RTEMS 6.1-rc1
This header file provides functions used by corresponding test suite. More...
void ThreadBeginExtension0 (rtems_tcb *executing)
bool ThreadCreateExtension0 (rtems_tcb *executing, rtems_tcb *created)
void ThreadDeleteExtension0 (rtems_tcb *executing, rtems_tcb *deleted)
void ThreadExittedExtension0 (rtems_tcb *executing)
void ThreadRestartExtension0 (rtems_tcb *executing, rtems_tcb *restarted)
void ThreadStartExtension0 (rtems_tcb *executing, rtems_tcb *started)
void ThreadSwitchExtension0 (rtems_tcb *executing, rtems_tcb *heir)
void ThreadTerminateExtension0 (rtems_tcb *executing)
void FatalExtension0 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code)
void ThreadBeginExtension1 (rtems_tcb *executing)
bool ThreadCreateExtension1 (rtems_tcb *executing, rtems_tcb *created)
void ThreadDeleteExtension1 (rtems_tcb *executing, rtems_tcb *deleted)
void ThreadExittedExtension1 (rtems_tcb *executing)
void ThreadRestartExtension1 (rtems_tcb *executing, rtems_tcb *restarted)
void ThreadStartExtension1 (rtems_tcb *executing, rtems_tcb *started)
void ThreadSwitchExtension1 (rtems_tcb *executing, rtems_tcb *heir)
void ThreadTerminateExtension1 (rtems_tcb *executing)
void FatalExtension1 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code)
