RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations
Dcdc_soc
struct  _dcdc_config
 Configuration for DCDC. More...
struct  _dcdc_min_power_config
 Configuration for min power setting. More...
struct  _dcdc_detection_config
 Configuration for DCDC detection. More...
struct  _dcdc_loop_control_config
 Configuration for the loop control. More...
struct  _dcdc_internal_regulator_config
 Configuration for DCDC internal regulator. More...
struct  _dcdc_low_power_config
 Configuration for DCDC low power. More...
struct  _dcdc_setpoint_config
 DCDC configuration in set point mode. More...
#define FSL_DCDC_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 DCDC driver version. More...
#define STANDBY_MODE_VDD1P0_TARGET_VOLTAGE
 The array of VDD1P0 target voltage in standby mode. More...
#define STANDBY_MODE_VDD1P8_TARGET_VOLTAGE
 The array of VDD1P8 target voltage in standby mode. More...
#define BUCK_MODE_VDD1P0_TARGET_VOLTAGE
 The array of VDD1P0 target voltage in buck mode. More...
#define BUCK_MODE_VDD1P8_TARGET_VOLTAGE
 The array of VDD1P8 target voltage in buck mode. More...
typedef enum _dcdc_control_mode dcdc_control_mode_t
 DCDC control mode, including setpoint control mode and static control mode.
typedef enum _dcdc_trim_input_mode dcdc_trim_input_mode_t
 DCDC trim input mode, including sample trim input and hold trim input.
typedef enum _dcdc_standby_mode_1P0_target_vol dcdc_standby_mode_1P0_target_vol_t
 The enumeration VDD1P0's target voltage value in standby mode.
typedef enum _dcdc_standby_mode_1P8_target_vol dcdc_standby_mode_1P8_target_vol_t
 The enumeration VDD1P8's target voltage value in standby mode.
typedef enum _dcdc_buck_mode_1P0_target_vol dcdc_buck_mode_1P0_target_vol_t
 The enumeration VDD1P0's target voltage value in buck mode.
typedef enum _dcdc_buck_mode_1P8_target_vol dcdc_buck_mode_1P8_target_vol_t
 The enumeration VDD1P8's target voltage value in buck mode.
typedef enum _dcdc_comparator_current_bias dcdc_comparator_current_bias_t
 The current bias of low power comparator.
typedef enum _dcdc_peak_current_threshold dcdc_peak_current_threshold_t
 The threshold if peak current detection.
typedef enum _dcdc_clock_source dcdc_clock_source_t
 Oscillator clock option.
typedef enum _dcdc_voltage_output_sel dcdc_voltage_output_sel_t
 Voltage output option.
typedef struct _dcdc_config dcdc_config_t
typedef struct _dcdc_min_power_config dcdc_min_power_config_t
typedef struct _dcdc_detection_config dcdc_detection_config_t
typedef struct _dcdc_loop_control_config dcdc_loop_control_config_t
typedef struct _dcdc_internal_regulator_config dcdc_internal_regulator_config_t
typedef struct _dcdc_low_power_config dcdc_low_power_config_t
typedef struct _dcdc_setpoint_config dcdc_setpoint_config_t
enum  _dcdc_status_flags { kDCDC_AlreadySettledStatusFlag = DCDC_REG0_STS_DC_OK_MASK }
 The enumeration of DCDC status flags. More...
enum  _dcdc_setpoint_map {
  kDCDC_SetPoint0 = 1UL << 0UL , kDCDC_SetPoint1 = 1UL << 1UL , kDCDC_SetPoint2 = 1UL << 2UL , kDCDC_SetPoint3 = 1UL << 3UL ,
  kDCDC_SetPoint4 = 1UL << 4UL , kDCDC_SetPoint5 = 1UL << 5UL , kDCDC_SetPoint6 = 1UL << 6UL , kDCDC_SetPoint7 = 1UL << 7UL ,
  kDCDC_SetPoint8 = 1UL << 8UL , kDCDC_SetPoint9 = 1UL << 9UL , kDCDC_SetPoint10 = 1UL << 10UL , kDCDC_SetPoint11 = 1UL << 11UL ,
  kDCDC_SetPoint12 = 1UL << 12UL , kDCDC_SetPoint13 = 1UL << 13UL , kDCDC_SetPoint14 = 1UL << 14UL , kDCDC_SetPoint15 = 1UL << 15UL
 System setpoints enumeration. More...
enum  _dcdc_control_mode { kDCDC_StaticControl = 0U , kDCDC_SetPointControl = 1U }
 DCDC control mode, including setpoint control mode and static control mode. More...
enum  _dcdc_trim_input_mode { kDCDC_SampleTrimInput = 0U , kDCDC_HoldTrimInput = 1U }
 DCDC trim input mode, including sample trim input and hold trim input. More...
