RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
test.h File Reference
This header file provides interfaces of the RTEMS Test Framework. More...
#include <stdarg.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdint.h>
struct  T_fixture
struct  T_fixture_node
struct  T_remark
struct  T_case_context
struct  T_check_context
struct  T_check_context_msg
struct  T_config
struct  T_interrupt_test_config
struct  T_thread_switch_event
struct  T_thread_switch_header
struct  T_thread_switch_log
struct  T_thread_switch_log_2
struct  T_thread_switch_log_4
struct  T_thread_switch_log_10
struct  T_destructor
struct  T_measure_runtime_config
struct  T_measure_runtime_request
#define T_ARRAY_SIZE(array)   (sizeof(array) / sizeof((array)[0]))
#define T_FILE_NAME   __FILE__
#define T_ZERO_LENGTH_ARRAY   1
#define T_NO_RETURN   _Noreturn
#define T_CHECK_STOP   1U
#define T_CHECK_QUIET   2U
#define T_CHECK_FMT   4U
#define T_CHECK_STEP_FLAG   8U
#define T_CHECK_STEP_TO_FLAGS(step)   ((unsigned int)(step) << 8)
#define T_CHECK_STEP_FROM_FLAGS(flags)   ((flags) >> 8)
#define T_CHECK_STEP(step)   (T_CHECK_STEP_TO_FLAGS(step) | T_CHECK_STEP_FLAG)
#define T_VA_ARGS_FIRST(...)   T_VA_ARGS_FIRST_SELECT(__VA_ARGS__, throw_away)
#define T_VA_ARGS_FIRST_SELECT(first, ...)   first
#define T_VA_ARGS_MORE(...)    T_VA_ARGS_XEXPAND(T_VA_ARGS_KIND(__VA_ARGS__), __VA_ARGS__)
#define T_VA_ARGS_XEXPAND(kind, ...)   T_VA_ARGS_EXPAND(kind, __VA_ARGS__)
#define T_VA_ARGS_EXPAND(kind, ...)   T_VA_ARGS_EXPAND_##kind(__VA_ARGS__)
#define T_VA_ARGS_EXPAND_0U(first)
#define T_VA_ARGS_EXPAND_4U(first, ...)   , __VA_ARGS__
#define T_VA_ARGS_KIND(...)
#define T_VA_ARGS_SELECT(a1, a2, a3, a4, a5, a6, a7, a8, a9, a10, ...)   a10
#define T_flags_true(flags, ...)
#define T_flags_eq(flags, a, ...)
#define T_flags_ne(flags, a, ...)
#define T_flags_eq_ptr(a, e, flags, sa, se)
#define T_flags_ne_ptr(a, e, flags, sa, se)
#define T_flags_null(a, flags, sa)
#define T_flags_not_null(a, flags, sa)
#define T_flags_eq_mem(a, e, n, flags, sa, se, sn)
#define T_flags_ne_mem(a, e, n, flags, sa, se, sn)
#define T_flags_eq_str(a, e, flags)
#define T_flags_ne_str(a, e, flags)
#define T_flags_eq_nstr(a, e, n, flags)
#define T_flags_ne_nstr(a, e, n, flags)
#define T_flags_eq_char(a, e, flags)
#define T_flags_ne_char(a, e, flags)
#define T_flags_eq_int(a, e, flags)
#define T_flags_ne_int(a, e, flags)
#define T_flags_ge_int(a, e, flags)
#define T_flags_gt_int(a, e, flags)
#define T_flags_le_int(a, e, flags)
#define T_flags_lt_int(a, e, flags)
#define T_flags_eq_uint(a, e, flags)
#define T_flags_ne_uint(a, e, flags)
#define T_flags_ge_uint(a, e, flags)
#define T_flags_gt_uint(a, e, flags)
#define T_flags_le_uint(a, e, flags)
#define T_flags_lt_uint(a, e, flags)
#define T_flags_eq_long(a, e, flags)
#define T_flags_ne_long(a, e, flags)
#define T_flags_ge_long(a, e, flags)
#define T_flags_gt_long(a, e, flags)
#define T_flags_le_long(a, e, flags)
#define T_flags_lt_long(a, e, flags)
#define T_flags_eq_ulong(a, e, flags)
#define T_flags_ne_ulong(a, e, flags)
#define T_flags_ge_ulong(a, e, flags)
#define T_flags_gt_ulong(a, e, flags)
#define T_flags_le_ulong(a, e, flags)
#define T_flags_lt_ulong(a, e, flags)
#define T_flags_eq_ll(a, e, flags)
#define T_flags_ne_ll(a, e, flags)
#define T_flags_ge_ll(a, e, flags)
#define T_flags_gt_ll(a, e, flags)
#define T_flags_le_ll(a, e, flags)
#define T_flags_lt_ll(a, e, flags)
#define T_flags_eq_ull(a, e, flags)
#define T_flags_ne_ull(a, e, flags)
#define T_flags_ge_ull(a, e, flags)
#define T_flags_gt_ull(a, e, flags)
#define T_flags_le_ull(a, e, flags)
#define T_flags_lt_ull(a, e, flags)
#define T_flags_eno(a, e, flags)
#define T_flags_eno_success(a, flags)
#define T_flags_psx_error(a, eno, flags)
#define T_flags_psx_success(a, flags)
#define T_true(...)   T_flags_true(0, __VA_ARGS__)
#define T_assert_true(...)   T_flags_true(T_CHECK_STOP, __VA_ARGS__)
#define T_quiet_true(...)   T_flags_true(T_CHECK_QUIET, __VA_ARGS__)
#define T_step_true(s, ...)   T_flags_true(T_CHECK_STEP(s), __VA_ARGS__)
#define T_step_assert_true(s, ...)    T_flags_true(T_CHECK_STEP(s) | T_CHECK_STOP, __VA_ARGS__)
#define T_false(...)
#define T_assert_false(...)
#define T_quiet_false(...)
#define T_step_false(s, ...)
#define T_step_assert_false(s, ...)
#define T_eq(a, ...)   T_flags_eq(0, a, __VA_ARGS__)
#define T_assert_eq(a, ...)   T_flags_eq(T_CHECK_STOP, a, __VA_ARGS__)
#define T_quiet_eq(a, ...)   T_flags_eq(T_CHECK_QUIET, a, __VA_ARGS__)
#define T_step_eq(s, a, ...)   T_flags_eq(T_CHECK_STEP(s), a, __VA_ARGS__)
#define T_step_assert_eq(s, a, ...)    T_flags_eq(T_CHECK_STEP(s) | T_CHECK_STOP, a, __VA_ARGS__)
#define T_ne(a, ...)   T_flags_ne(0, a, __VA_ARGS__)
#define T_assert_ne(a, ...)   T_flags_ne(T_CHECK_STOP, a, __VA_ARGS__)
#define T_quiet_ne(a, ...)   T_flags_ne(T_CHECK_QUIET, a, __VA_ARGS__)
#define T_step_ne(s, a, ...)   T_flags_ne(T_CHECK_STEP(s), a, __VA_ARGS__)
#define T_step_assert_ne(s, a, ...)    T_flags_ne(T_CHECK_STEP(s) | T_CHECK_STOP, a, __VA_ARGS__)
#define T_eq_ptr(a, e)   T_flags_eq_ptr(a, e, 0, #a, #e)
#define T_assert_eq_ptr(a, e)   T_flags_eq_ptr(a, e, T_CHECK_STOP, #a, #e)
#define T_quiet_eq_ptr(a, e)   T_flags_eq_ptr(a, e, T_CHECK_QUIET, #a, #e)
#define T_step_eq_ptr(s, a, e)   T_flags_eq_ptr(a, e, T_CHECK_STEP(s), #a, #e)
#define T_step_assert_eq_ptr(s, a, e)    T_flags_eq_ptr(a, e, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e)
#define T_ne_ptr(a, e)   T_flags_ne_ptr(a, e, 0, #a, #e)
#define T_assert_ne_ptr(a, e)   T_flags_ne_ptr(a, e, T_CHECK_STOP, #a, #e)
#define T_quiet_ne_ptr(a, e)   T_flags_ne_ptr(a, e, T_CHECK_QUIET, #a, #e)
#define T_step_ne_ptr(s, a, e)   T_flags_ne_ptr(a, e, T_CHECK_STEP(s), #a, #e)
#define T_step_assert_ne_ptr(s, a, e)    T_flags_ne_ptr(a, e, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e)
#define T_null(a)   T_flags_null(a, 0, #a)
#define T_assert_null(a)   T_flags_null(a, T_CHECK_STOP, #a)
#define T_quiet_null(a)   T_flags_null(a, T_CHECK_QUIET, #a)
#define T_quiet_assert_null(a)    T_flags_null(a, T_CHECK_QUIET | T_CHECK_STOP, #a)
#define T_step_null(s, a)   T_flags_null(a, T_CHECK_STEP(s), #a)
#define T_step_assert_null(s, a)    T_flags_null(a, T_CHECK_STEP(s) | T_CHECK_STOP, #a)
#define T_not_null(a)   T_flags_not_null(a, 0, #a)
#define T_assert_not_null(a)   T_flags_not_null(a, T_CHECK_STOP, #a)
#define T_quiet_not_null(a)   T_flags_not_null(a, T_CHECK_QUIET, #a)
#define T_quiet_assert_not_null(a)    T_flags_not_null(a, T_CHECK_QUIET | T_CHECK_STOP, #a)
#define T_step_not_null(s, a)   T_flags_not_null(a, T_CHECK_STEP(s), #a)
#define T_step_assert_not_null(s, a)    T_flags_not_null(a, T_CHECK_STEP(s) | T_CHECK_STOP, #a)
#define T_eq_mem(a, e, n)   T_flags_eq_mem(a, e, n, 0, #a, #e, #n)
#define T_assert_eq_mem(a, e, n)    T_flags_eq_mem(a, e, n, T_CHECK_STOP, #a, #e, #n)
#define T_quiet_eq_mem(a, e, n)    T_flags_eq_mem(a, e, n, T_CHECK_QUIET, #a, #e, #n)
#define T_step_eq_mem(s, a, e, n)    T_flags_eq_mem(a, e, n, T_CHECK_STEP(s), #a, #e, #n)
#define T_step_assert_eq_mem(s, a, e, n)    T_flags_eq_mem(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e, #n)
#define T_ne_mem(a, e, n)   T_flags_ne_mem(a, e, n, 0, #a, #e, #n)
#define T_assert_ne_mem(a, e, n)    T_flags_ne_mem(a, e, n, T_CHECK_STOP, #a, #e, #n)
#define T_quiet_ne_mem(a, e, n)    T_flags_ne_mem(a, e, n, T_CHECK_QUIET, #a, #e, #n)
#define T_step_ne_mem(s, a, e, n)    T_flags_ne_mem(a, e, n, T_CHECK_STEP(s), #a, #e, #n)
#define T_step_assert_ne_mem(s, a, e, n)    T_flags_ne_mem(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP, #a, #e, #n)
#define T_eq_str(a, e)   T_flags_eq_str(a, e, 0)
#define T_assert_eq_str(a, e)   T_flags_eq_str(a, e, T_CHECK_STOP)
#define T_quiet_eq_str(a, e)   T_flags_eq_str(a, e, T_CHECK_QUIET)
#define T_step_eq_str(s, a, e)   T_flags_eq_str(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_str(s, a, e)    T_flags_eq_str(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_str(a, e)   T_flags_ne_str(a, e, 0)
#define T_assert_ne_str(a, e)   T_flags_ne_str(a, e, T_CHECK_STOP)
#define T_quiet_ne_str(a, e)   T_flags_ne_str(a, e, T_CHECK_QUIET)
#define T_step_ne_str(s, a, e)   T_flags_ne_str(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_str(s, a, e)    T_flags_ne_str(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_nstr(a, e, n)   T_flags_eq_nstr(a, e, n, 0)
#define T_assert_eq_nstr(a, e, n)   T_flags_eq_nstr(a, e, n, T_CHECK_STOP)
#define T_quiet_eq_nstr(a, e, n)   T_flags_eq_nstr(a, e, n, T_CHECK_QUIET)
#define T_step_eq_nstr(s, a, e, n)   T_flags_eq_nstr(a, e, n, T_CHECK_STEP(s))
#define T_step_assert_eq_nstr(s, a, e, n)    T_flags_eq_nstr(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_nstr(a, e, n)   T_flags_ne_nstr(a, e, n, 0)
#define T_assert_ne_nstr(a, e, n)   T_flags_ne_nstr(a, e, n, T_CHECK_STOP)
#define T_quiet_ne_nstr(a, e, n)   T_flags_ne_nstr(a, e, n, T_CHECK_QUIET)
#define T_step_ne_nstr(s, a, e, n)   T_flags_ne_nstr(a, e, n, T_CHECK_STEP(s))
#define T_step_assert_ne_nstr(s, a, e, n)    T_flags_ne_nstr(a, e, n, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_char(a, e)   T_flags_eq_char(a, e, 0)
#define T_assert_eq_char(a, e)   T_flags_eq_char(a, e, T_CHECK_STOP)
#define T_quiet_eq_char(a, e)   T_flags_eq_char(a, e, T_CHECK_QUIET)
#define T_step_eq_char(s, a, e)   T_flags_eq_char(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_char(s, a, e)    T_flags_eq_char(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_char(a, e)   T_flags_ne_char(a, e, 0)
#define T_assert_ne_char(a, e)   T_flags_ne_char(a, e, T_CHECK_STOP)
#define T_quiet_ne_char(a, e)   T_flags_ne_char(a, e, T_CHECK_QUIET)
#define T_step_ne_char(s, a, e)   T_flags_ne_char(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_char(s, a, e)    T_flags_ne_char(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_schar(a, e)   T_flags_eq_int(a, e, 0)
#define T_assert_eq_schar(a, e)   T_flags_eq_int(a, e, T_CHECK_STOP)
#define T_quiet_eq_schar(a, e)   T_flags_eq_int(a, e, T_CHECK_QUIET)
#define T_step_eq_schar(s, a, e)   T_flags_eq_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_schar(s, a, e)    T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_schar(a, e)   T_flags_ne_int(a, e, 0)
#define T_assert_ne_schar(a, e)   T_flags_ne_int(a, e, T_CHECK_STOP)
#define T_quiet_ne_schar(a, e)   T_flags_ne_int(a, e, T_CHECK_QUIET)
#define T_step_ne_schar(s, a, e)   T_flags_ne_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_schar(s, a, e)    T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_schar(a, e)   T_flags_ge_int(a, e, 0)
#define T_assert_ge_schar(a, e)   T_flags_ge_int(a, e, T_CHECK_STOP)
#define T_quiet_ge_schar(a, e)   T_flags_ge_int(a, e, T_CHECK_QUIET)
#define T_step_ge_schar(s, a, e)   T_flags_ge_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_schar(s, a, e)    T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_schar(a, e)   T_flags_gt_int(a, e, 0)
#define T_assert_gt_schar(a, e)   T_flags_gt_int(a, e, T_CHECK_STOP)
#define T_quiet_gt_schar(a, e)   T_flags_gt_int(a, e, T_CHECK_QUIET)
#define T_step_gt_schar(s, a, e)   T_flags_gt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_schar(s, a, e)    T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_schar(a, e)   T_flags_le_int(a, e, 0)
#define T_assert_le_schar(a, e)   T_flags_le_int(a, e, T_CHECK_STOP)
#define T_quiet_le_schar(a, e)   T_flags_le_int(a, e, T_CHECK_QUIET)
#define T_step_le_schar(s, a, e)   T_flags_le_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_schar(s, a, e)    T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_schar(a, e)   T_flags_lt_int(a, e, 0)
#define T_assert_lt_schar(a, e)   T_flags_lt_int(a, e, T_CHECK_STOP)
#define T_quiet_lt_schar(a, e)   T_flags_lt_int(a, e, T_CHECK_QUIET)
#define T_step_lt_schar(s, a, e)   T_flags_lt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_schar(s, a, e)    T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_uchar(a, e)   T_flags_eq_uint(a, e, 0)
#define T_assert_eq_uchar(a, e)   T_flags_eq_uint(a, e, T_CHECK_STOP)
#define T_quiet_eq_uchar(a, e)   T_flags_eq_uint(a, e, T_CHECK_QUIET)
#define T_step_eq_uchar(s, a, e)   T_flags_eq_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_uchar(s, a, e)    T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_uchar(a, e)   T_flags_ne_uint(a, e, 0)
#define T_assert_ne_uchar(a, e)   T_flags_ne_uint(a, e, T_CHECK_STOP)
#define T_quiet_ne_uchar(a, e)   T_flags_ne_uint(a, e, T_CHECK_QUIET)
#define T_step_ne_uchar(s, a, e)   T_flags_ne_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_uchar(s, a, e)    T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_uchar(a, e)   T_flags_ge_uint(a, e, 0)
#define T_assert_ge_uchar(a, e)   T_flags_ge_uint(a, e, T_CHECK_STOP)
#define T_quiet_ge_uchar(a, e)   T_flags_ge_uint(a, e, T_CHECK_QUIET)
#define T_step_ge_uchar(s, a, e)   T_flags_ge_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_uchar(s, a, e)    T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_uchar(a, e)   T_flags_gt_uint(a, e, 0)
#define T_assert_gt_uchar(a, e)   T_flags_gt_uint(a, e, T_CHECK_STOP)
#define T_quiet_gt_uchar(a, e)   T_flags_gt_uint(a, e, T_CHECK_QUIET)
#define T_step_gt_uchar(s, a, e)   T_flags_gt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_uchar(s, a, e)    T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_uchar(a, e)   T_flags_le_uint(a, e, 0)
#define T_assert_le_uchar(a, e)   T_flags_le_uint(a, e, T_CHECK_STOP)
#define T_quiet_le_uchar(a, e)   T_flags_le_uint(a, e, T_CHECK_QUIET)
#define T_step_le_uchar(s, a, e)   T_flags_le_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_uchar(s, a, e)    T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_uchar(a, e)   T_flags_lt_uint(a, e, 0)
#define T_assert_lt_uchar(a, e)   T_flags_lt_uint(a, e, T_CHECK_STOP)
#define T_quiet_lt_uchar(a, e)   T_flags_lt_uint(a, e, T_CHECK_QUIET)
#define T_step_lt_uchar(s, a, e)   T_flags_lt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_uchar(s, a, e)    T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_short(a, e)   T_flags_eq_int(a, e, 0)
#define T_assert_eq_short(a, e)   T_flags_eq_int(a, e, T_CHECK_STOP)
#define T_quiet_eq_short(a, e)   T_flags_eq_int(a, e, T_CHECK_QUIET)
#define T_step_eq_short(s, a, e)   T_flags_eq_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_short(s, a, e)    T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_short(a, e)   T_flags_ne_int(a, e, 0)
#define T_assert_ne_short(a, e)   T_flags_ne_int(a, e, T_CHECK_STOP)
#define T_quiet_ne_short(a, e)   T_flags_ne_int(a, e, T_CHECK_QUIET)
#define T_step_ne_short(s, a, e)   T_flags_ne_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_short(s, a, e)    T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_short(a, e)   T_flags_ge_int(a, e, 0)
#define T_assert_ge_short(a, e)   T_flags_ge_int(a, e, T_CHECK_STOP)
#define T_quiet_ge_short(a, e)   T_flags_ge_int(a, e, T_CHECK_QUIET)
#define T_step_ge_short(s, a, e)   T_flags_ge_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_short(s, a, e)    T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_short(a, e)   T_flags_gt_int(a, e, 0)
#define T_assert_gt_short(a, e)   T_flags_gt_int(a, e, T_CHECK_STOP)
#define T_quiet_gt_short(a, e)   T_flags_gt_int(a, e, T_CHECK_QUIET)
#define T_step_gt_short(s, a, e)   T_flags_gt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_short(s, a, e)    T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_short(a, e)   T_flags_le_int(a, e, 0)
#define T_assert_le_short(a, e)   T_flags_le_int(a, e, T_CHECK_STOP)
#define T_quiet_le_short(a, e)   T_flags_le_int(a, e, T_CHECK_QUIET)
#define T_step_le_short(s, a, e)   T_flags_le_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_short(s, a, e)    T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_short(a, e)   T_flags_lt_int(a, e, 0)
#define T_assert_lt_short(a, e)   T_flags_lt_int(a, e, T_CHECK_STOP)
#define T_quiet_lt_short(a, e)   T_flags_lt_int(a, e, T_CHECK_QUIET)
#define T_step_lt_short(s, a, e)   T_flags_lt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_short(s, a, e)    T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_ushort(a, e)   T_flags_eq_uint(a, e, 0)
#define T_assert_eq_ushort(a, e)   T_flags_eq_uint(a, e, T_CHECK_STOP)
#define T_quiet_eq_ushort(a, e)   T_flags_eq_uint(a, e, T_CHECK_QUIET)
#define T_step_eq_ushort(s, a, e)   T_flags_eq_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_ushort(s, a, e)    T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_ushort(a, e)   T_flags_ne_uint(a, e, 0)
#define T_assert_ne_ushort(a, e)   T_flags_ne_uint(a, e, T_CHECK_STOP)
#define T_quiet_ne_ushort(a, e)   T_flags_ne_uint(a, e, T_CHECK_QUIET)
#define T_step_ne_ushort(s, a, e)   T_flags_ne_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_ushort(s, a, e)    T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_ushort(a, e)   T_flags_ge_uint(a, e, 0)
