RTEMS 6.1-rc1
Test context for spec:/rtems/signal/req/send test case. More...
Data Fields | |
rtems_id | runner_id |
rtems_id | worker_id |
rtems_asr_entry | handler |
size_t | nested |
size_t | handler_calls |
size_t | calls_after_send |
size_t | calls_after_dispatch |
size_t | calls_after_enable |
rtems_signal_set | processed_signal_sets [2] |
uintptr_t | stack_pointers [2] |
rtems_mode | mode |
rtems_status_code | status |
rtems_id | id |
rtems_signal_set | signal_set |
struct { | |
size_t pcs [5] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsSignalReqSend_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