enum  _dcdc_standby_mode_1P0_target_vol {
  kDCDC_1P0StbyTarget0P625V = 0U , kDCDC_1P0StbyTarget0P65V , kDCDC_1P0StbyTarget0P675V , kDCDC_1P0StbyTarget0P7V ,
  kDCDC_1P0StbyTarget0P725V , kDCDC_1P0StbyTarget0P75V , kDCDC_1P0StbyTarget0P775V , kDCDC_1P0StbyTarget0P8V ,
  kDCDC_1P0StbyTarget0P825V , kDCDC_1P0StbyTarget0P85V , kDCDC_1P0StbyTarget0P875V , kDCDC_1P0StbyTarget0P9V ,
  kDCDC_1P0StbyTarget0P925V , kDCDC_1P0StbyTarget0P95V , kDCDC_1P0StbyTarget0P975V , kDCDC_1P0StbyTarget1P0V ,
  kDCDC_1P0StbyTarget1P025V , kDCDC_1P0StbyTarget1P05V , kDCDC_1P0StbyTarget1P075V , kDCDC_1P0StbyTarget1P1V ,
  kDCDC_1P0StbyTarget1P125V , kDCDC_1P0StbyTarget1P15V , kDCDC_1P0StbyTarget1P175V , kDCDC_1P0StbyTarget1P2V ,
  kDCDC_1P0StbyTarget1P225V , kDCDC_1P0StbyTarget1P25V , kDCDC_1P0StbyTarget1P275V , kDCDC_1P0StbyTarget1P3V ,
  kDCDC_1P0StbyTarget1P325V , kDCDC_1P0StbyTarget1P35V , kDCDC_1P0StbyTarget1P375V , kDCDC_1P0StbyTarget1P4V = 0x1FU
 The enumeration VDD1P0's target voltage value in standby mode. More...
enum  _dcdc_standby_mode_1P8_target_vol {
  kDCDC_1P8StbyTarget1P525V = 0U , kDCDC_1P8StbyTarget1P55V , kDCDC_1P8StbyTarget1P575V , kDCDC_1P8StbyTarget1P6V ,
  kDCDC_1P8StbyTarget1P625V , kDCDC_1P8StbyTarget1P65V , kDCDC_1P8StbyTarget1P675V , kDCDC_1P8StbyTarget1P7V ,
  kDCDC_1P8StbyTarget1P725V , kDCDC_1P8StbyTarget1P75V , kDCDC_1P8StbyTarget1P775V , kDCDC_1P8StbyTarget1P8V ,
  kDCDC_1P8StbyTarget1P825V , kDCDC_1P8StbyTarget1P85V , kDCDC_1P8StbyTarget1P875V , kDCDC_1P8StbyTarget1P9V ,
  kDCDC_1P8StbyTarget1P925V , kDCDC_1P8StbyTarget1P95V , kDCDC_1P8StbyTarget1P975V , kDCDC_1P8StbyTarget2P0V ,
  kDCDC_1P8StbyTarget2P025V , kDCDC_1P8StbyTarget2P05V , kDCDC_1P8StbyTarget2P075V , kDCDC_1P8StbyTarget2P1V ,
  kDCDC_1P8StbyTarget2P125V , kDCDC_1P8StbyTarget2P15V , kDCDC_1P8StbyTarget2P175V , kDCDC_1P8StbyTarget2P2V ,
  kDCDC_1P8StbyTarget2P225V , kDCDC_1P8StbyTarget2P25V , kDCDC_1P8StbyTarget2P275V , kDCDC_1P8StbyTarget2P3V = 0x1FU
 The enumeration VDD1P8's target voltage value in standby mode. More...
enum  _dcdc_buck_mode_1P0_target_vol {
  kDCDC_1P0BuckTarget0P6V = 0U , kDCDC_1P0BuckTarget0P625V , kDCDC_1P0BuckTarget0P65V , kDCDC_1P0BuckTarget0P675V ,
  kDCDC_1P0BuckTarget0P7V , kDCDC_1P0BuckTarget0P725V , kDCDC_1P0BuckTarget0P75V , kDCDC_1P0BuckTarget0P775V ,
  kDCDC_1P0BuckTarget0P8V , kDCDC_1P0BuckTarget0P825V , kDCDC_1P0BuckTarget0P85V , kDCDC_1P0BuckTarget0P875V ,
  kDCDC_1P0BuckTarget0P9V , kDCDC_1P0BuckTarget0P925V , kDCDC_1P0BuckTarget0P95V , kDCDC_1P0BuckTarget0P975V ,
  kDCDC_1P0BuckTarget1P0V , kDCDC_1P0BuckTarget1P025V , kDCDC_1P0BuckTarget1P05V , kDCDC_1P0BuckTarget1P075V ,
  kDCDC_1P0BuckTarget1P1V , kDCDC_1P0BuckTarget1P125V , kDCDC_1P0BuckTarget1P15V , kDCDC_1P0BuckTarget1P175V ,
  kDCDC_1P0BuckTarget1P2V , kDCDC_1P0BuckTarget1P225V , kDCDC_1P0BuckTarget1P25V , kDCDC_1P0BuckTarget1P275V ,
  kDCDC_1P0BuckTarget1P3V , kDCDC_1P0BuckTarget1P325V , kDCDC_1P0BuckTarget1P35V , kDCDC_1P0BuckTarget1P375V = 0x1FU
 The enumeration VDD1P0's target voltage value in buck mode. More...
