RTEMS 6.1-rc1
confdefs.h
2
17/*
18 * Copyright (C) 2020 embedded brains GmbH & Co. KG
19 * Copyright (C) 1989, 2000 On-Line Applications Research Corporation (OAR)
20 *
21 * Redistribution and use in source and binary forms, with or without
22 * modification, are permitted provided that the following conditions
23 * are met:
24 * 1. Redistributions of source code must retain the above copyright
25 * notice, this list of conditions and the following disclaimer.
26 * 2. Redistributions in binary form must reproduce the above copyright
27 * notice, this list of conditions and the following disclaimer in the
28 * documentation and/or other materials provided with the distribution.
29 *
30 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
31 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
32 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
33 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
34 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
35 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
36 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
37 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
38 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
39 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
40 * POSSIBILITY OF SUCH DAMAGE.
41 */
42
43#ifndef __CONFIGURATION_TEMPLATE_h
44#define __CONFIGURATION_TEMPLATE_h
45
57/*
58 * This header file must be included first. For example, configuration options
59 * which have been renamed are mapped to the new define.
60 */
62
67#include <rtems/confdefs/face.h>
74#include <rtems/confdefs/mpci.h>
82
85#endif
86/* end of include file */
This header file evaluates configuration options related to the block device cache configuration.
This header file evaluates configuration options related to the I/O library configuration.
This header file evaluates configuration options related to the C Program Heap configuration.
This header file evaluates configuration options related to the per-CPU configuration.
This header file evaluates configuration options related to the scheduler configuration.
This header file evaluates configuration options related to the RTEMS Workspace configuration.
This header file evaluates configuration options related to the clock driver configuration.
This header file evaluates configuration options related to the console driver configuration.
This header file evaluates configuration options related to the MPCI configuration.
This header file evaluates configuration options related to the user extensions configuration.
This header file evaluates configuration options related to the FACE Technical Standard.
This header file evaluates configuration options related to the Classic API initialization task confi...
This header file evaluates configuration options related to the POSIX initialization thread configura...
This header file evaluates configuration options related to the I/O driver configuration.
This header file evaluates configuration options related to the PCI library configuration.
This header file evaluates configuration options related to the Newlib C Library configuration.
This header file evaluates configuration options related to the Classic API objects configuration.
This header file evaluates configuration options related to the POSIX API objects configuration.
This header file evaluates configuration options related to obsolete configuration options.
This header file evaluates configuration options related to the thread configuration.
