RTEMS 6.1-rc1
#define __HAL_SWPMI_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SWPMI_STATE_RESET)
 Reset SWPMI handle state. More...
#define __HAL_SWPMI_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT)
 Enable the SWPMI peripheral. More...
#define __HAL_SWPMI_DISABLE(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT)
 Disable the SWPMI peripheral. More...
#define __HAL_SWPMI_TRANSCEIVER_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN)
 Enable the SWPMI transceiver. More...
#define __HAL_SWPMI_TRANSCEIVER_DISABLE(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN)
 Disable the SWPMI transceiver. More...
#define __HAL_SWPMI_GET_FLAG(__HANDLE__, __FLAG__)   (READ_BIT((__HANDLE__)->Instance->ISR, (__FLAG__)) == (__FLAG__))
 Check whether the specified SWPMI flag is set or not. More...
#define __HAL_SWPMI_CLEAR_FLAG(__HANDLE__, __FLAG__)   WRITE_REG((__HANDLE__)->Instance->ICR, (__FLAG__))
 Clear the specified SWPMI ISR flag. More...
#define __HAL_SWPMI_ENABLE_IT(__HANDLE__, __INTERRUPT__)   SET_BIT((__HANDLE__)->Instance->IER, (__INTERRUPT__))
 Enable the specified SWPMI interrupt. More...
#define __HAL_SWPMI_DISABLE_IT(__HANDLE__, __INTERRUPT__)   CLEAR_BIT((__HANDLE__)->Instance->IER, (__INTERRUPT__))
 Disable the specified SWPMI interrupt. More...
#define __HAL_SWPMI_GET_IT(__HANDLE__, __IT__)   (READ_BIT((__HANDLE__)->Instance->ISR,(__IT__)) == (__IT__))
 Check whether the specified SWPMI interrupt has occurred or not. More...
#define __HAL_SWPMI_GET_IT_SOURCE(__HANDLE__, __IT__)   ((READ_BIT((__HANDLE__)->Instance->IER, (__IT__)) == (__IT__)) ? SET : RESET)
 Check whether the specified SWPMI interrupt source is enabled or not. More...
◆ __HAL_SWPMI_CLEAR_FLAG
#define __HAL_SWPMI_CLEAR_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__HANDLE__specifies the SWPMI Handle.
__FLAG__specifies the flag to clear. This parameter can be one of the following values:
  • SWPMI_FLAG_RXBFF Receive buffer full flag.
  • SWPMI_FLAG_TXBEF Transmit buffer empty flag.
  • SWPMI_FLAG_RXBERF Receive CRC error flag.
  • SWPMI_FLAG_RXOVRF Receive overrun error flag.
  • SWPMI_FLAG_TXUNRF Transmit underrun error flag.
  • SWPMI_FLAG_TCF Transfer complete flag.
  • SWPMI_FLAG_SRF Slave resume flag.
  • SWPMI_FLAG_RDYF Transceiver ready flag.
Return values
None
◆ __HAL_SWPMI_DISABLE
#define __HAL_SWPMI_DISABLE (   __HANDLE__)    CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT)
Parameters
__HANDLE__SWPMI handle
Return values
None
◆ __HAL_SWPMI_DISABLE_IT
#define __HAL_SWPMI_DISABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the SWPMI interrupt source to disable. This parameter can be one of the following values:
  • SWPMI_IT_RDYIE Transceiver ready interrupt.
  • SWPMI_IT_SRIE Slave resume interrupt.
  • SWPMI_IT_TCIE Transmit complete interrupt.
  • SWPMI_IT_TIE Transmit interrupt.
  • SWPMI_IT_RIE Receive interrupt.
  • SWPMI_IT_TXUNRIE Transmit underrun error interrupt.
  • SWPMI_IT_RXOVRIE Receive overrun error interrupt.
  • SWPMI_IT_RXBEIE Receive CRC error interrupt.
  • SWPMI_IT_TXBEIE Transmit buffer empty interrupt.
  • SWPMI_IT_RXBFIE Receive buffer full interrupt.
Return values
None
◆ __HAL_SWPMI_ENABLE
#define __HAL_SWPMI_ENABLE (   __HANDLE__)    SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT)
Parameters
Return values
None
◆ __HAL_SWPMI_ENABLE_IT
#define __HAL_SWPMI_ENABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the SWPMI interrupt source to enable. This parameter can be one of the following values:
Return values
None
◆ __HAL_SWPMI_GET_FLAG
#define __HAL_SWPMI_GET_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__FLAG__specifies the flag to check. This parameter can be one of the following values:
  • SWPMI_FLAG_RXNE Receive data register not empty.
  • SWPMI_FLAG_TXE Transmit data register empty.
  • SWPMI_FLAG_SUSP SUSPEND flag.
  • SWPMI_FLAG_DEACTF DEACTIVATED flag.
Return values
Thenew state of FLAG (TRUE or FALSE).
◆ __HAL_SWPMI_GET_IT
#define __HAL_SWPMI_GET_IT (   __HANDLE__,
  __IT__
Parameters
__IT__specifies the SWPMI interrupt to check. This parameter can be one of the following values:
  • SWPMI_IT_RXBERIE Receive CRC error interrupt.
Return values
Thenew state of IT (TRUE or FALSE).
◆ __HAL_SWPMI_GET_IT_SOURCE
#define __HAL_SWPMI_GET_IT_SOURCE (   __HANDLE__,
  __IT__
Parameters
__IT__specifies the SWPMI interrupt source to check. This parameter can be one of the following values:
Return values
◆ __HAL_SWPMI_RESET_HANDLE_STATE
#define __HAL_SWPMI_RESET_HANDLE_STATE (   __HANDLE__)    ((__HANDLE__)->State = HAL_SWPMI_STATE_RESET)
Parameters
Return values
None
◆ __HAL_SWPMI_TRANSCEIVER_DISABLE
#define __HAL_SWPMI_TRANSCEIVER_DISABLE (   __HANDLE__)    CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN)
Parameters
Return values
None
◆ __HAL_SWPMI_TRANSCEIVER_ENABLE
#define __HAL_SWPMI_TRANSCEIVER_ENABLE (   __HANDLE__)    SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN)
Parameters
Return values
None