#define T_assert_ge_ushort(a, e)   T_flags_ge_uint(a, e, T_CHECK_STOP)
#define T_quiet_ge_ushort(a, e)   T_flags_ge_uint(a, e, T_CHECK_QUIET)
#define T_step_ge_ushort(s, a, e)   T_flags_ge_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_ushort(s, a, e)    T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_ushort(a, e)   T_flags_gt_uint(a, e, 0)
#define T_assert_gt_ushort(a, e)   T_flags_gt_uint(a, e, T_CHECK_STOP)
#define T_quiet_gt_ushort(a, e)   T_flags_gt_uint(a, e, T_CHECK_QUIET)
#define T_step_gt_ushort(s, a, e)   T_flags_gt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_ushort(s, a, e)    T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_ushort(a, e)   T_flags_le_uint(a, e, 0)
#define T_assert_le_ushort(a, e)   T_flags_le_uint(a, e, T_CHECK_STOP)
#define T_quiet_le_ushort(a, e)   T_flags_le_uint(a, e, T_CHECK_QUIET)
#define T_step_le_ushort(s, a, e)   T_flags_le_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_ushort(s, a, e)    T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_ushort(a, e)   T_flags_lt_uint(a, e, 0)
#define T_assert_lt_ushort(a, e)   T_flags_lt_uint(a, e, T_CHECK_STOP)
#define T_quiet_lt_ushort(a, e)   T_flags_lt_uint(a, e, T_CHECK_QUIET)
#define T_step_lt_ushort(s, a, e)   T_flags_lt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_ushort(s, a, e)    T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_int(a, e)   T_flags_eq_int(a, e, 0)
#define T_assert_eq_int(a, e)   T_flags_eq_int(a, e, T_CHECK_STOP)
#define T_quiet_eq_int(a, e)   T_flags_eq_int(a, e, T_CHECK_QUIET)
#define T_step_eq_int(s, a, e)   T_flags_eq_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_int(s, a, e)    T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_int(a, e)   T_flags_ne_int(a, e, 0)
#define T_assert_ne_int(a, e)   T_flags_ne_int(a, e, T_CHECK_STOP)
#define T_quiet_ne_int(a, e)   T_flags_ne_int(a, e, T_CHECK_QUIET)
#define T_step_ne_int(s, a, e)   T_flags_ne_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_int(s, a, e)    T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_int(a, e)   T_flags_ge_int(a, e, 0)
#define T_assert_ge_int(a, e)   T_flags_ge_int(a, e, T_CHECK_STOP)
#define T_quiet_ge_int(a, e)   T_flags_ge_int(a, e, T_CHECK_QUIET)
#define T_step_ge_int(s, a, e)   T_flags_ge_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_int(s, a, e)    T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_int(a, e)   T_flags_gt_int(a, e, 0)
#define T_assert_gt_int(a, e)   T_flags_gt_int(a, e, T_CHECK_STOP)
#define T_quiet_gt_int(a, e)   T_flags_gt_int(a, e, T_CHECK_QUIET)
#define T_step_gt_int(s, a, e)   T_flags_gt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_int(s, a, e)    T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_int(a, e)   T_flags_le_int(a, e, 0)
#define T_assert_le_int(a, e)   T_flags_le_int(a, e, T_CHECK_STOP)
#define T_quiet_le_int(a, e)   T_flags_le_int(a, e, T_CHECK_QUIET)
#define T_step_le_int(s, a, e)   T_flags_le_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_int(s, a, e)    T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_int(a, e)   T_flags_lt_int(a, e, 0)
#define T_assert_lt_int(a, e)   T_flags_lt_int(a, e, T_CHECK_STOP)
#define T_quiet_lt_int(a, e)   T_flags_lt_int(a, e, T_CHECK_QUIET)
#define T_step_lt_int(s, a, e)   T_flags_lt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_int(s, a, e)    T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_uint(a, e)   T_flags_eq_uint(a, e, 0)
#define T_assert_eq_uint(a, e)   T_flags_eq_uint(a, e, T_CHECK_STOP)
#define T_quiet_eq_uint(a, e)   T_flags_eq_uint(a, e, T_CHECK_QUIET)
#define T_step_eq_uint(s, a, e)   T_flags_eq_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_uint(s, a, e)    T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_uint(a, e)   T_flags_ne_uint(a, e, 0)
#define T_assert_ne_uint(a, e)   T_flags_ne_uint(a, e, T_CHECK_STOP)
#define T_quiet_ne_uint(a, e)   T_flags_ne_uint(a, e, T_CHECK_QUIET)
#define T_step_ne_uint(s, a, e)   T_flags_ne_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_uint(s, a, e)    T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_uint(a, e)   T_flags_ge_uint(a, e, 0)
#define T_assert_ge_uint(a, e)   T_flags_ge_uint(a, e, T_CHECK_STOP)
#define T_quiet_ge_uint(a, e)   T_flags_ge_uint(a, e, T_CHECK_QUIET)
#define T_step_ge_uint(s, a, e)   T_flags_ge_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_uint(s, a, e)    T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_uint(a, e)   T_flags_gt_uint(a, e, 0)
#define T_assert_gt_uint(a, e)   T_flags_gt_uint(a, e, T_CHECK_STOP)
#define T_quiet_gt_uint(a, e)   T_flags_gt_uint(a, e, T_CHECK_QUIET)
#define T_step_gt_uint(s, a, e)   T_flags_gt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_uint(s, a, e)    T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_uint(a, e)   T_flags_le_uint(a, e, 0)
#define T_assert_le_uint(a, e)   T_flags_le_uint(a, e, T_CHECK_STOP)
#define T_quiet_le_uint(a, e)   T_flags_le_uint(a, e, T_CHECK_QUIET)
#define T_step_le_uint(s, a, e)   T_flags_le_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_uint(s, a, e)    T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_uint(a, e)   T_flags_lt_uint(a, e, 0)
#define T_assert_lt_uint(a, e)   T_flags_lt_uint(a, e, T_CHECK_STOP)
#define T_quiet_lt_uint(a, e)   T_flags_lt_uint(a, e, T_CHECK_QUIET)
#define T_step_lt_uint(s, a, e)   T_flags_lt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_uint(s, a, e)    T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_long(a, e)   T_flags_eq_long(a, e, 0)
#define T_assert_eq_long(a, e)   T_flags_eq_long(a, e, T_CHECK_STOP)
#define T_quiet_eq_long(a, e)   T_flags_eq_long(a, e, T_CHECK_QUIET)
#define T_step_eq_long(s, a, e)   T_flags_eq_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_long(s, a, e)    T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_long(a, e)   T_flags_ne_long(a, e, 0)
#define T_assert_ne_long(a, e)   T_flags_ne_long(a, e, T_CHECK_STOP)
#define T_quiet_ne_long(a, e)   T_flags_ne_long(a, e, T_CHECK_QUIET)
#define T_step_ne_long(s, a, e)   T_flags_ne_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_long(s, a, e)    T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_long(a, e)   T_flags_ge_long(a, e, 0)
#define T_assert_ge_long(a, e)   T_flags_ge_long(a, e, T_CHECK_STOP)
#define T_quiet_ge_long(a, e)   T_flags_ge_long(a, e, T_CHECK_QUIET)
#define T_step_ge_long(s, a, e)   T_flags_ge_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_long(s, a, e)    T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_long(a, e)   T_flags_gt_long(a, e, 0)
#define T_assert_gt_long(a, e)   T_flags_gt_long(a, e, T_CHECK_STOP)
#define T_quiet_gt_long(a, e)   T_flags_gt_long(a, e, T_CHECK_QUIET)
#define T_step_gt_long(s, a, e)   T_flags_gt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_long(s, a, e)    T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_long(a, e)   T_flags_le_long(a, e, 0)
#define T_assert_le_long(a, e)   T_flags_le_long(a, e, T_CHECK_STOP)
#define T_quiet_le_long(a, e)   T_flags_le_long(a, e, T_CHECK_QUIET)
#define T_step_le_long(s, a, e)   T_flags_le_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_long(s, a, e)    T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_long(a, e)   T_flags_lt_long(a, e, 0)
#define T_assert_lt_long(a, e)   T_flags_lt_long(a, e, T_CHECK_STOP)
#define T_quiet_lt_long(a, e)   T_flags_lt_long(a, e, T_CHECK_QUIET)
#define T_step_lt_long(s, a, e)   T_flags_lt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_long(s, a, e)    T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_ulong(a, e)   T_flags_eq_ulong(a, e, 0)
#define T_assert_eq_ulong(a, e)   T_flags_eq_ulong(a, e, T_CHECK_STOP)
#define T_quiet_eq_ulong(a, e)   T_flags_eq_ulong(a, e, T_CHECK_QUIET)
#define T_step_eq_ulong(s, a, e)   T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_ulong(s, a, e)    T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_ulong(a, e)   T_flags_ne_ulong(a, e, 0)
#define T_assert_ne_ulong(a, e)   T_flags_ne_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ne_ulong(a, e)   T_flags_ne_ulong(a, e, T_CHECK_QUIET)
#define T_step_ne_ulong(s, a, e)   T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_ulong(s, a, e)    T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_ulong(a, e)   T_flags_ge_ulong(a, e, 0)
