RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions
ftpfs.c File Reference
#include <ctype.h>
#include <fcntl.h>
#include <malloc.h>
#include <netdb.h>
#include <stdarg.h>
#include <unistd.h>
#include <arpa/inet.h>
#include <netinet/in.h>
#include <sys/select.h>
#include <sys/socket.h>
#include <sys/types.h>
#include <rtems/ftpfs.h>
#include <rtems/libio_.h>
#include <rtems/seterr.h>
struct  rtems_ftpfs_entry
struct  rtems_ftpfs_mount_entry
struct  rtems_ftpfs_pasv_entry
struct  rtems_ftpfs_size_entry
#define DEBUG_PRINTF(...)
#define RTEMS_FTPFS_REPLY_SIZE   3
typedef void(* rtems_ftpfs_reply_parser) (const char *, size_t, void *)
enum  rtems_ftpfs_reply_state {
  RTEMS_FTPFS_REPLY_START , RTEMS_FTPFS_REPLY_SINGLE_LINE , RTEMS_FTPFS_REPLY_DONE , RTEMS_FTPFS_REPLY_MULTI_LINE ,
  RTEMS_FTPFS_REPLY_MULTI_LINE_START
enum  rtems_ftpfs_reply {
  RTEMS_FTPFS_REPLY_ERROR = 0 , RTEMS_FTPFS_REPLY_1 = '1' , RTEMS_FTPFS_REPLY_2 = '2' , RTEMS_FTPFS_REPLY_3 = '3' ,
  RTEMS_FTPFS_REPLY_4 = '4' , RTEMS_FTPFS_REPLY_5 = '5'
enum  split_state {
  STATE_USER_NAME , STATE_START_PASSWORD , STATE_START_HOST_NAME , STATE_START_HOST_NAME_OR_PATH ,
  STATE_START_PATH , STATE_PASSWORD , STATE_HOST_NAME , STATE_DONE ,
  STATE_INVALID
enum  rtems_ftpfs_pasv_state { RTEMS_FTPFS_PASV_START = 0 , RTEMS_FTPFS_PASV_JUNK , RTEMS_FTPFS_PASV_DATA , RTEMS_FTPFS_PASV_DONE }
enum  rtems_ftpfs_size_state { RTEMS_FTPFS_SIZE_START = 0 , RTEMS_FTPFS_SIZE_SPACE , RTEMS_FTPFS_SIZE_NUMBER , RTEMS_FTPFS_SIZE_NL }
rtems_status_code rtems_ftpfs_get_verbose (const char *mount_point, bool *verbose)
 Returns in verbose if the verbose mode is enabled or disabled for the file system at mount_point. More...
rtems_status_code rtems_ftpfs_set_verbose (const char *mount_point, bool verbose)
 Enables or disables the verbose mode if verbose is true or false respectively for the file system at mount_point. More...
rtems_status_code rtems_ftpfs_get_timeout (const char *mount_point, struct timeval *timeout)
 Returns the current timeout value in timeout for the file system at mount_point. More...
rtems_status_code rtems_ftpfs_set_timeout (const char *mount_point, const struct timeval *timeout)
 Sets the timeout value to timeout for the file system at mount_point. More...
int rtems_ftpfs_initialize (rtems_filesystem_mount_table_entry_t *e, const void *d)
 Do not call directly, use mount().
File Transfer Protocol file system (FTP client).
