RTEMS 6.1-rc1
Test context for spec:/rtems/task/req/create-errors test case. More...
Data Fields | |
rtems_status_code | status |
rtems_id * | id |
rtems_id | id_value |
bool | create_extension_status |
uint32_t | create_extension_calls |
uint32_t | delete_extension_calls |
rtems_name | name |
rtems_task_priority | initial_priority |
size_t | stack_size |
rtems_attribute | attributes |
rtems_id | extension_id |
void * | seized_objects |
struct { | |
size_t pcs [7] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsTaskReqCreateErrors_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