#define T_assert_ge_ulong(a, e)   T_flags_ge_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ge_ulong(a, e)   T_flags_ge_ulong(a, e, T_CHECK_QUIET)
#define T_step_ge_ulong(s, a, e)   T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_ulong(s, a, e)    T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_ulong(a, e)   T_flags_gt_ulong(a, e, 0)
#define T_assert_gt_ulong(a, e)   T_flags_gt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_gt_ulong(a, e)   T_flags_gt_ulong(a, e, T_CHECK_QUIET)
#define T_step_gt_ulong(s, a, e)   T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_ulong(s, a, e)    T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_ulong(a, e)   T_flags_le_ulong(a, e, 0)
#define T_assert_le_ulong(a, e)   T_flags_le_ulong(a, e, T_CHECK_STOP)
#define T_quiet_le_ulong(a, e)   T_flags_le_ulong(a, e, T_CHECK_QUIET)
#define T_step_le_ulong(s, a, e)   T_flags_le_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_ulong(s, a, e)    T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_ulong(a, e)   T_flags_lt_ulong(a, e, 0)
#define T_assert_lt_ulong(a, e)   T_flags_lt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_lt_ulong(a, e)   T_flags_lt_ulong(a, e, T_CHECK_QUIET)
#define T_step_lt_ulong(s, a, e)   T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_ulong(s, a, e)    T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_ll(a, e)   T_flags_eq_ll(a, e, 0)
#define T_assert_eq_ll(a, e)   T_flags_eq_ll(a, e, T_CHECK_STOP)
#define T_quiet_eq_ll(a, e)   T_flags_eq_ll(a, e, T_CHECK_QUIET)
#define T_step_eq_ll(s, a, e)   T_flags_eq_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_ll(s, a, e)    T_flags_eq_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_ll(a, e)   T_flags_ne_ll(a, e, 0)
#define T_assert_ne_ll(a, e)   T_flags_ne_ll(a, e, T_CHECK_STOP)
#define T_quiet_ne_ll(a, e)   T_flags_ne_ll(a, e, T_CHECK_QUIET)
#define T_step_ne_ll(s, a, e)   T_flags_ne_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_ll(s, a, e)    T_flags_ne_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_ll(a, e)   T_flags_ge_ll(a, e, 0)
#define T_assert_ge_ll(a, e)   T_flags_ge_ll(a, e, T_CHECK_STOP)
#define T_quiet_ge_ll(a, e)   T_flags_ge_ll(a, e, T_CHECK_QUIET)
#define T_step_ge_ll(s, a, e)   T_flags_ge_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_ll(s, a, e)    T_flags_ge_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_ll(a, e)   T_flags_gt_ll(a, e, 0)
#define T_assert_gt_ll(a, e)   T_flags_gt_ll(a, e, T_CHECK_STOP)
#define T_quiet_gt_ll(a, e)   T_flags_gt_ll(a, e, T_CHECK_QUIET)
#define T_step_gt_ll(s, a, e)   T_flags_gt_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_ll(s, a, e)    T_flags_gt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_ll(a, e)   T_flags_le_ll(a, e, 0)
#define T_assert_le_ll(a, e)   T_flags_le_ll(a, e, T_CHECK_STOP)
#define T_quiet_le_ll(a, e)   T_flags_le_ll(a, e, T_CHECK_QUIET)
#define T_step_le_ll(s, a, e)   T_flags_le_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_ll(s, a, e)    T_flags_le_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_ll(a, e)   T_flags_lt_ll(a, e, 0)
#define T_assert_lt_ll(a, e)   T_flags_lt_ll(a, e, T_CHECK_STOP)
#define T_quiet_lt_ll(a, e)   T_flags_lt_ll(a, e, T_CHECK_QUIET)
#define T_step_lt_ll(s, a, e)   T_flags_lt_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_ll(s, a, e)    T_flags_lt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_ull(a, e)   T_flags_eq_ull(a, e, 0)
#define T_assert_eq_ull(a, e)   T_flags_eq_ull(a, e, T_CHECK_STOP)
#define T_quiet_eq_ull(a, e)   T_flags_eq_ull(a, e, T_CHECK_QUIET)
#define T_step_eq_ull(s, a, e)   T_flags_eq_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_ull(s, a, e)    T_flags_eq_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_ull(a, e)   T_flags_ne_ull(a, e, 0)
#define T_assert_ne_ull(a, e)   T_flags_ne_ull(a, e, T_CHECK_STOP)
#define T_quiet_ne_ull(a, e)   T_flags_ne_ull(a, e, T_CHECK_QUIET)
#define T_step_ne_ull(s, a, e)   T_flags_ne_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_ull(s, a, e)    T_flags_ne_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_ull(a, e)   T_flags_ge_ull(a, e, 0)
#define T_assert_ge_ull(a, e)   T_flags_ge_ull(a, e, T_CHECK_STOP)
#define T_quiet_ge_ull(a, e)   T_flags_ge_ull(a, e, T_CHECK_QUIET)
#define T_step_ge_ull(s, a, e)   T_flags_ge_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_ull(s, a, e)    T_flags_ge_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_ull(a, e)   T_flags_gt_ull(a, e, 0)
#define T_assert_gt_ull(a, e)   T_flags_gt_ull(a, e, T_CHECK_STOP)
#define T_quiet_gt_ull(a, e)   T_flags_gt_ull(a, e, T_CHECK_QUIET)
#define T_step_gt_ull(s, a, e)   T_flags_gt_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_ull(s, a, e)    T_flags_gt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_ull(a, e)   T_flags_le_ull(a, e, 0)
#define T_assert_le_ull(a, e)   T_flags_le_ull(a, e, T_CHECK_STOP)
#define T_quiet_le_ull(a, e)   T_flags_le_ull(a, e, T_CHECK_QUIET)
#define T_step_le_ull(s, a, e)   T_flags_le_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_ull(s, a, e)    T_flags_le_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_ull(a, e)   T_flags_lt_ull(a, e, 0)
#define T_assert_lt_ull(a, e)   T_flags_lt_ull(a, e, T_CHECK_STOP)
#define T_quiet_lt_ull(a, e)   T_flags_lt_ull(a, e, T_CHECK_QUIET)
#define T_step_lt_ull(s, a, e)   T_flags_lt_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_ull(s, a, e)    T_flags_lt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_i8(a, e)   T_flags_eq_int(a, e, 0)
#define T_assert_eq_i8(a, e)   T_flags_eq_int(a, e, T_CHECK_STOP)
#define T_quiet_eq_i8(a, e)   T_flags_eq_int(a, e, T_CHECK_QUIET)
#define T_step_eq_i8(s, a, e)   T_flags_eq_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_i8(s, a, e)    T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_i8(a, e)   T_flags_ne_int(a, e, 0)
#define T_assert_ne_i8(a, e)   T_flags_ne_int(a, e, T_CHECK_STOP)
#define T_quiet_ne_i8(a, e)   T_flags_ne_int(a, e, T_CHECK_QUIET)
#define T_step_ne_i8(s, a, e)   T_flags_ne_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_i8(s, a, e)    T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_i8(a, e)   T_flags_ge_int(a, e, 0)
#define T_assert_ge_i8(a, e)   T_flags_ge_int(a, e, T_CHECK_STOP)
#define T_quiet_ge_i8(a, e)   T_flags_ge_int(a, e, T_CHECK_QUIET)
#define T_step_ge_i8(s, a, e)   T_flags_ge_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_i8(s, a, e)    T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_i8(a, e)   T_flags_gt_int(a, e, 0)
#define T_assert_gt_i8(a, e)   T_flags_gt_int(a, e, T_CHECK_STOP)
#define T_quiet_gt_i8(a, e)   T_flags_gt_int(a, e, T_CHECK_QUIET)
#define T_step_gt_i8(s, a, e)   T_flags_gt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_i8(s, a, e)    T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_i8(a, e)   T_flags_le_int(a, e, 0)
#define T_assert_le_i8(a, e)   T_flags_le_int(a, e, T_CHECK_STOP)
#define T_quiet_le_i8(a, e)   T_flags_le_int(a, e, T_CHECK_QUIET)
#define T_step_le_i8(s, a, e)   T_flags_le_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_i8(s, a, e)    T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_i8(a, e)   T_flags_lt_int(a, e, 0)
#define T_assert_lt_i8(a, e)   T_flags_lt_int(a, e, T_CHECK_STOP)
#define T_quiet_lt_i8(a, e)   T_flags_lt_int(a, e, T_CHECK_QUIET)
#define T_step_lt_i8(s, a, e)   T_flags_lt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_i8(s, a, e)    T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_u8(a, e)   T_flags_eq_uint(a, e, 0)
#define T_assert_eq_u8(a, e)   T_flags_eq_uint(a, e, T_CHECK_STOP)
#define T_quiet_eq_u8(a, e)   T_flags_eq_uint(a, e, T_CHECK_QUIET)
#define T_step_eq_u8(s, a, e)   T_flags_eq_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_u8(s, a, e)    T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_u8(a, e)   T_flags_ne_uint(a, e, 0)
#define T_assert_ne_u8(a, e)   T_flags_ne_uint(a, e, T_CHECK_STOP)
#define T_quiet_ne_u8(a, e)   T_flags_ne_uint(a, e, T_CHECK_QUIET)
#define T_step_ne_u8(s, a, e)   T_flags_ne_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_u8(s, a, e)    T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_u8(a, e)   T_flags_ge_uint(a, e, 0)
#define T_assert_ge_u8(a, e)   T_flags_ge_uint(a, e, T_CHECK_STOP)
#define T_quiet_ge_u8(a, e)   T_flags_ge_uint(a, e, T_CHECK_QUIET)
