum _clock_name | clock_name_t |
Clock name used to get clock frequency. | |
typedef enum _clock_ip_name | clock_ip_name_t |
CCM CCGR gate control for each module independently. | |
typedef enum _clock_osc | clock_osc_t |
OSC 24M sorce select. | |
typedef enum _clock_gate_value | clock_gate_value_t |
Clock gate value. | |
typedef enum _clock_mode_t | clock_mode_t |
System clock mode. | |
typedef enum _clock_mux | clock_mux_t |
MUX control names for clock mux setting. | |
typedef enum _clock_div | clock_div_t |
DIV control names for clock div setting. | |
typedef enum _clock_div_value | clock_div_value_t |
Clock divider value. | |
typedef enum _clock_usb_src | clock_usb_src_t |
USB clock source definition. | |
typedef enum _clock_usb_phy_src | clock_usb_phy_src_t |
Source of the USB HS PHY. | |
typedef struct _clock_arm_pll_config | clock_arm_pll_config_t |
PLL configuration for ARM. | |
typedef struct _clock_usb_pll_config | clock_usb_pll_config_t |
PLL configuration for USB. | |
typedef struct _clock_sys_pll_config | clock_sys_pll_config_t |
PLL configuration for System. | |
typedef struct _clock_audio_pll_config | clock_audio_pll_config_t |
PLL configuration for AUDIO and VIDEO. | |
typedef struct _clock_video_pll_config | clock_video_pll_config_t |
typedef struct _clock_enet_pll_config | clock_enet_pll_config_t |
PLL configuration for ENET. | |
typedef enum _clock_pll | clock_pll_t |
PLL name. | |
typedef enum _clock_pfd | clock_pfd_t |
PLL PFD name. | |
typedef enum _clock_output1_selection | clock_output1_selection_t |
The enumerater of clock output1's clock source, such as USB1 PLL, SYS PLL and so on. | |
typedef enum _clock_output2_selection | clock_output2_selection_t |
The enumerater of clock output2's clock source, such as USDHC1 clock root, LPI2C clock root and so on. | |
typedef enum _clock_output_divider | clock_output_divider_t |
The enumerator of clock output's divider. | |
typedef enum _clock_root | clock_root_t |
The enumerator of clock root. | |
volatile uint32_t | g_xtalFreq |
External XTAL (24M OSC/SYSOSC) clock frequency. | |
volatile uint32_t | g_rtcXtalFreq |
External RTC XTAL (32K OSC) clock frequency. | |
uint32_t | CLOCK_GetAhbFreq (void) |
Gets the AHB clock frequency. | |
uint32_t | CLOCK_GetSemcFreq (void) |
Gets the SEMC clock frequency. | |
uint32_t | CLOCK_GetIpgFreq (void) |
Gets the IPG clock frequency. | |
uint32_t | CLOCK_GetPerClkFreq (void) |
Gets the PER clock frequency. | |
uint32_t | CLOCK_GetFreq (clock_name_t name) |
Gets the clock frequency for a specific clock name. | |
uint32_t | CLOCK_GetClockRootFreq (clock_root_t clockRoot) |
Gets the frequency of selected clock root. | |
