RTEMS 6.1-rc1
Modules | Files | Macros | Variables
spec:/testsuites/validation-one-cpu-0
This general purpose validation test suite provides enough resources to run basic tests with exactly one processor and without a Clock Driver. More...
 spec:/acfg/val/one-cpu
 Tests the effect of application configuration options.
 spec:/rtems/ratemon/req/cancel
 spec:/rtems/ratemon/req/get-status
 spec:/rtems/ratemon/req/period
 spec:/rtems/ratemon/req/timeout
 spec:/rtems/sem/req/delete
 spec:/rtems/sem/val/uni
 Tests uniprocessor-specific semaphore behaviour.
 spec:/rtems/signal/req/catch
 spec:/rtems/signal/req/send
 spec:/rtems/task/req/create-errors
 spec:/rtems/task/req/mode
 spec:/rtems/task/req/set-affinity
 spec:/rtems/task/req/set-priority
 spec:/rtems/task/req/wake-after
 spec:/score/val/fatal
 Tests some fatal errors.
file  ts-validation-one-cpu-0.c
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_PROCESSORS   1
const char rtems_test_name [] = "TestsuitesValidationOneCpu0"
 Each test must define a test name string.
Two test suites of this configuration are provided to limit test run duration.