#define T_step_ge_u8(s, a, e)   T_flags_ge_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_u8(s, a, e)    T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_u8(a, e)   T_flags_gt_uint(a, e, 0)
#define T_assert_gt_u8(a, e)   T_flags_gt_uint(a, e, T_CHECK_STOP)
#define T_quiet_gt_u8(a, e)   T_flags_gt_uint(a, e, T_CHECK_QUIET)
#define T_step_gt_u8(s, a, e)   T_flags_gt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_u8(s, a, e)    T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_u8(a, e)   T_flags_le_uint(a, e, 0)
#define T_assert_le_u8(a, e)   T_flags_le_uint(a, e, T_CHECK_STOP)
#define T_quiet_le_u8(a, e)   T_flags_le_uint(a, e, T_CHECK_QUIET)
#define T_step_le_u8(s, a, e)   T_flags_le_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_u8(s, a, e)    T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_u8(a, e)   T_flags_lt_uint(a, e, 0)
#define T_assert_lt_u8(a, e)   T_flags_lt_uint(a, e, T_CHECK_STOP)
#define T_quiet_lt_u8(a, e)   T_flags_lt_uint(a, e, T_CHECK_QUIET)
#define T_step_lt_u8(s, a, e)   T_flags_lt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_u8(s, a, e)    T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_i16(a, e)   T_flags_eq_int(a, e, 0)
#define T_assert_eq_i16(a, e)   T_flags_eq_int(a, e, T_CHECK_STOP)
#define T_quiet_eq_i16(a, e)   T_flags_eq_int(a, e, T_CHECK_QUIET)
#define T_step_eq_i16(s, a, e)   T_flags_eq_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_i16(s, a, e)    T_flags_eq_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_i16(a, e)   T_flags_ne_int(a, e, 0)
#define T_assert_ne_i16(a, e)   T_flags_ne_int(a, e, T_CHECK_STOP)
#define T_quiet_ne_i16(a, e)   T_flags_ne_int(a, e, T_CHECK_QUIET)
#define T_step_ne_i16(s, a, e)   T_flags_ne_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_i16(s, a, e)    T_flags_ne_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_i16(a, e)   T_flags_ge_int(a, e, 0)
#define T_assert_ge_i16(a, e)   T_flags_ge_int(a, e, T_CHECK_STOP)
#define T_quiet_ge_i16(a, e)   T_flags_ge_int(a, e, T_CHECK_QUIET)
#define T_step_ge_i16(s, a, e)   T_flags_ge_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_i16(s, a, e)    T_flags_ge_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_i16(a, e)   T_flags_gt_int(a, e, 0)
#define T_assert_gt_i16(a, e)   T_flags_gt_int(a, e, T_CHECK_STOP)
#define T_quiet_gt_i16(a, e)   T_flags_gt_int(a, e, T_CHECK_QUIET)
#define T_step_gt_i16(s, a, e)   T_flags_gt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_i16(s, a, e)    T_flags_gt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_i16(a, e)   T_flags_le_int(a, e, 0)
#define T_assert_le_i16(a, e)   T_flags_le_int(a, e, T_CHECK_STOP)
#define T_quiet_le_i16(a, e)   T_flags_le_int(a, e, T_CHECK_QUIET)
#define T_step_le_i16(s, a, e)   T_flags_le_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_i16(s, a, e)    T_flags_le_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_i16(a, e)   T_flags_lt_int(a, e, 0)
#define T_assert_lt_i16(a, e)   T_flags_lt_int(a, e, T_CHECK_STOP)
#define T_quiet_lt_i16(a, e)   T_flags_lt_int(a, e, T_CHECK_QUIET)
#define T_step_lt_i16(s, a, e)   T_flags_lt_int(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_i16(s, a, e)    T_flags_lt_int(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_u16(a, e)   T_flags_eq_uint(a, e, 0)
#define T_assert_eq_u16(a, e)   T_flags_eq_uint(a, e, T_CHECK_STOP)
#define T_quiet_eq_u16(a, e)   T_flags_eq_uint(a, e, T_CHECK_QUIET)
#define T_step_eq_u16(s, a, e)   T_flags_eq_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_u16(s, a, e)    T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_u16(a, e)   T_flags_ne_uint(a, e, 0)
#define T_assert_ne_u16(a, e)   T_flags_ne_uint(a, e, T_CHECK_STOP)
#define T_quiet_ne_u16(a, e)   T_flags_ne_uint(a, e, T_CHECK_QUIET)
#define T_step_ne_u16(s, a, e)   T_flags_ne_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_u16(s, a, e)    T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_u16(a, e)   T_flags_ge_uint(a, e, 0)
#define T_assert_ge_u16(a, e)   T_flags_ge_uint(a, e, T_CHECK_STOP)
#define T_quiet_ge_u16(a, e)   T_flags_ge_uint(a, e, T_CHECK_QUIET)
#define T_step_ge_u16(s, a, e)   T_flags_ge_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_u16(s, a, e)    T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_u16(a, e)   T_flags_gt_uint(a, e, 0)
#define T_assert_gt_u16(a, e)   T_flags_gt_uint(a, e, T_CHECK_STOP)
#define T_quiet_gt_u16(a, e)   T_flags_gt_uint(a, e, T_CHECK_QUIET)
#define T_step_gt_u16(s, a, e)   T_flags_gt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_u16(s, a, e)    T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_u16(a, e)   T_flags_le_uint(a, e, 0)
#define T_assert_le_u16(a, e)   T_flags_le_uint(a, e, T_CHECK_STOP)
#define T_quiet_le_u16(a, e)   T_flags_le_uint(a, e, T_CHECK_QUIET)
#define T_step_le_u16(s, a, e)   T_flags_le_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_u16(s, a, e)    T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_u16(a, e)   T_flags_lt_uint(a, e, 0)
#define T_assert_lt_u16(a, e)   T_flags_lt_uint(a, e, T_CHECK_STOP)
#define T_quiet_lt_u16(a, e)   T_flags_lt_uint(a, e, T_CHECK_QUIET)
#define T_step_lt_u16(s, a, e)   T_flags_lt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_u16(s, a, e)    T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_i32(a, e)   T_flags_eq_long(a, e, 0)
#define T_assert_eq_i32(a, e)   T_flags_eq_long(a, e, T_CHECK_STOP)
#define T_quiet_eq_i32(a, e)   T_flags_eq_long(a, e, T_CHECK_QUIET)
#define T_step_eq_i32(s, a, e)   T_flags_eq_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_i32(s, a, e)    T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_i32(a, e)   T_flags_ne_long(a, e, 0)
#define T_assert_ne_i32(a, e)   T_flags_ne_long(a, e, T_CHECK_STOP)
#define T_quiet_ne_i32(a, e)   T_flags_ne_long(a, e, T_CHECK_QUIET)
#define T_step_ne_i32(s, a, e)   T_flags_ne_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_i32(s, a, e)    T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_i32(a, e)   T_flags_ge_long(a, e, 0)
#define T_assert_ge_i32(a, e)   T_flags_ge_long(a, e, T_CHECK_STOP)
#define T_quiet_ge_i32(a, e)   T_flags_ge_long(a, e, T_CHECK_QUIET)
#define T_step_ge_i32(s, a, e)   T_flags_ge_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_i32(s, a, e)    T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_i32(a, e)   T_flags_gt_long(a, e, 0)
#define T_assert_gt_i32(a, e)   T_flags_gt_long(a, e, T_CHECK_STOP)
#define T_quiet_gt_i32(a, e)   T_flags_gt_long(a, e, T_CHECK_QUIET)
#define T_step_gt_i32(s, a, e)   T_flags_gt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_i32(s, a, e)    T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_i32(a, e)   T_flags_le_long(a, e, 0)
#define T_assert_le_i32(a, e)   T_flags_le_long(a, e, T_CHECK_STOP)
#define T_quiet_le_i32(a, e)   T_flags_le_long(a, e, T_CHECK_QUIET)
#define T_step_le_i32(s, a, e)   T_flags_le_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_i32(s, a, e)    T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_i32(a, e)   T_flags_lt_long(a, e, 0)
#define T_assert_lt_i32(a, e)   T_flags_lt_long(a, e, T_CHECK_STOP)
#define T_quiet_lt_i32(a, e)   T_flags_lt_long(a, e, T_CHECK_QUIET)
#define T_step_lt_i32(s, a, e)   T_flags_lt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_i32(s, a, e)    T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_u32(a, e)   T_flags_eq_ulong(a, e, 0)
#define T_assert_eq_u32(a, e)   T_flags_eq_ulong(a, e, T_CHECK_STOP)
#define T_quiet_eq_u32(a, e)   T_flags_eq_ulong(a, e, T_CHECK_QUIET)
#define T_step_eq_u32(s, a, e)   T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_u32(s, a, e)    T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_u32(a, e)   T_flags_ne_ulong(a, e, 0)
#define T_assert_ne_u32(a, e)   T_flags_ne_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ne_u32(a, e)   T_flags_ne_ulong(a, e, T_CHECK_QUIET)
#define T_step_ne_u32(s, a, e)   T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_u32(s, a, e)    T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_u32(a, e)   T_flags_ge_ulong(a, e, 0)
#define T_assert_ge_u32(a, e)   T_flags_ge_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ge_u32(a, e)   T_flags_ge_ulong(a, e, T_CHECK_QUIET)
#define T_step_ge_u32(s, a, e)   T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_u32(s, a, e)    T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_u32(a, e)   T_flags_gt_ulong(a, e, 0)
#define T_assert_gt_u32(a, e)   T_flags_gt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_gt_u32(a, e)   T_flags_gt_ulong(a, e, T_CHECK_QUIET)
#define T_step_gt_u32(s, a, e)   T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_u32(s, a, e)    T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_u32(a, e)   T_flags_le_ulong(a, e, 0)
#define T_assert_le_u32(a, e)   T_flags_le_ulong(a, e, T_CHECK_STOP)
#define T_quiet_le_u32(a, e)   T_flags_le_ulong(a, e, T_CHECK_QUIET)
#define T_step_le_u32(s, a, e)   T_flags_le_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_u32(s, a, e)    T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_u32(a, e)   T_flags_lt_ulong(a, e, 0)
#define T_assert_lt_u32(a, e)   T_flags_lt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_lt_u32(a, e)   T_flags_lt_ulong(a, e, T_CHECK_QUIET)
#define T_step_lt_u32(s, a, e)   T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_u32(s, a, e)    T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_i64(a, e)   T_flags_eq_ll(a, e, 0)
#define T_assert_eq_i64(a, e)   T_flags_eq_ll(a, e, T_CHECK_STOP)
#define T_quiet_eq_i64(a, e)   T_flags_eq_ll(a, e, T_CHECK_QUIET)
#define T_step_eq_i64(s, a, e)   T_flags_eq_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_i64(s, a, e)    T_flags_eq_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_i64(a, e)   T_flags_ne_ll(a, e, 0)
#define T_assert_ne_i64(a, e)   T_flags_ne_ll(a, e, T_CHECK_STOP)
#define T_quiet_ne_i64(a, e)   T_flags_ne_ll(a, e, T_CHECK_QUIET)
#define T_step_ne_i64(s, a, e)   T_flags_ne_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_i64(s, a, e)    T_flags_ne_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_i64(a, e)   T_flags_ge_ll(a, e, 0)
#define T_assert_ge_i64(a, e)   T_flags_ge_ll(a, e, T_CHECK_STOP)
#define T_quiet_ge_i64(a, e)   T_flags_ge_ll(a, e, T_CHECK_QUIET)
#define T_step_ge_i64(s, a, e)   T_flags_ge_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_i64(s, a, e)    T_flags_ge_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_i64(a, e)   T_flags_gt_ll(a, e, 0)
#define T_assert_gt_i64(a, e)   T_flags_gt_ll(a, e, T_CHECK_STOP)
#define T_quiet_gt_i64(a, e)   T_flags_gt_ll(a, e, T_CHECK_QUIET)
#define T_step_gt_i64(s, a, e)   T_flags_gt_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_i64(s, a, e)    T_flags_gt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_i64(a, e)   T_flags_le_ll(a, e, 0)
#define T_assert_le_i64(a, e)   T_flags_le_ll(a, e, T_CHECK_STOP)
#define T_quiet_le_i64(a, e)   T_flags_le_ll(a, e, T_CHECK_QUIET)
#define T_step_le_i64(s, a, e)   T_flags_le_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_i64(s, a, e)    T_flags_le_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_i64(a, e)   T_flags_lt_ll(a, e, 0)
#define T_assert_lt_i64(a, e)   T_flags_lt_ll(a, e, T_CHECK_STOP)
#define T_quiet_lt_i64(a, e)   T_flags_lt_ll(a, e, T_CHECK_QUIET)
#define T_step_lt_i64(s, a, e)   T_flags_lt_ll(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_i64(s, a, e)    T_flags_lt_ll(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_u64(a, e)   T_flags_eq_ull(a, e, 0)
#define T_assert_eq_u64(a, e)   T_flags_eq_ull(a, e, T_CHECK_STOP)
#define T_quiet_eq_u64(a, e)   T_flags_eq_ull(a, e, T_CHECK_QUIET)
#define T_step_eq_u64(s, a, e)   T_flags_eq_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_u64(s, a, e)    T_flags_eq_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_u64(a, e)   T_flags_ne_ull(a, e, 0)
#define T_assert_ne_u64(a, e)   T_flags_ne_ull(a, e, T_CHECK_STOP)
#define T_quiet_ne_u64(a, e)   T_flags_ne_ull(a, e, T_CHECK_QUIET)
#define T_step_ne_u64(s, a, e)   T_flags_ne_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_u64(s, a, e)    T_flags_ne_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_u64(a, e)   T_flags_ge_ull(a, e, 0)
#define T_assert_ge_u64(a, e)   T_flags_ge_ull(a, e, T_CHECK_STOP)
#define T_quiet_ge_u64(a, e)   T_flags_ge_ull(a, e, T_CHECK_QUIET)
#define T_step_ge_u64(s, a, e)   T_flags_ge_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_u64(s, a, e)    T_flags_ge_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_u64(a, e)   T_flags_gt_ull(a, e, 0)
#define T_assert_gt_u64(a, e)   T_flags_gt_ull(a, e, T_CHECK_STOP)
#define T_quiet_gt_u64(a, e)   T_flags_gt_ull(a, e, T_CHECK_QUIET)
#define T_step_gt_u64(s, a, e)   T_flags_gt_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_u64(s, a, e)    T_flags_gt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_u64(a, e)   T_flags_le_ull(a, e, 0)
#define T_assert_le_u64(a, e)   T_flags_le_ull(a, e, T_CHECK_STOP)
#define T_quiet_le_u64(a, e)   T_flags_le_ull(a, e, T_CHECK_QUIET)
#define T_step_le_u64(s, a, e)   T_flags_le_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_u64(s, a, e)    T_flags_le_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_u64(a, e)   T_flags_lt_ull(a, e, 0)
#define T_assert_lt_u64(a, e)   T_flags_lt_ull(a, e, T_CHECK_STOP)
#define T_quiet_lt_u64(a, e)   T_flags_lt_ull(a, e, T_CHECK_QUIET)
#define T_step_lt_u64(s, a, e)   T_flags_lt_ull(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_u64(s, a, e)    T_flags_lt_ull(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_iptr(a, e)   T_flags_eq_long(a, e, 0)
#define T_assert_eq_iptr(a, e)   T_flags_eq_long(a, e, T_CHECK_STOP)
#define T_quiet_eq_iptr(a, e)   T_flags_eq_long(a, e, T_CHECK_QUIET)
#define T_step_eq_iptr(s, a, e)   T_flags_eq_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_iptr(s, a, e)    T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_iptr(a, e)   T_flags_ne_long(a, e, 0)
#define T_assert_ne_iptr(a, e)   T_flags_ne_long(a, e, T_CHECK_STOP)
#define T_quiet_ne_iptr(a, e)   T_flags_ne_long(a, e, T_CHECK_QUIET)
#define T_step_ne_iptr(s, a, e)   T_flags_ne_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_iptr(s, a, e)    T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_iptr(a, e)   T_flags_ge_long(a, e, 0)
#define T_assert_ge_iptr(a, e)   T_flags_ge_long(a, e, T_CHECK_STOP)
#define T_quiet_ge_iptr(a, e)   T_flags_ge_long(a, e, T_CHECK_QUIET)
#define T_step_ge_iptr(s, a, e)   T_flags_ge_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_iptr(s, a, e)    T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_iptr(a, e)   T_flags_gt_long(a, e, 0)
#define T_assert_gt_iptr(a, e)   T_flags_gt_long(a, e, T_CHECK_STOP)
#define T_quiet_gt_iptr(a, e)   T_flags_gt_long(a, e, T_CHECK_QUIET)
#define T_step_gt_iptr(s, a, e)   T_flags_gt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_iptr(s, a, e)    T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_iptr(a, e)   T_flags_le_long(a, e, 0)
#define T_assert_le_iptr(a, e)   T_flags_le_long(a, e, T_CHECK_STOP)
#define T_quiet_le_iptr(a, e)   T_flags_le_long(a, e, T_CHECK_QUIET)
#define T_step_le_iptr(s, a, e)   T_flags_le_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_iptr(s, a, e)    T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_iptr(a, e)   T_flags_lt_long(a, e, 0)
#define T_assert_lt_iptr(a, e)   T_flags_lt_long(a, e, T_CHECK_STOP)
#define T_quiet_lt_iptr(a, e)   T_flags_lt_long(a, e, T_CHECK_QUIET)
#define T_step_lt_iptr(s, a, e)   T_flags_lt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_iptr(s, a, e)    T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_uptr(a, e)   T_flags_eq_ulong(a, e, 0)
#define T_assert_eq_uptr(a, e)   T_flags_eq_ulong(a, e, T_CHECK_STOP)
#define T_quiet_eq_uptr(a, e)   T_flags_eq_ulong(a, e, T_CHECK_QUIET)
#define T_step_eq_uptr(s, a, e)   T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_uptr(s, a, e)    T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_uptr(a, e)   T_flags_ne_ulong(a, e, 0)
#define T_assert_ne_uptr(a, e)   T_flags_ne_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ne_uptr(a, e)   T_flags_ne_ulong(a, e, T_CHECK_QUIET)
#define T_step_ne_uptr(s, a, e)   T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_uptr(s, a, e)    T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_uptr(a, e)   T_flags_ge_ulong(a, e, 0)
#define T_assert_ge_uptr(a, e)   T_flags_ge_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ge_uptr(a, e)   T_flags_ge_ulong(a, e, T_CHECK_QUIET)
#define T_step_ge_uptr(s, a, e)   T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_uptr(s, a, e)    T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_uptr(a, e)   T_flags_gt_ulong(a, e, 0)