enum  _dcdc_buck_mode_1P8_target_vol {
  kDCDC_1P8BuckTarget1P5V = 0U , kDCDC_1P8BuckTarget1P525V , kDCDC_1P8BuckTarget1P55V , kDCDC_1P8BuckTarget1P575V ,
  kDCDC_1P8BuckTarget1P6V , kDCDC_1P8BuckTarget1P625V , kDCDC_1P8BuckTarget1P65V , kDCDC_1P8BuckTarget1P675V ,
  kDCDC_1P8BuckTarget1P7V , kDCDC_1P8BuckTarget1P725V , kDCDC_1P8BuckTarget1P75V , kDCDC_1P8BuckTarget1P775V ,
  kDCDC_1P8BuckTarget1P8V , kDCDC_1P8BuckTarget1P825V , kDCDC_1P8BuckTarget1P85V , kDCDC_1P8BuckTarget1P875V ,
  kDCDC_1P8BuckTarget1P9V , kDCDC_1P8BuckTarget1P925V , kDCDC_1P8BuckTarget1P95V , kDCDC_1P8BuckTarget1P975V ,
  kDCDC_1P8BuckTarget2P0V , kDCDC_1P8BuckTarget2P025V , kDCDC_1P8BuckTarget2P05V , kDCDC_1P8BuckTarget2P075V ,
  kDCDC_1P8BuckTarget2P1V , kDCDC_1P8BuckTarget2P125V , kDCDC_1P8BuckTarget2P15V , kDCDC_1P8BuckTarget2P175V ,
  kDCDC_1P8BuckTarget2P2V , kDCDC_1P8BuckTarget2P225V , kDCDC_1P8BuckTarget2P25V , kDCDC_1P8BuckTarget2P275V = 0x1FU
 The enumeration VDD1P8's target voltage value in buck mode. More...
enum  _dcdc_comparator_current_bias {
  kDCDC_ComparatorCurrentBias50nA = 0U , kDCDC_ComparatorCurrentBias100nA = 1U , kDCDC_ComparatorCurrentBias200nA = 2U , kDCDC_ComparatorCurrentBias400nA = 3U ,
 The current bias of low power comparator. More...
enum  _dcdc_peak_current_threshold {
  kDCDC_PeakCurrentRunMode250mALPMode1P5A = 0U , kDCDC_PeakCurrentRunMode200mALPMode1P5A , kDCDC_PeakCurrentRunMode250mALPMode2A , kDCDC_PeakCurrentRunMode200mALPMode2A ,
  kDCDC_PeakCurrentThresholdAlt0 = 0U , kDCDC_PeakCurrentThresholdAlt1 = 1U , kDCDC_PeakCurrentThresholdAlt2 = 2U , kDCDC_PeakCurrentThresholdAlt3 = 3U ,
  kDCDC_PeakCurrentThresholdAlt4 = 4U , kDCDC_PeakCurrentThresholdAlt5 = 5U
 The threshold if peak current detection. More...
enum  _dcdc_clock_source {
  kDCDC_ClockAutoSwitch = 0U , kDCDC_ClockInternalOsc = 1U , kDCDC_ClockExternalOsc = 2U , kDCDC_ClockAutoSwitch = 0U ,
 Oscillator clock option. More...
enum  _dcdc_voltage_output_sel { kDCDC_VoltageOutput1P8 = 0U , kDCDC_VoltageOutput1P0 = 1U }
 Voltage output option. More...
Initialization and De-initialization Interfaces
void DCDC_Init (DCDC_Type *base, const dcdc_config_t *config)
 Initializes the basic resource of DCDC module, such as control mode, etc. More...
void DCDC_Deinit (DCDC_Type *base)
 De-initializes the DCDC module. More...
void DCDC_GetDefaultConfig (dcdc_config_t *config)
 Gets the default setting for DCDC, such as control mode, etc. More...
Detection Related Inferfaces
void DCDC_GetDefaultDetectionConfig (dcdc_detection_config_t *config)
 Gets the default setting for detection configuration. More...
void DCDC_SetDetectionConfig (DCDC_Type *base, const dcdc_detection_config_t *config)
 Configures the DCDC detection. More...
