RTEMS 6.1-rc1
This validation test suite contains a test case for the system termination procedure. More...
Modules | |
spec:/score/interr/val/terminate | |
Tests system termination procedure. | |
Files | |
file | ts-terminate.c |
#define | CONFIGURE_MAXIMUM_PROCESSORS 2 |
#define | CONFIGURE_INITIAL_EXTENSIONS |
#define | CONFIGURE_DISABLE_BSP_SETTINGS |
const char | rtems_test_name [] = "TestsuitesTerminate" |
Each test must define a test name string. | |
#define CONFIGURE_INITIAL_EXTENSIONS |