#define T_assert_gt_uptr(a, e)   T_flags_gt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_gt_uptr(a, e)   T_flags_gt_ulong(a, e, T_CHECK_QUIET)
#define T_step_gt_uptr(s, a, e)   T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_uptr(s, a, e)    T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_uptr(a, e)   T_flags_le_ulong(a, e, 0)
#define T_assert_le_uptr(a, e)   T_flags_le_ulong(a, e, T_CHECK_STOP)
#define T_quiet_le_uptr(a, e)   T_flags_le_ulong(a, e, T_CHECK_QUIET)
#define T_step_le_uptr(s, a, e)   T_flags_le_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_uptr(s, a, e)    T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_uptr(a, e)   T_flags_lt_ulong(a, e, 0)
#define T_assert_lt_uptr(a, e)   T_flags_lt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_lt_uptr(a, e)   T_flags_lt_ulong(a, e, T_CHECK_QUIET)
#define T_step_lt_uptr(s, a, e)   T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_uptr(s, a, e)    T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_ssz(a, e)   T_flags_eq_long(a, e, 0)
#define T_assert_eq_ssz(a, e)   T_flags_eq_long(a, e, T_CHECK_STOP)
#define T_quiet_eq_ssz(a, e)   T_flags_eq_long(a, e, T_CHECK_QUIET)
#define T_step_eq_ssz(s, a, e)   T_flags_eq_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_ssz(s, a, e)    T_flags_eq_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_ssz(a, e)   T_flags_ne_long(a, e, 0)
#define T_assert_ne_ssz(a, e)   T_flags_ne_long(a, e, T_CHECK_STOP)
#define T_quiet_ne_ssz(a, e)   T_flags_ne_long(a, e, T_CHECK_QUIET)
#define T_step_ne_ssz(s, a, e)   T_flags_ne_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_ssz(s, a, e)    T_flags_ne_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_ssz(a, e)   T_flags_ge_long(a, e, 0)
#define T_assert_ge_ssz(a, e)   T_flags_ge_long(a, e, T_CHECK_STOP)
#define T_quiet_ge_ssz(a, e)   T_flags_ge_long(a, e, T_CHECK_QUIET)
#define T_step_ge_ssz(s, a, e)   T_flags_ge_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_ssz(s, a, e)    T_flags_ge_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_ssz(a, e)   T_flags_gt_long(a, e, 0)
#define T_assert_gt_ssz(a, e)   T_flags_gt_long(a, e, T_CHECK_STOP)
#define T_quiet_gt_ssz(a, e)   T_flags_gt_long(a, e, T_CHECK_QUIET)
#define T_step_gt_ssz(s, a, e)   T_flags_gt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_ssz(s, a, e)    T_flags_gt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_ssz(a, e)   T_flags_le_long(a, e, 0)
#define T_assert_le_ssz(a, e)   T_flags_le_long(a, e, T_CHECK_STOP)
#define T_quiet_le_ssz(a, e)   T_flags_le_long(a, e, T_CHECK_QUIET)
#define T_step_le_ssz(s, a, e)   T_flags_le_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_ssz(s, a, e)    T_flags_le_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_ssz(a, e)   T_flags_lt_long(a, e, 0)
#define T_assert_lt_ssz(a, e)   T_flags_lt_long(a, e, T_CHECK_STOP)
#define T_quiet_lt_ssz(a, e)   T_flags_lt_long(a, e, T_CHECK_QUIET)
#define T_step_lt_ssz(s, a, e)   T_flags_lt_long(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_ssz(s, a, e)    T_flags_lt_long(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eq_sz(a, e)   T_flags_eq_ulong(a, e, 0)
#define T_assert_eq_sz(a, e)   T_flags_eq_ulong(a, e, T_CHECK_STOP)
#define T_quiet_eq_sz(a, e)   T_flags_eq_ulong(a, e, T_CHECK_QUIET)
#define T_step_eq_sz(s, a, e)   T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_sz(s, a, e)    T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_sz(a, e)   T_flags_ne_ulong(a, e, 0)
#define T_assert_ne_sz(a, e)   T_flags_ne_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ne_sz(a, e)   T_flags_ne_ulong(a, e, T_CHECK_QUIET)
#define T_step_ne_sz(s, a, e)   T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_sz(s, a, e)    T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_sz(a, e)   T_flags_ge_ulong(a, e, 0)
#define T_assert_ge_sz(a, e)   T_flags_ge_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ge_sz(a, e)   T_flags_ge_ulong(a, e, T_CHECK_QUIET)
#define T_step_ge_sz(s, a, e)   T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_sz(s, a, e)    T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_sz(a, e)   T_flags_gt_ulong(a, e, 0)
#define T_assert_gt_sz(a, e)   T_flags_gt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_gt_sz(a, e)   T_flags_gt_ulong(a, e, T_CHECK_QUIET)
#define T_step_gt_sz(s, a, e)   T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_sz(s, a, e)    T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_sz(a, e)   T_flags_le_ulong(a, e, 0)
#define T_assert_le_sz(a, e)   T_flags_le_ulong(a, e, T_CHECK_STOP)
#define T_quiet_le_sz(a, e)   T_flags_le_ulong(a, e, T_CHECK_QUIET)
#define T_step_le_sz(s, a, e)   T_flags_le_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_sz(s, a, e)    T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_sz(a, e)   T_flags_lt_ulong(a, e, 0)
#define T_assert_lt_sz(a, e)   T_flags_lt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_lt_sz(a, e)   T_flags_lt_ulong(a, e, T_CHECK_QUIET)
#define T_step_lt_sz(s, a, e)   T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_sz(s, a, e)    T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eno(a, e)   T_flags_eno(a, e, 0)
#define T_assert_eno(a, e)   T_flags_eno(a, e, T_CHECK_STOP)
#define T_quiet_eno(a, e)   T_flags_eno(a, e, T_CHECK_QUIET)
#define T_step_eno(s, a, e)   T_flags_eno(a, e, T_CHECK_STEP(s))
#define T_step_assert_eno(s, a, e)    T_flags_eno(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_eno_success(a)   T_flags_eno_success(a, 0)
#define T_assert_eno_success(a)   T_flags_eno_success(a, T_CHECK_STOP)
#define T_quiet_eno_success(a)   T_flags_eno_success(a, T_CHECK_QUIET)
#define T_step_eno_success(s, a)   T_flags_eno_success(a, T_CHECK_STEP(s))
#define T_step_assert_eno_success(s, a)    T_flags_eno_success(a, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_psx_error(a, eno)   T_flags_psx_error(a, eno, 0)
#define T_assert_psx_error(a, eno)   T_flags_psx_error(a, eno, T_CHECK_STOP)
#define T_quiet_psx_error(a, eno)   T_flags_psx_error(a, eno, T_CHECK_QUIET)
#define T_step_psx_error(s, a, eno)   T_flags_psx_error(a, eno, T_CHECK_STEP(s))
#define T_step_assert_psx_error(s, a, eno)    T_flags_psx_error(a, eno, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_psx_success(a)   T_flags_psx_success(a, 0)
#define T_assert_psx_success(a)   T_flags_psx_success(a, T_CHECK_STOP)
#define T_quiet_psx_success(a)   T_flags_psx_success(a, T_CHECK_QUIET)
#define T_step_psx_success(s, a)   T_flags_psx_success(a, T_CHECK_STEP(s))
#define T_step_assert_psx_success(s, a)    T_flags_psx_success(a, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_flags_step(a, flags)
#define T_step(e)   T_flags_step(e, 0)
#define T_step_assert(e)   T_flags_step(e, T_CHECK_STOP)
#define T_unreachable()    do { T_true(false, "Unreachable"); T_stop(); } while (0)
#define T_TEST_CASE_FIXTURE(name, fixture)
#define T_TEST_CASE(name)   T_TEST_CASE_FIXTURE(name, NULL)
#define T_MEASURE_RUNTIME_ALLOW_CLOCK_ISR   0x1
#define T_MEASURE_RUNTIME_REPORT_SAMPLES   0x2
#define T_MEASURE_RUNTIME_DISABLE_FULL_CACHE   0x10
#define T_MEASURE_RUNTIME_DISABLE_HOT_CACHE   0x20
#define T_MEASURE_RUNTIME_DISABLE_DIRTY_CACHE   0x40
#define T_MEASURE_RUNTIME_DISABLE_MINOR_LOAD   0x80
#define T_MEASURE_RUNTIME_DISABLE_MAX_LOAD   0x100
typedef struct T_fixture T_fixture
typedef struct T_fixture_node T_fixture_node
typedef struct T_remark T_remark
typedef struct T_case_context T_case_context
typedef unsigned long T_ticks
typedef uint64_t T_time
typedef char T_time_string[24]
typedef void(* T_action) (T_event, const char *)
typedef void(* T_putchar) (int, void *)
typedef struct T_destructor T_destructor
typedef struct T_measure_runtime_context T_measure_runtime_context
enum  T_verbosity { T_QUIET , T_NORMAL , T_VERBOSE }
enum  T_event {
  T_EVENT_RUN_INITIALIZE_EARLY , T_EVENT_RUN_INITIALIZE_LATE , T_EVENT_CASE_EARLY , T_EVENT_CASE_BEGIN ,
  T_EVENT_CASE_END , T_EVENT_CASE_LATE , T_EVENT_CASE_STOP , T_EVENT_RUN_FINALIZE_EARLY ,
  T_EVENT_RUN_FINALIZE_LATE
enum  T_interrupt_test_state {
  T_INTERRUPT_TEST_INITIAL , T_INTERRUPT_TEST_ACTION , T_INTERRUPT_TEST_BLOCKED , T_INTERRUPT_TEST_CONTINUE ,
  T_INTERRUPT_TEST_DONE , T_INTERRUPT_TEST_EARLY , T_INTERRUPT_TEST_INTERRUPT , T_INTERRUPT_TEST_LATE ,
  T_INTERRUPT_TEST_TIMEOUT
void T_case_register (T_case_context *)
void T_check (const T_check_context *, bool,...)