DCDC Miscellaneous Inferfaces
void DCDC_SetClockSource (DCDC_Type *base, dcdc_clock_source_t clockSource)
 Configures the DCDC clock source. More...
void DCDC_GetDefaultLowPowerConfig (dcdc_low_power_config_t *config)
 Gets the default setting for low power configuration. More...
void DCDC_SetLowPowerConfig (DCDC_Type *base, const dcdc_low_power_config_t *config)
 Configures the DCDC low power. More...
void DCDC_GetDefaultLoopControlConfig (dcdc_loop_control_config_t *config)
 Gets the default setting for loop control configuration. More...
void DCDC_SetLoopControlConfig (DCDC_Type *base, const dcdc_loop_control_config_t *config)
 Configures the DCDC loop control. More...
void DCDC_SetMinPowerConfig (DCDC_Type *base, const dcdc_min_power_config_t *config)
 Configures for the min power. More...
void DCDC_SetInternalRegulatorConfig (DCDC_Type *base, const dcdc_internal_regulator_config_t *config)
 Configures the DCDC internal regulator. More...
Setpoint Control Related Interfaces
void DCDC_SetPointInit (DCDC_Type *base, const dcdc_setpoint_config_t *config)
 Initializes DCDC module when the control mode selected as setpoint mode. More...
Application Guideline Interfaces
void DCDC_BootIntoDCM (DCDC_Type *base)
 Boots DCDC into DCM(discontinous conduction mode). More...
void DCDC_BootIntoCCM (DCDC_Type *base)
 Boots DCDC into CCM(continous conduction mode). More...
◆ BUCK_MODE_VDD1P0_TARGET_VOLTAGE
Value:
600, 625, 650, 675, 700, 725, 750, 775, 800, 825, 850, 875, 900, 925, 950, 975, 1000, 1025, 1050, 1075, 1100, \
1125, 1150, 1175, 1200, 1225, 1250, 1275, 1300, 1325, 1350, 1375 \
◆ BUCK_MODE_VDD1P8_TARGET_VOLTAGE
Value:
1500, 1525, 1550, 1575, 1600, 1625, 1650, 1675, 1700, 1725, 1750, 1775, 1800, 1825, 1850, 1875, 1900, 1925, \
1950, 1975, 2000, 2025, 2050, 2075, 2100, 2125, 2150, 2175, 2200, 2225, 2250, 2275 \
◆ FSL_DCDC_DRIVER_VERSION
Version 2.1.1.
◆ STANDBY_MODE_VDD1P0_TARGET_VOLTAGE
Value:
625, 650, 675, 700, 725, 750, 775, 800, 825, 850, 875, 900, 925, 950, 975, 1000, 1025, 1050, 1075, 1100, 1125, \
1150, 1175, 1200, 1225, 1250, 1275, 1300, 1325, 1350, 1375, 1400 \
◆ STANDBY_MODE_VDD1P8_TARGET_VOLTAGE
Value:
1525, 1550, 1575, 1600, 1625, 1650, 1675, 1700, 1725, 1750, 1775, 1800, 1825, 1850, 1875, 1900, 1925, 1950, \
1975, 2000, 2025, 2050, 2075, 2100, 2125, 2150, 2175, 2200, 2225, 2250, 2275, 2300 \
◆ _dcdc_buck_mode_1P0_target_vol
In buck mode, the target voltage value of VDD1P0 is 0.6V.
In buck mode, the target voltage value of VDD1P0 is 0.625V.
In buck mode, the target voltage value of VDD1P0 is 0.65V.
In buck mode, the target voltage value of VDD1P0 is 0.675V.
In buck mode, the target voltage value of VDD1P0 is 0.7V.
In buck mode, the target voltage value of VDD1P0 is 0.725V.
In buck mode, the target voltage value of VDD1P0 is 0.75V.
In buck mode, the target voltage value of VDD1P0 is 0.775V.
In buck mode, the target voltage value of VDD1P0 is 0.8V.
In buck mode, the target voltage value of VDD1P0 is 0.825V.
In buck mode, the target voltage value of VDD1P0 is 0.85V.
In buck mode, the target voltage value of VDD1P0 is 0.875V.
In buck mode, the target voltage value of VDD1P0 is 0.9V.
In buck mode, the target voltage value of VDD1P0 is 0.925V.
In buck mode, the target voltage value of VDD1P0 is 0.95V.
In buck mode, the target voltage value of VDD1P0 is 0.975V.
In buck mode, the target voltage value of VDD1P0 is 1.0V.
In buck mode, the target voltage value of VDD1P0 is 1.025V.
In buck mode, the target voltage value of VDD1P0 is 1.05V.
In buck mode, the target voltage value of VDD1P0 is 1.075V.
In buck mode, the target voltage value of VDD1P0 is 1.1V.
In buck mode, the target voltage value of VDD1P0 is 1.125V.
