RTEMS 6.1-rc1
Test context for spec:/rtems/task/req/set-affinity test case. More...
T_scheduler_log_2 scheduler_log
 This member provides the scheduler operation records.
cpu_set_t cpuset_obj [2]
 This member provides the object referenced by the cpuset parameter.
rtems_status_code status
 This member contains the return value of the rtems_task_set_affinity() call.
rtems_id id
 This member specifies if the id parameter value.
size_t cpusetsize
 This member specifies if the cpusetsize parameter value.
cpu_set_t * cpuset
 This member specifies if the cpuset parameter value.
struct {
   size_t   pci [5]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [5]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqSetAffinity_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
