RTEMS 6.1-rc1
#include <rtems/bspIo.h>
#include <rtems/test-info.h>
#include <rtems/test.h>
#include <rtems/testopts.h>
#include <rtems/score/smpimpl.h>
#include "ts-config.h"
#include "tx-support.h"
#include <rtems/confdefs.h>
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
#define | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0 |
#define | CONFIGURE_MAXIMUM_USER_EXTENSIONS 1 |
#define | CONFIGURE_DISABLE_NEWLIB_REENTRANCY |
#define | CONFIGURE_APPLICATION_DISABLE_FILESYSTEM |
#define | CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE |
#define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
#define | CONFIGURE_IDLE_TASK_BODY ShutdownIdleBody |
#define | CONFIGURE_INITIAL_EXTENSIONS { .fatal = FatalInitialExtension } |
#define | CONFIGURE_INIT |
void | __real__CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr code) |
void | __wrap__CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr code) |
const char | rtems_test_name [] = "TestsuitesBspsFatalSparcLeon3Shutdown" |
Each test must define a test name string. | |