In buck mode, the target voltage value of VDD1P0 is 1.15V.
In buck mode, the target voltage value of VDD1P0 is 1.175V.
In buck mode, the target voltage value of VDD1P0 is 1.2V.
In buck mode, the target voltage value of VDD1P0 is 1.225V.
In buck mode, the target voltage value of VDD1P0 is 1.25V.
In buck mode, the target voltage value of VDD1P0 is 1.275V.
In buck mode, the target voltage value of VDD1P0 is 1.3V.
In buck mode, the target voltage value of VDD1P0 is 1.325V.
In buck mode, the target voltage value of VDD1P0 is 1.35V.
In buck mode, the target voltage value of VDD1P0 is 1.375V.
◆ _dcdc_buck_mode_1P8_target_vol
In buck mode, the target voltage value of VDD1P0 is 1.5V.
In buck mode, the target voltage value of VDD1P0 is 1.525V.
In buck mode, the target voltage value of VDD1P0 is 1.55V.
In buck mode, the target voltage value of VDD1P0 is 1.575V.
In buck mode, the target voltage value of VDD1P0 is 1.6V.
In buck mode, the target voltage value of VDD1P0 is 1.625V.
In buck mode, the target voltage value of VDD1P0 is 1.65V.
In buck mode, the target voltage value of VDD1P0 is 1.675V.
In buck mode, the target voltage value of VDD1P0 is 1.7V.
In buck mode, the target voltage value of VDD1P0 is 1.725V.
In buck mode, the target voltage value of VDD1P0 is 1.75V.
In buck mode, the target voltage value of VDD1P0 is 1.775V.
In buck mode, the target voltage value of VDD1P0 is 1.8V.
In buck mode, the target voltage value of VDD1P0 is 1.825V.
In buck mode, the target voltage value of VDD1P0 is 1.85V.
In buck mode, the target voltage value of VDD1P0 is 1.875V.
In buck mode, the target voltage value of VDD1P0 is 1.9V.
In buck mode, the target voltage value of VDD1P0 is 1.925V.
In buck mode, the target voltage value of VDD1P0 is 1.95V.
In buck mode, the target voltage value of VDD1P0 is 1.975V.
In buck mode, the target voltage value of VDD1P0 is 2.0V.
In buck mode, the target voltage value of VDD1P0 is 2.025V.
In buck mode, the target voltage value of VDD1P0 is 2.05V.
In buck mode, the target voltage value of VDD1P0 is 2.075V.
In buck mode, the target voltage value of VDD1P0 is 2.1V.
In buck mode, the target voltage value of VDD1P0 is 2.125V.
In buck mode, the target voltage value of VDD1P0 is 2.15V.
In buck mode, the target voltage value of VDD1P0 is 2.175V.
In buck mode, the target voltage value of VDD1P0 is 2.2V.
In buck mode, the target voltage value of VDD1P0 is 2.225V.
In buck mode, the target voltage value of VDD1P0 is 2.25V.
In buck mode, the target voltage value of VDD1P0 is 2.275V.
◆ _dcdc_clock_source
Automatic clock switch from internal oscillator to external clock.
Use internal oscillator.
Use external 24M crystal oscillator.
◆ _dcdc_comparator_current_bias
The current bias of low power comparator is 50nA.
The current bias of low power comparator is 100nA.
The current bias of low power comparator is 200nA.
The current bias of low power comparator is 400nA.
◆ _dcdc_control_mode
kDCDC_StaticControl
Static control.
Controlled by GPC set points.
◆ _dcdc_peak_current_threshold
Over peak current threshold in low power mode is 250mA, in run mode is 1.5A
Over peak current threshold in low power mode is 200mA, in run mode is 1.5A
Over peak current threshold in low power mode is 250mA, in run mode is 2A
Over peak current threshold in low power mode is 200mA, in run mode is 2A
150mA peak current threshold.
250mA peak current threshold.
350mA peak current threshold.
450mA peak current threshold.
550mA peak current threshold.
650mA peak current threshold.
◆ _dcdc_setpoint_map
kDCDC_SetPoint0
Set point 0.
kDCDC_SetPoint1
Set point 1.
kDCDC_SetPoint2
Set point 2.
kDCDC_SetPoint3
Set point 3.
kDCDC_SetPoint4
Set point 4.
kDCDC_SetPoint5
Set point 5.
kDCDC_SetPoint6
Set point 6.
kDCDC_SetPoint7
Set point 7.
kDCDC_SetPoint8
Set point 8.
kDCDC_SetPoint9
Set point 9.
kDCDC_SetPoint10
Set point 10.
kDCDC_SetPoint11
Set point 11.
kDCDC_SetPoint12
Set point 12.
kDCDC_SetPoint13
Set point 13.
kDCDC_SetPoint14
Set point 14.
kDCDC_SetPoint15
Set point 15.
