RTEMS 6.1-rc1
This source file contains the core implementation of RTEMS Test Framework. More...
#include <rtems/test.h>
#include <sys/queue.h>
#include <limits.h>
#include <pthread.h>
#include <sched.h>
#include <setjmp.h>
#include <stdatomic.h>
#include "t-test-printf.h"
struct  T_context
struct  T_putchar_string_context
#define _GNU_SOURCE
#define T_LINE_SIZE   256
#define T_BIGGEST_ALIGNMENT   sizeof(long long)
bool T_is_runner (void)
int T_snprintf (char *s, size_t n, char const *fmt,...)
int T_vprintf (char const *fmt, va_list ap)
int T_puts (const char *buf, size_t len)
size_t T_str_copy (char *dst, const char *src, size_t n)
void T_make_runner (void)
int T_printf (char const *fmt,...)
void T_log (T_verbosity verbosity, char const *fmt,...)
T_NO_RETURN void T_stop (void)
void T_plan (unsigned int planned_steps)
void T_push_plan (T_fixture_node *node, unsigned int planned_steps)
void T_pop_plan (void)
void T_check_step (const T_check_context *t, unsigned int expected)
void T_case_register (T_case_context *tc)
T_verbosity T_set_verbosity (T_verbosity verbosity)
void * T_fixture_context (void)
void T_set_fixture_context (void *context)
const char * T_case_name (void)
void T_check (const T_check_context *t, bool ok,...)
void T_add_destructor (T_destructor *dtor, void(*destroy)(T_destructor *))
void T_remove_destructor (T_destructor *dtor)
int T_main (const T_config *config)
void T_register (void)
void T_run_initialize (const T_config *config)
void T_run_all (void)
void T_run_by_name (const char *name)
void * T_case_begin (const char *name, const T_fixture *fixture)
void T_case_end (void)
bool T_run_finalize (void)
T_time T_case_begin_time (void)
void T_set_putchar (T_putchar new_putchar, void *new_arg, T_putchar *old_putchar, void **old_arg)
T_time T_now (void)
void * T_push_fixture (T_fixture_node *node, const T_fixture *fixture)
void T_pop_fixture (void)
void T_add_remark (T_remark *remark)
size_t T_get_scope (const char *const *const *desc, char *buf, size_t n, const size_t *second_indices)
 Gets the scope for nested fixtures. More...
struct __attribute__ ((__aligned__(T_BIGGEST_ALIGNMENT)))
void * T_malloc (size_t size)
void * T_calloc (size_t nelem, size_t elsize)
void * T_zalloc (size_t size, void(*destroy)(void *))
void T_free (void *ptr)
const T_check_context T_special
const T_fixture T_empty_fixture
 T_malloc_destructor
◆ T_get_scope()
size_t T_get_scope ( const char *const *const *  desc,
char *  buf,
size_t  n,
const size_t *  second_indices
This function should help implementing scope fixture methods. The parameter layout allows efficient code generation for this method.
Parameters
descis the description table. It shall be a NULL-terminated array which references arrays of descriptive strings.
bufis the buffer for the scope string.
nis the size of the scope buffer in characters.
second_indicesis an array of indices defining which descriptive string is used for each entry in the description table.
Returns
Returns the characters consumed from the buffer for the produced scope.
