RTEMS 6.1-rc1
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_swpmi.h File Reference
Header file of SWPMI HAL module. More...
#include "stm32h7xx_hal_def.h"
struct  SWPMI_InitTypeDef
 SWPMI Init Structure definition. More...
struct  SWPMI_HandleTypeDef
 SWPMI handle Structure definition. More...
#define HAL_SWPMI_ERROR_NONE   ((uint32_t)0x00000000)
#define HAL_SWPMI_ERROR_CRC   ((uint32_t)0x00000004)
#define HAL_SWPMI_ERROR_OVR   ((uint32_t)0x00000008)
#define HAL_SWPMI_ERROR_UDR   ((uint32_t)0x0000000C)
#define HAL_SWPMI_ERROR_DMA   ((uint32_t)0x00000010)
#define HAL_SWPMI_ERROR_TIMEOUT   ((uint32_t)0x00000020)
#define HAL_SWPMI_ERROR_TXBEF_TIMEOUT   ((uint32_t)0x00000040)
#define HAL_SWPMI_ERROR_TRANSCEIVER_NOT_READY   ((uint32_t)0x00000080)
#define SWPMI_VOLTAGE_CLASS_C   ((uint32_t)0x00000000)
#define SWPMI_VOLTAGE_CLASS_B   SWPMI_OR_CLASS
#define SWPMI_TX_NO_SOFTWAREBUFFER   ((uint32_t)0x00000000)
#define SWPMI_TX_SINGLE_SOFTWAREBUFFER   ((uint32_t)0x00000000)
#define SWPMI_TX_MULTI_SOFTWAREBUFFER   SWPMI_CR_TXMODE
#define SWPMI_RX_NO_SOFTWAREBUFFER   ((uint32_t)0x00000000)
#define SWPMI_RX_SINGLE_SOFTWAREBUFFER   ((uint32_t)0x00000000)
#define SWPMI_RX_MULTI_SOFTWAREBUFFER   SWPMI_CR_RXMODE
#define SWPMI_FLAG_RXBFF   SWPMI_ISR_RXBFF
#define SWPMI_FLAG_TXBEF   SWPMI_ISR_TXBEF
#define SWPMI_FLAG_RXBERF   SWPMI_ISR_RXBERF
#define SWPMI_FLAG_RXOVRF   SWPMI_ISR_RXOVRF
#define SWPMI_FLAG_TXUNRF   SWPMI_ISR_TXUNRF
#define SWPMI_FLAG_RXNE   SWPMI_ISR_RXNE
#define SWPMI_FLAG_TXE   SWPMI_ISR_TXE
#define SWPMI_FLAG_TCF   SWPMI_ISR_TCF
#define SWPMI_FLAG_SRF   SWPMI_ISR_SRF
#define SWPMI_FLAG_SUSP   SWPMI_ISR_SUSP
#define SWPMI_FLAG_DEACTF   SWPMI_ISR_DEACTF
#define SWPMI_FLAG_RDYF   SWPMI_ISR_RDYF
#define SWPMI_IT_RDYIE   SWPMI_IER_RDYIE
#define SWPMI_IT_SRIE   SWPMI_IER_SRIE
#define SWPMI_IT_TCIE   SWPMI_IER_TCIE
#define SWPMI_IT_TIE   SWPMI_IER_TIE
#define SWPMI_IT_RIE   SWPMI_IER_RIE
#define SWPMI_IT_TXUNRIE   SWPMI_IER_TXUNRIE
#define SWPMI_IT_RXOVRIE   SWPMI_IER_RXOVRIE
#define SWPMI_IT_RXBERIE   SWPMI_IER_RXBERIE
#define SWPMI_IT_TXBEIE   SWPMI_IER_TXBEIE
#define SWPMI_IT_RXBFIE   SWPMI_IER_RXBFIE
#define __HAL_SWPMI_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SWPMI_STATE_RESET)
 Reset SWPMI handle state. More...
#define __HAL_SWPMI_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT)
 Enable the SWPMI peripheral. More...
#define __HAL_SWPMI_DISABLE(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT)
 Disable the SWPMI peripheral. More...