◆ _dcdc_standby_mode_1P0_target_vol
In standby mode, the target voltage value of VDD1P0 is 0.625V.
In standby mode, the target voltage value of VDD1P0 is 0.65V.
In standby mode, the target voltage value of VDD1P0 is 0.675V.
In standby mode, the target voltage value of VDD1P0 is 0.7V.
In standby mode, the target voltage value of VDD1P0 is 0.725V.
In standby mode, the target voltage value of VDD1P0 is 0.75V.
In standby mode, the target voltage value of VDD1P0 is 0.775V.
In standby mode, the target voltage value of VDD1P0 is 0.8V.
In standby mode, the target voltage value of VDD1P0 is 0.825V.
In standby mode, the target voltage value of VDD1P0 is 0.85V.
In standby mode, the target voltage value of VDD1P0 is 0.875V.
In standby mode, the target voltage value of VDD1P0 is 0.9V.
In standby mode, the target voltage value of VDD1P0 is 0.925V.
In standby mode, the target voltage value of VDD1P0 is 0.95V.
In standby mode, the target voltage value of VDD1P0 is 0.975V.
In standby mode, the target voltage value of VDD1P0 is 1.0V.
In standby mode, the target voltage value of VDD1P0 is 1.025V.
In standby mode, the target voltage value of VDD1P0 is 1.05V.
In standby mode, the target voltage value of VDD1P0 is 1.075V.
In standby mode, the target voltage value of VDD1P0 is 1.1V.
In standby mode, the target voltage value of VDD1P0 is 1.125V.
In standby mode, the target voltage value of VDD1P0 is 1.15V.
In standby mode, the target voltage value of VDD1P0 is 1.175V.
In standby mode, the target voltage value of VDD1P0 is 1.2V.
In standby mode, the target voltage value of VDD1P0 is 1.225V.
In standby mode, the target voltage value of VDD1P0 is 1.25V.
In standby mode, the target voltage value of VDD1P0 is 1.275V.
In standby mode, the target voltage value of VDD1P0 is 1.3V.
In standby mode, the target voltage value of VDD1P0 is 1.325V.
In standby mode, the target voltage value of VDD1P0 is 1.35V.
In standby mode, the target voltage value of VDD1P0 is 1.375V.
In standby mode, The target voltage value of VDD1P0 is 1.4V
◆ _dcdc_standby_mode_1P8_target_vol
In standby mode, the target voltage value of VDD1P8 is 1.525V.
In standby mode, the target voltage value of VDD1P8 is 1.55V.
In standby mode, the target voltage value of VDD1P8 is 1.575V.
In standby mode, the target voltage value of VDD1P8 is 1.6V.
In standby mode, the target voltage value of VDD1P8 is 1.625V.
In standby mode, the target voltage value of VDD1P8 is 1.65V.
In standby mode, the target voltage value of VDD1P8 is 1.675V.
In standby mode, the target voltage value of VDD1P8 is 1.7V.
In standby mode, the target voltage value of VDD1P8 is 1.725V.
In standby mode, the target voltage value of VDD1P8 is 1.75V.
In standby mode, the target voltage value of VDD1P8 is 1.775V.
In standby mode, the target voltage value of VDD1P8 is 1.8V.
In standby mode, the target voltage value of VDD1P8 is 1.825V.
In standby mode, the target voltage value of VDD1P8 is 1.85V.
In standby mode, the target voltage value of VDD1P8 is 1.875V.
In standby mode, the target voltage value of VDD1P8 is 1.9V.
In standby mode, the target voltage value of VDD1P8 is 1.925V.
In standby mode, the target voltage value of VDD1P8 is 1.95V.
In standby mode, the target voltage value of VDD1P8 is 1.975V.
In standby mode, the target voltage value of VDD1P8 is 2.0V.
In standby mode, the target voltage value of VDD1P8 is 2.025V.
In standby mode, the target voltage value of VDD1P8 is 2.05V.
In standby mode, the target voltage value of VDD1P8 is 2.075V.
In standby mode, the target voltage value of VDD1P8 is 2.1V.
In standby mode, the target voltage value of VDD1P8 is 2.125V.
In standby mode, the target voltage value of VDD1P8 is 2.15V.
In standby mode, the target voltage value of VDD1P8 is 2.175V.
In standby mode, the target voltage value of VDD1P8 is 2.2V.
In standby mode, the target voltage value of VDD1P8 is 2.225V.
In standby mode, the target voltage value of VDD1P8 is 2.25V.
In standby mode, the target voltage value of VDD1P8 is 2.275V.
In standby mode, the target voltage value is 2.3V.
◆ _dcdc_status_flags
Indicate DCDC status. 1'b1: DCDC already settled 1'b0: DCDC is settling.
