RTEMS 6.1-rc1
_dcdc_loop_control_config Struct Reference
Configuration for the loop control. More...
#include <fsl_dcdc.h>
bool enableCommonHysteresis
bool enableCommonThresholdDetection
bool enableDifferentialHysteresis
bool enableDifferentialThresholdDetection
bool enableInvertHysteresisSign
bool enableRCThresholdDetection
uint32_t enableRCScaleCircuit
uint32_t complementFeedForwardStep
uint32_t controlParameterMagnitude
uint32_t integralProportionalRatio
Field Documentation
◆ controlParameterMagnitude
uint32_t _dcdc_loop_control_config::controlParameterMagnitude
Available range is 0~15. Magnitude of proportional control parameter in the switching DC-DC converter control loop.
◆ enableDifferentialHysteresis
bool _dcdc_loop_control_config::enableDifferentialHysteresis
Enable hysteresis in switching converter differential mode analog comparators. This feature will improve transient supply ripple and efficiency.
◆ enableDifferentialThresholdDetection
bool _dcdc_loop_control_config::enableDifferentialThresholdDetection
Increase the threshold detection for differential mode analog comparators.
◆ integralProportionalRatio
uint32_t _dcdc_loop_control_config::integralProportionalRatio
Available range is 0~3.Ratio of integral control parameter to proportional control parameter in the switching DC-DC converter, and can be used to optimize efficiency and loop response.
The documentation for this struct was generated from the following files:
