RTEMS 6.1-rc1
Telnet Daemon Interface. More...
struct | rtems_telnetd_config_table |
Telnet configuration structure. More... | |
Typedefs | |
typedef void(* | rtems_telnetd_command) (char *, void *) |
Telnet command type. | |
bool | rtems_telnetd_login_check (const char *user, const char *passphrase) |
Standard Telnet login check that uses DES to encrypt the passphrase. More... | |
rtems_status_code | rtems_telnetd_start (const rtems_telnetd_config_table *config) |
Starts the Telnet server using the provided configuration. More... | |
rtems_status_code | rtems_telnetd_initialize (void) |
Initializes the Telnet subsystem. More... | |
rtems_telnetd_config_table | rtems_telnetd_config |
Telnet configuration. More... | |
rtems_status_code rtems_telnetd_initialize | ( | void | ) |
Uses the application provided rtems_telnetd_config configuration table.
bool rtems_telnetd_login_check | ( | const char * | user, |
const char * | passphrase | ||
Takes a passphrase, encrypts it and compares it to the encrypted passphrase in the TELNETD_PASSWD
environment variable. No password is required if TELNETD_PASSWD
is unset. The argument user is ignored.
rtems_status_code rtems_telnetd_start | ( | const rtems_telnetd_config_table * | config | ) |
RTEMS_SUCCESSFUL | Successful operation. |
RTEMS_INVALID_ADDRESS | The command function in the configuration is NULL . |
RTEMS_RESOURCE_IN_USE | The server port is already in use. |
RTEMS_NOT_IMPLEMENTED | The keep stdio configuration option is true. |
RTEMS_UNSATISFIED | Not enough resources to start the Telnet server or task priority in configuration is invalid. |
extern |
The application must provide this configuration table. It is used by rtems_telnetd_initialize() to configure the Telnet subsystem. Do not modify the entries after the intialization since it is used internally.