void T_check_eq_ptr (const T_check_context_msg *, uintptr_t, uintptr_t)
void T_check_ne_ptr (const T_check_context_msg *, uintptr_t, uintptr_t)
void T_check_null (const T_check_context_msg *, uintptr_t)
void T_check_not_null (const T_check_context_msg *, uintptr_t)
void T_check_eq_mem (const T_check_context_msg *, const void *, const void *, size_t)
void T_check_ne_mem (const T_check_context_msg *, const void *, const void *, size_t)
void T_check_eq_str (const T_check_context *, const char *, const char *)
void T_check_ne_str (const T_check_context *, const char *, const char *)
void T_check_eq_nstr (const T_check_context *, const char *, const char *, size_t)
void T_check_ne_nstr (const T_check_context *, const char *, const char *, size_t)
void T_check_eq_char (const T_check_context *, char, char)
void T_check_ne_char (const T_check_context *, char, char)
void T_check_eq_int (const T_check_context *, int, int)
void T_check_ne_int (const T_check_context *, int, int)
void T_check_ge_int (const T_check_context *, int, int)
void T_check_gt_int (const T_check_context *, int, int)
void T_check_le_int (const T_check_context *, int, int)
void T_check_lt_int (const T_check_context *, int, int)
void T_check_eq_uint (const T_check_context *, unsigned int, unsigned int)
void T_check_ne_uint (const T_check_context *, unsigned int, unsigned int)
void T_check_ge_uint (const T_check_context *, unsigned int, unsigned int)
void T_check_gt_uint (const T_check_context *, unsigned int, unsigned int)
void T_check_le_uint (const T_check_context *, unsigned int, unsigned int)
void T_check_lt_uint (const T_check_context *, unsigned int, unsigned int)
void T_check_eq_long (const T_check_context *, long, long)
void T_check_ne_long (const T_check_context *, long, long)
void T_check_ge_long (const T_check_context *, long, long)
void T_check_gt_long (const T_check_context *, long, long)
void T_check_le_long (const T_check_context *, long, long)
void T_check_lt_long (const T_check_context *, long, long)
void T_check_eq_ulong (const T_check_context *, unsigned long, unsigned long)
void T_check_ne_ulong (const T_check_context *, unsigned long, unsigned long)
void T_check_ge_ulong (const T_check_context *, unsigned long, unsigned long)
void T_check_gt_ulong (const T_check_context *, unsigned long, unsigned long)
void T_check_le_ulong (const T_check_context *, unsigned long, unsigned long)
void T_check_lt_ulong (const T_check_context *, unsigned long, unsigned long)
void T_check_eq_ll (const T_check_context *, long long, long long)
void T_check_ne_ll (const T_check_context *, long long, long long)
void T_check_ge_ll (const T_check_context *, long long, long long)
void T_check_gt_ll (const T_check_context *, long long, long long)
void T_check_le_ll (const T_check_context *, long long, long long)
void T_check_lt_ll (const T_check_context *, long long, long long)
void T_check_eq_ull (const T_check_context *, unsigned long long, unsigned long long)
void T_check_ne_ull (const T_check_context *, unsigned long long, unsigned long long)
void T_check_ge_ull (const T_check_context *, unsigned long long, unsigned long long)
void T_check_gt_ull (const T_check_context *, unsigned long long, unsigned long long)
void T_check_le_ull (const T_check_context *, unsigned long long, unsigned long long)
void T_check_lt_ull (const T_check_context *, unsigned long long, unsigned long long)
void T_check_eno (const T_check_context *, int, int)
void T_check_eno_success (const T_check_context *, int)
void T_check_psx_error (const T_check_context *, int, int)
void T_check_psx_success (const T_check_context *, int)
int T_printf (char const *,...)
int T_vprintf (char const *, va_list)
int T_puts (const char *, size_t)
int T_snprintf (char *, size_t, const char *,...)
void T_log (T_verbosity, char const *,...)
const char * T_case_name (void)
T_verbosity T_set_verbosity (T_verbosity)
const char * T_strerror (int)
void T_plan (unsigned int)
void T_push_plan (T_fixture_node *, unsigned int)
void T_pop_plan (void)
void T_check_step (const T_check_context *, unsigned int)
const char * T_time_to_string_ns (T_time, T_time_string)
const char * T_time_to_string_us (T_time, T_time_string)
const char * T_time_to_string_ms (T_time, T_time_string)
const char * T_time_to_string_s (T_time, T_time_string)
const char * T_ticks_to_string_ns (T_ticks, T_time_string)
const char * T_ticks_to_string_us (T_ticks, T_time_string)
const char * T_ticks_to_string_ms (T_ticks, T_time_string)
const char * T_ticks_to_string_s (T_ticks, T_time_string)
T_time T_ticks_to_time (T_ticks)
T_ticks T_time_to_ticks (T_time)
T_time T_seconds_and_nanoseconds_to_time (uint32_t, uint32_t)
void T_time_to_seconds_and_nanoseconds (T_time, uint32_t *, uint32_t *)
T_time T_now (void)
T_ticks T_tick (void)
T_time T_now_clock (void)
T_time T_now_dummy (void)
T_time T_now_tick (void)
T_time T_case_begin_time (void)
void * T_malloc (size_t)
void * T_calloc (size_t, size_t)
void * T_zalloc (size_t, void(*)(void *))
void T_free (void *)
void T_register (void)
void T_putchar_default (int, void *)
int T_main (const T_config *)
void T_make_runner (void)
bool T_is_runner (void)
void T_run_initialize (const T_config *)
void T_run_all (void)
void T_run_by_name (const char *)
void * T_case_begin (const char *, const T_fixture *)
void T_case_end (void)
bool T_run_finalize (void)
void T_set_putchar (T_putchar, void *, T_putchar *, void **)
void * T_fixture_context (void)
void T_set_fixture_context (void *)
void T_add_remark (T_remark *)
void * T_push_fixture (T_fixture_node *, const T_fixture *)
void T_pop_fixture (void)
T_NO_RETURN void T_stop (void)
size_t T_get_scope (const char *const *const *desc, char *buf, size_t n, const size_t *second_indices)
 Gets the scope for nested fixtures. More...
size_t T_str_copy (char *, const char *, size_t)
void T_busy (uint_fast32_t)
uint_fast32_t T_get_one_clock_tick_busy (void)
T_interrupt_test_state T_interrupt_test_change_state (T_interrupt_test_state, T_interrupt_test_state)
T_interrupt_test_state T_interrupt_test_get_state (void)
void T_interrupt_test_busy_wait_for_interrupt (void)
T_interrupt_test_state T_interrupt_test (const T_interrupt_test_config *config, void *arg)
T_thread_switch_logT_thread_switch_record (T_thread_switch_log *)
T_thread_switch_logT_thread_switch_record_2 (T_thread_switch_log_2 *)
T_thread_switch_logT_thread_switch_record_4 (T_thread_switch_log_4 *)
T_thread_switch_logT_thread_switch_record_10 (T_thread_switch_log_10 *)
void T_report_hash_sha256 (T_event, const char *)
void T_report_hash_sha256_update (char c)
void T_check_heap (T_event, const char *)
void T_add_destructor (T_destructor *, void(*)(T_destructor *))
void T_remove_destructor (T_destructor *)
T_measure_runtime_contextT_measure_runtime_create (const T_measure_runtime_config *)
void T_measure_runtime (T_measure_runtime_context *, const T_measure_runtime_request *)
const T_check_context T_special
const T_fixture T_empty_fixture
This header file provides interfaces of the RTEMS Test Framework.
◆ T_flags_step
#define T_flags_step (   a,
  flags
Value:
static const T_check_context T_check_instance = { \
T_FILE_NAME, __LINE__, (flags) | T_CHECK_FMT }; \
T_check_step(&T_check_instance, a); \
Definition: test.h:152
◆ T_TEST_CASE_FIXTURE
#define T_TEST_CASE_FIXTURE (   name,
  fixture
Value:
void T_case_body_##name(void); \
T_case_context T_case_instance_##name = { \
#name, \
T_case_body_##name, \
fixture, \
NULL \
__attribute__((__constructor__)) static void \
T_case_register_##name(void) \
T_case_register(&T_case_instance_##name); \
◆ T_get_scope()
size_t T_get_scope ( const char *const *const *  desc,
char *  buf,
size_t  n,
const size_t *  second_indices
This function should help implementing scope fixture methods. The parameter layout allows efficient code generation for this method.
Parameters
descis the description table. It shall be a NULL-terminated array which references arrays of descriptive strings.
bufis the buffer for the scope string.
nis the size of the scope buffer in characters.
second_indicesis an array of indices defining which descriptive string is used for each entry in the description table.
Returns
Returns the characters consumed from the buffer for the produced scope.