◆ _dcdc_trim_input_mode
Sample trim input.
kDCDC_HoldTrimInput
Hold trim input.
◆ _dcdc_voltage_output_sel
1.8V output.
1.0V output.
◆ DCDC_BootIntoCCM()
void DCDC_BootIntoCCM ( DCDC_Type base)
pwd_zcd=0x1;
pwd_cmp_offset=0x0;
dcdc_loopctrl_en_rcscale=0x3;
Parameters
baseDCDC peripheral base address.
brief Boots DCDC into CCM(continous conduction mode).
pwd_zcd=0x1; pwd_cmp_offset=0x0; dcdc_loopctrl_en_rcscale=0x3;
param base DCDC peripheral base address.
brief Boot DCDC into CCM(continous conduction mode).
◆ DCDC_BootIntoDCM()
void DCDC_BootIntoDCM ( DCDC_Type base)
pwd_zcd=0x0;
DM_CTRL = 1'b1;
pwd_cmp_offset=0x0;
dcdc_loopctrl_en_rcscale=0x3 or 0x5;
DCM_set_ctrl=1'b1;
Parameters
brief Boots DCDC into DCM(discontinous conduction mode).
pwd_zcd=0x0; DM_CTRL = 1'b1; pwd_cmp_offset=0x0; dcdc_loopctrl_en_rcscale=0x3 or 0x5; DCM_set_ctrl=1'b1;
brief Boot DCDC into DCM(discontinous conduction mode).
pwd_zcd=0x0; pwd_cmp_offset=0x0; dcdc_loopctrl_en_rcscale= 0x5; DCM_set_ctrl=1'b1;
◆ DCDC_Deinit()
void DCDC_Deinit ( DCDC_Type base)
Parameters
brief De-initializes the DCDC module.
brief Disable the access to DCDC registers.
◆ DCDC_GetDefaultConfig()
void DCDC_GetDefaultConfig ( dcdc_config_t config)
This function initializes the user configuration structure to a default value. The default values are:
config->controlMode = kDCDC_StaticControl;
config->trimInputMode = kDCDC_SampleTrimInput;
config->enableDcdcTimeout = false;
config->enableSwitchingConverterOutput = false;
@ kDCDC_StaticControl
Definition: fsl_dcdc.h:91
@ kDCDC_SampleTrimInput
Definition: fsl_dcdc.h:100
Definition: deflate.c:114
Parameters
configPointer to configuration structure. See to dcdc_config_t.
brief Gets the default setting for DCDC, such as control mode, etc.
This function initializes the user configuration structure to a default value. The default values are: code config->controlMode = kDCDC_StaticControl; config->trimInputMode = kDCDC_SampleTrimInput; config->enableDcdcTimeout = false; config->enableSwitchingConverterOutput = false; endcode
param config Pointer to configuration structure. See to dcdc_config_t.
◆ DCDC_GetDefaultDetectionConfig()
void DCDC_GetDefaultDetectionConfig ( dcdc_detection_config_t config)
The default configuration are set according to responding registers' setting when powered on. They are:
config->enableXtalokDetection = false;
config->powerDownOverVoltageVdd1P8Detection = true;
config->powerDownOverVoltageVdd1P0Detection = true;
config->powerDownLowVoltageDetection = false;
config->powerDownOverCurrentDetection = true;
config->powerDownPeakCurrentDetection = true;
config->powerDownZeroCrossDetection = true;
config->OverCurrentThreshold = kDCDC_OverCurrentThresholdAlt0;
config->PeakCurrentThreshold = kDCDC_PeakCurrentThresholdAlt0;
@ kDCDC_PeakCurrentThresholdAlt0
Definition: fsl_dcdc.h:60
@ kDCDC_OverCurrentThresholdAlt0
Definition: fsl_dcdc.h:49
Parameters
configPointer to configuration structure. See to dcdc_detection_config_t.
brief Gets the default setting for detection configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableXtalokDetection = false; config->powerDownOverVoltageVdd1P8Detection = true; config->powerDownOverVoltageVdd1P0Detection = true; config->powerDownLowVoltageDetection = false; config->powerDownOverCurrentDetection = true; config->powerDownPeakCurrentDetection = true; config->powerDownZeroCrossDetection = true; config->PeakCurrentThreshold = kDCDC_PeakCurrentRunMode250mALPMode1P5A; endcode
param config Pointer to configuration structure. See to "dcdc_detection_config_t"
brief Get the default setting for detection configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableXtalokDetection = false; config->powerDownOverVoltageDetection = true; config->powerDownLowVlotageDetection = false; config->powerDownOverCurrentDetection = true; config->powerDownPeakCurrentDetection = true; config->powerDownZeroCrossDetection = true; config->OverCurrentThreshold = kDCDC_OverCurrentThresholdAlt0; config->PeakCurrentThreshold = kDCDC_PeakCurrentThresholdAlt0; endcode
◆ DCDC_GetDefaultLoopControlConfig()
void DCDC_GetDefaultLoopControlConfig ( dcdc_loop_control_config_t config)
config->enableCommonHysteresis = false;
config->enableCommonThresholdDetection = false;
config->enableInvertHysteresisSign = false;
config->enableRCThresholdDetection = false;
config->enableRCScaleCircuit = 0U;
config->complementFeedForwardStep = 0U;
config->controlParameterMagnitude = 2U;
config->integralProportionalRatio = 2U;
Parameters
configPointer to configuration structure. See to dcdc_loop_control_config_t.
