RTEMS 6.1-rc1
pthread.h
2
12/*
13 * COPYRIGHT (c) 1989-2011.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_POSIX_PTHREAD_H
39#define _RTEMS_POSIX_PTHREAD_H
40
42#include <rtems/score/thread.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif
47
62typedef struct {
64 void *(*thread_entry)(void *);
68
69extern const size_t _POSIX_Threads_Minimum_stack_size;
70
79
84
90
93#ifdef __cplusplus
94}
95#endif
96
97#endif
98/* end of include file */
const posix_initialization_threads_table _POSIX_Threads_User_thread_table
Initialization table for the first user POSIX thread.
void _POSIX_Threads_Initialize_user_thread(void)
System initialization handler to create the first user POSIX thread.
Definition: pthreadinitthreads.c:49
Thread_Information _POSIX_Threads_Information
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
The thread object information.
Definition: thread.h:1098
Definition: pthread.h:62
int stack_size
Definition: pthread.h:66
POSIX Thread API Support.
