RTEMS 6.1-rc1
The telnet DAEMON. More...
#include <sys/queue.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <inttypes.h>
#include <unistd.h>
#include <syslog.h>
#include <rtems/pty.h>
#include <rtems/shell.h>
#include <rtems/telnetd.h>
#include <rtems/thread.h>
#include <rtems/userenv.h>
struct | telnetd_session |
struct | telnetd_context |
union | telnetd_address |
#define | TELNETD_EVENT_SUCCESS RTEMS_EVENT_0 |
#define | TELNETD_EVENT_ERROR RTEMS_EVENT_1 |
Typedefs | |
typedef struct telnetd_context | telnetd_context |
typedef struct telnetd_session | telnetd_session |
rtems_status_code | rtems_telnetd_start (const rtems_telnetd_config_table *config) |
Starts the Telnet server using the provided configuration. More... | |
The telnet DAEMON.
After start the net you can start this daemon. It uses the previously inited pseudo-terminales (pty.c) getting a new terminal with getpty(). This function gives a terminal name passing a opened socket like parameter.
With register_telnetd() you add a new command in the shell to start this daemon interactively. (Login in /dev/console of course)
Sorry but OOB is not still implemented. (This is the first version)
rtems_status_code rtems_telnetd_start | ( | const rtems_telnetd_config_table * | config | ) |
RTEMS_SUCCESSFUL | Successful operation. |
RTEMS_INVALID_ADDRESS | The command function in the configuration is NULL . |
RTEMS_RESOURCE_IN_USE | The server port is already in use. |
RTEMS_NOT_IMPLEMENTED | The keep stdio configuration option is true. |
RTEMS_UNSATISFIED | Not enough resources to start the Telnet server or task priority in configuration is invalid. |