brief Gets the default setting for loop control configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableCommonHysteresis = false; config->enableCommonThresholdDetection = false; config->enableInvertHysteresisSign = false; config->enableRCThresholdDetection = false; config->enableRCScaleCircuit = 0U; config->complementFeedForwardStep = 0U; config->controlParameterMagnitude = 2U; config->integralProportionalRatio = 2U; endcode
param config Pointer to configuration structure. See to "dcdc_loop_control_config_t"
brief Get the default setting for loop control configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableCommonHysteresis = false; config->enableCommonThresholdDetection = false; config->enableInvertHysteresisSign = false; config->enableRCThresholdDetection = false; config->enableRCScaleCircuit = 0U; config->complementFeedForwardStep = 0U; endcode
◆ DCDC_GetDefaultLowPowerConfig()
void DCDC_GetDefaultLowPowerConfig ( dcdc_low_power_config_t config)
config->enableAdjustHystereticValue = false;
Parameters
configPointer to configuration structure. See to dcdc_low_power_config_t.
brief Gets the default setting for low power configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableAdjustHystereticValue = false; endcode
param config Pointer to configuration structure. See to "dcdc_low_power_config_t"
brief Get the default setting for low power configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableOverloadDetection = true; config->enableAdjustHystereticValue = false; config->countChargingTimePeriod = kDCDC_CountChargingTimePeriod8Cycle; config->countChargingTimeThreshold = kDCDC_CountChargingTimeThreshold32; endcode
◆ DCDC_Init()
void DCDC_Init ( DCDC_Type base,
const dcdc_config_t config
Parameters
configPointer to the dcdc_config_t structure.
brief Initializes the basic resource of DCDC module, such as control mode, etc.
param base DCDC peripheral base address. param config Pointer to the configuration structure.
◆ DCDC_SetClockSource()
void DCDC_SetClockSource ( DCDC_Type base,
Parameters
clockSourceClock source for DCDC. See to dcdc_clock_source_t.
brief Configures the DCDC clock source.
param base DCDC peripheral base address. param clockSource Clock source for DCDC. See to "dcdc_clock_source_t".
brief Configure the DCDC clock source.
◆ DCDC_SetDetectionConfig()
void DCDC_SetDetectionConfig ( DCDC_Type base,
const dcdc_detection_config_t config
Parameters
breif Configures the DCDC detection.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_detection_config_t"
breif Configure the DCDC detection.
◆ DCDC_SetInternalRegulatorConfig()
void DCDC_SetInternalRegulatorConfig ( DCDC_Type base,
const dcdc_internal_regulator_config_t config
Parameters
configPointer to configuration structure. See to dcdc_internal_regulator_config_t.
brief Configures the DCDC internal regulator.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_internal_regulator_config_t".
brief Configure the DCDC internal regulator.
◆ DCDC_SetLoopControlConfig()
void DCDC_SetLoopControlConfig ( DCDC_Type base,
const dcdc_loop_control_config_t config
Parameters
brief Configures the DCDC loop control.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_loop_control_config_t".
brief Configure the DCDC loop control.
◆ DCDC_SetLowPowerConfig()
void DCDC_SetLowPowerConfig ( DCDC_Type base,
const dcdc_low_power_config_t config
Parameters
brief Configures the DCDC low power.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_low_power_config_t".
brief Configure the DCDC low power.
◆ DCDC_SetMinPowerConfig()
void DCDC_SetMinPowerConfig ( DCDC_Type base,
const dcdc_min_power_config_t config
Parameters
configPointer to configuration structure. See to dcdc_min_power_config_t.
brief Configures for the min power.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_min_power_config_t".
brief Configure for the min power.
◆ DCDC_SetPointInit()
void DCDC_SetPointInit ( DCDC_Type base,
const dcdc_setpoint_config_t config
Note
The function should be invoked in the initial step to config the DCDC via setpoint control mode.
Parameters
configThe pointer to the structure dcdc_setpoint_config_t.
brief Initializes DCDC module when the control mode selected as setpoint mode.
note The function should be invoked in the initial step to config the DCDC via setpoint control mode.
param base DCDC peripheral base address. param config The pointer to the structure dcdc_setpoint_config_t.
