RTEMS 6.1-rc1
tc-userext.h
2
11/*
12 * Copyright (C) 2021 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _TC_USEREXT_H
37#define _TC_USEREXT_H
38
39#include <rtems.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
45void ThreadBeginExtension0( rtems_tcb *executing );
46
47bool ThreadCreateExtension0( rtems_tcb *executing, rtems_tcb *created );
48
49void ThreadDeleteExtension0( rtems_tcb *executing, rtems_tcb *deleted );
50
51void ThreadExittedExtension0( rtems_tcb *executing );
52
53void ThreadRestartExtension0( rtems_tcb *executing, rtems_tcb *restarted );
54
55void ThreadStartExtension0( rtems_tcb *executing, rtems_tcb *started );
56
57void ThreadSwitchExtension0( rtems_tcb *executing, rtems_tcb *heir );
58
59void ThreadTerminateExtension0( rtems_tcb *executing );
60
61void FatalExtension0(
62 rtems_fatal_source source,
63 bool always_set_to_false,
65);
66
67void ThreadBeginExtension1( rtems_tcb *executing );
68
69bool ThreadCreateExtension1( rtems_tcb *executing, rtems_tcb *created );
70
71void ThreadDeleteExtension1( rtems_tcb *executing, rtems_tcb *deleted );
72
73void ThreadExittedExtension1( rtems_tcb *executing );
74
75void ThreadRestartExtension1( rtems_tcb *executing, rtems_tcb *restarted );
76
77void ThreadStartExtension1( rtems_tcb *executing, rtems_tcb *started );
78
79void ThreadSwitchExtension1( rtems_tcb *executing, rtems_tcb *heir );
80
81void ThreadTerminateExtension1( rtems_tcb *executing );
82
83void FatalExtension1(
84 rtems_fatal_source source,
85 bool always_set_to_false,
87);
88
89#ifdef __cplusplus
90}
91#endif
92
93#endif /* _TC_USEREXT_H */
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition: extension.h:161
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
Definition: thread.h:812
Definition: inftrees.h:24