#define __HAL_SWPMI_TRANSCEIVER_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN)
 Enable the SWPMI transceiver. More...
#define __HAL_SWPMI_TRANSCEIVER_DISABLE(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN)
 Disable the SWPMI transceiver. More...
#define __HAL_SWPMI_GET_FLAG(__HANDLE__, __FLAG__)   (READ_BIT((__HANDLE__)->Instance->ISR, (__FLAG__)) == (__FLAG__))
 Check whether the specified SWPMI flag is set or not. More...
#define __HAL_SWPMI_CLEAR_FLAG(__HANDLE__, __FLAG__)   WRITE_REG((__HANDLE__)->Instance->ICR, (__FLAG__))
 Clear the specified SWPMI ISR flag. More...
#define __HAL_SWPMI_ENABLE_IT(__HANDLE__, __INTERRUPT__)   SET_BIT((__HANDLE__)->Instance->IER, (__INTERRUPT__))
 Enable the specified SWPMI interrupt. More...
#define __HAL_SWPMI_DISABLE_IT(__HANDLE__, __INTERRUPT__)   CLEAR_BIT((__HANDLE__)->Instance->IER, (__INTERRUPT__))
 Disable the specified SWPMI interrupt. More...
#define __HAL_SWPMI_GET_IT(__HANDLE__, __IT__)   (READ_BIT((__HANDLE__)->Instance->ISR,(__IT__)) == (__IT__))
 Check whether the specified SWPMI interrupt has occurred or not. More...
#define __HAL_SWPMI_GET_IT_SOURCE(__HANDLE__, __IT__)   ((READ_BIT((__HANDLE__)->Instance->IER, (__IT__)) == (__IT__)) ? SET : RESET)
 Check whether the specified SWPMI interrupt source is enabled or not. More...
#define IS_SWPMI_VOLTAGE_CLASS(__CLASS__)
#define IS_SWPMI_BITRATE_VALUE(__VALUE__)   (((__VALUE__) <= 255U))
#define IS_SWPMI_TX_BUFFERING_MODE(__MODE__)
#define IS_SWPMI_RX_BUFFERING_MODE(__MODE__)
enum  HAL_SWPMI_StateTypeDef {
  HAL_SWPMI_STATE_RESET = 0x00 , HAL_SWPMI_STATE_READY = 0x01 , HAL_SWPMI_STATE_BUSY = 0x02 , HAL_SWPMI_STATE_BUSY_TX = 0x12 ,
  HAL_SWPMI_STATE_BUSY_RX = 0x22 , HAL_SWPMI_STATE_BUSY_TX_RX = 0x32 , HAL_SWPMI_STATE_TIMEOUT = 0x03 , HAL_SWPMI_STATE_ERROR = 0x04
 HAL SWPMI State structures definition. More...
HAL_StatusTypeDef HAL_SWPMI_Init (SWPMI_HandleTypeDef *hswpmi)
HAL_StatusTypeDef HAL_SWPMI_DeInit (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_MspInit (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_MspDeInit (SWPMI_HandleTypeDef *hswpmi)
HAL_StatusTypeDef HAL_SWPMI_Transmit (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_SWPMI_Receive (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_SWPMI_Transmit_IT (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SWPMI_Receive_IT (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SWPMI_Transmit_DMA (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SWPMI_Receive_DMA (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SWPMI_DMAStop (SWPMI_HandleTypeDef *hswpmi)
HAL_StatusTypeDef HAL_SWPMI_EnableLoopback (SWPMI_HandleTypeDef *hswpmi)
HAL_StatusTypeDef HAL_SWPMI_DisableLoopback (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_IRQHandler (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_TxCpltCallback (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_TxHalfCpltCallback (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_RxCpltCallback (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_RxHalfCpltCallback (SWPMI_HandleTypeDef *hswpmi)
void HAL_SWPMI_ErrorCallback (SWPMI_HandleTypeDef *hswpmi)
HAL_SWPMI_StateTypeDef HAL_SWPMI_GetState (SWPMI_HandleTypeDef *hswpmi)
uint32_t HAL_SWPMI_GetError (SWPMI_HandleTypeDef *hswpmi)
Author
MCD Application Team
Attention
